Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
31-10-2023, 07:37 PM | #1681 | ||
Thank you for the taillight and bracket.
31-10-2023, 07:43 PM | #1682 | ||
09-11-2023, 10:04 PM | #1683 | ||
Mr GT... I'm hoping you can provide a price and availability on the 2 toe adjusting cam bolts for a 2006 BF Falcon. The ones under the diff as pictured.
Part number from the last time I bought them was BA5K751AKT, unless that's been superseded. Cheers. |
09-11-2023, 11:17 PM | #1684 | |||
That part number is still available, $115 each plus postage. GT |
12-11-2023, 01:48 PM | #1685 | ||
Hey GT, I'm looking for a specific part but can't find any information on it, or how deep this particular rabbit hole is going to for that matter.
I'm looking for any wiring/looms going from the Wastegate Solenoid of an FG2 XR6 Turbo all the way to the ECU. Not sure if it's relevant to my issue, but it's a part that I don't have so could be a good start. It's an NA+T and I'm getting a DSC fault on the dash. Checking the codes gives me U0401:00-AB, can't remember the specific wording but something along the lines of "Invalid data received from ECM/PCM A" A google search found someone with the same fault fit the original wastegate solenoid which cleared the code. So I'm going to try my luck there Thanks in advance. |
12-11-2023, 03:06 PM | #1686 | |||
I will have a think. Might need to rethink using the spares I have here instead. Cheers for the response. Its much appreciated. |
12-11-2023, 04:51 PM | #1687 | ||
Sprinting Everywhere!
Hi Mr GT, after some mondeo rubber mats part number
DS73F130D00NA3ZHE Thanks mate! |
12-11-2023, 09:08 PM | #1688 | |||
Hey mate, so are you chasing the wiring or the solenoid? Have a look at the below pic, I believe the part you are searching for might be a combination of the three engine/RH/LH engine bay wiring. Easiest way is to look at the tag on the wiring on the car and advise, we can chase from there. FG2 Engine Bay Wiring.png |
12-11-2023, 09:10 PM | #1689 | ||
13-11-2023, 06:44 AM | #1690 | |||
I'm assuming that the Turbo wiring (this solenoid connector and the Dual Fans, for example) aren't just tucked away somewhere unused on the existing NA loom and I'll need to source a turbo loom with C-310, does that sound about right? Thanks for the help |
13-11-2023, 08:08 AM | #1691 | |||
Just to show how confusing below are all the applicable 14K011 wiring looms for FG2 XR6 Turbos alone!! There are thripple that for the rest of the FG2 line up. FG2 XR6T Engine Wiring.png FG2 XR6T Engine Wiring 2.png FG2 XR6T Engine Wiring 3.png |
13-11-2023, 09:23 AM | #1692 | |||
Well I found the label on my loom, it's BR29 14K011 FC. That's obviously an NA one, but does it at least narrow it down to which one I need to replace it with? How can I tell which level headlamps I've got? Also, I'm guessing the 'extra engine cooling' is referring to dual cooling fans opposed to single? |
13-11-2023, 11:25 AM | #1693 | |||
Yes extra cooling is the dual fans and raditor type. In I6 NA & Turbo uses the same radiator, but LPi is different . A VIN will confirm most build questions about your particular car. |
13-11-2023, 02:49 PM | #1694 | |||
13-11-2023, 03:14 PM | #1695 | ||
13-11-2023, 04:06 PM | #1696 | |||
https://forum.hptuners.com/showthrea...-on-after-tune |
16-11-2023, 05:35 PM | #1697 | ||
Hi GTL.
im after a a/c condensor (radiator) OEM part number and availability for a my10 2011 fg gt. cheers if you can help. |
16-11-2023, 08:10 PM | #1698 | |||
Assuming its a 5.0 not 5.4. 5.0 has part number AR2Z19710CA and can get for $650 plus freight. 5.4 has part number BG19710A but is obsolete. GT |
19-11-2023, 12:09 PM | #1699 | ||
19-11-2023, 06:44 PM | #1700 | ||
I have a contact at GMH (GMSV now) that I can ask..
20-11-2023, 11:57 AM | #1701 | ||
Any idea how many different BCMs there are in FGII? I have an Ecolpi ute and wondering if sedan BCM is same.
20-11-2023, 02:27 PM | #1702 | ||
20-11-2023, 02:34 PM | #1703 | ||
20-11-2023, 05:38 PM | #1704 | ||
21-11-2023, 09:59 AM | #1705 | ||
A fellow with an FG-X XR8 may try to contact you, he’s looking for a radiator fan control module.
21-11-2023, 10:09 AM | #1706 | ||
21-11-2023, 11:15 AM | #1707 | ||
Apparently there are a couple of different price, need a VIN to confirm which one.
21-11-2023, 11:43 AM | #1708 | ||
Hey there, not so much interested in price, as availability! I'm trying to track down a top grille and the trim piece that sits under it for a Series I FG G6E. Absolutely nothing available that we can find here in NZ (even from wreckers), so needing freight from Aus. Thanks heaps
21-11-2023, 12:00 PM | #1709 | |||
Think this one is now sorted - bought a rear mounting kit this morning that’s 50% correct for my front - and the other two are probably slight differences in side-to-side curvature. I believe the different front kits likely reflected a flatter bumper face of the “sports” versions, vs standard. |
21-11-2023, 01:53 PM | #1710 | |||
