#151 | |||
![]() Join Date: Dec 2004
#152 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
#153 | ||
Do you reckon he would cut a genuine AU hose???
#154 | ||
Little dearer than I would have liked, but it seems like pretty good insurance.
#155 | ||
not here much anymore
Where do they fit in the cooling system Whoosh? Just anywhere you like in the bay, cut a hose type thing?
RAM 1500
#156 | ||
AU DIE HARD
It comes with all the fitting info Aust, but I would rekon between the water pump and the radiator would be the go , but as Pinky says I wouldnt cut a new hose to fit it let alone a silicon 1
#157 | |||
AU DIE HARD
Well all is good at the house of Windsor (touch wood) Hector Ms finest has taken to the road in anger again
![]() ![]() ![]() ![]() Last of the Flat white ![]() ![]() a few tools ![]() ![]() ![]() Nice one Hector M ![]() Cleaned and ready to rock ![]() ![]() ![]() Seto bear was waiting as were the go fast fluffy dice ![]() ![]() ![]() Cheers gang if any one needs more info.. send me a PM
#158 | |||
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Well done mate. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
#159 | |||
AU DIE HARD
Just poked around for a few Ks Stu checking stuff along the way (hence why I have left the clear header tank on for the min.) after a 1/2 hour or so gave it a bit up to the freeway limit, in 2nd gear
![]() ![]() ![]() Did I mention Project Lift a Leg has arrived home ![]() ![]() ![]() ![]()
#160 | ||
T3 TE50 Blueprint
I have been running a TEFBA cooling system filter since new in '02. I was getting machining swarf stuck in it from day 1. My Dad has been using them since they came out. So I guess it's hereditary.
-Craig |
#161 | ||
Lost Boost Gained Class
good news whoosha glad the sleepping beast is out to play again
2006 BF Fairmont Ghia
2001 AU Falcon |
