#1231 | ||
Leave it with me for a bit will see what I can find. What part numbers have you seen or tried so far?
#1232 | |||
![]() Join Date: Jul 2013
It was Bayford, and the ID was W715014SS3JA6. Although as I look at the listing it's FG, so was never going to work, but I hadn't seen anything so gave it a go. The others that I've tried are the lugs that fit the aftermarket 'Tickford' embroidered mats that you find around the place. Cheers.
The Current Fleet: 2018 Kia Sportage GTLine 2014 FG-X G6E T 2012 FG-II GTP #288 2002 AU-III XR8 Previous rides (1977 TE Cortina, 2001 AUII XR6, 2004 BAI XR8 Ute, 2005 BAII Typhoon, 2008 FG F6, 2015 FG-X XR6 Ute, 2006 SY Territory Turbo Ghia...it just used too much fuel) |
#1233 | |||
Give me a few days, I will see what I can dig up, they may be no longer available but hopefully we can at least dig up a part number. It may have also been part of the mat kit and not available separately. Be in touch.. |
#1234 | ||
It may have been mentioned prior, but can you obtain the security codes for EA - AU radios?
#1235 | ||
Possibly, as long as the radio is from the original VIN, in other words need to know the VIN the radio was originally from. If there has been a swap over the years, it may come back incorrect. Worth a shot though..
#1236 | ||
*SILVER SERVICE PILOT*
![]() ![]() Join Date: Jul 2006
Hey GT, was there a revised bonnet cable and fuse box for B series cars to fix the common breakages a few years ago?
Thought I recalled a stronger fuse box mounting point where the bonnet cable attached?
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
#1237 | |||
I am pretty sure there was no updated cable, just the fuse box. It went from a BAF14A073A part number to a BA14A073A. If memory serves me right the change came about in 2010.. |
#1238 | ||
#1239 | |||
Officially no. I am not sure if the pulley is bolted or pressed on to the tensioner, would need to see one in person. It may not easily be removed, but if it is, then we would need to see if it matches the other pulleys. Guessing Ford made it non removable for a reason if so. |
#1240 | |||
Can i then please just order B, F and G ? Cheers |
#1241 | ||
#1242 | ||
#1244 | ||
#1246 | ||
[QUOTE=GTLEGEND;6788501]For which vehicle?[/QUOTE
The vehicle is an AU2 |
#1247 | ||
#1249 | ||
#1250 | |||
Floor Mat Fastener.jpg Floor Mat Fastener 2.jpg |
#1251 | |||
Cheers.
#1252 | |||
Do these screw into somthing under the carpet or is that thread going to grip into the carpet?
Are these the fg1 model? Cheers Quote:
Current 2009 FG GTP Sold 2003 boss 260 xr8 daily driver 1991 eb1 xr8 once a year driver, factory cassette player |
#1253 | ||
![]() Join Date: Jan 2007
Hi GT,
Rocker shims for AU 6 Cyl - are they available? Regards, George |
#1254 | |||
1.9mm Rocker shims that between the lash adjuster and the arm of the rocker had part number ED6K514A, obsolete and no longer available. They were also part of the whole rocker arm assembly, part number EL6564B but they are also long gone. GT |
#1255 | ||
#1256 | ||
#1257 | ||
Thanks, any idea what the speed nut clip clips to? To sop it spinning
#1258 | |||
Regards, George |
#1259 | ||
#1260 | ||
Hi GT.
I'm after the plastic guard for behind the left rear wheel on a fg gt Local Ford say there is no option, it is trimmed differently where it meets the bumper, And holes are in the wrong place to trim a standard xr g6 one Cheers
