05-12-2013, 06:47 PM | #91 | ||
Peter Car
Heavy duty axle would be 4 pinion centre, as factory fitted to the V8's? At least the heavy duty diff was basically the V8 diff.
No XD ever came from the factory with a 9 inch. It's a myth that has been spoken of forever but it's been proven wrong a million times. |
05-12-2013, 08:28 PM | #92 | |||
Interesting you are not familiar with the term 'pony car' used to describe compact performance cars from all US manufacturers during the 60s to early 70s........this term would have its origins with the introduction of the mustang in 1964 as you say though. Our XAs on would be the equivalent of what the yanks call 'intermediates'.......US Fords equivalent would be the larger 71 mustang, torino etc. Cheers Mick Last edited by HO 3; 05-12-2013 at 08:55 PM. |
05-12-2013, 11:20 PM | #93 | ||
I recall when the XD's came out and all us young turks at the dealership were mourning the passing of the 9 inch. We all reckoned that the 5.8 manual XD's were going to blow these little standard diff centres to smithereens.
They didn't. Maybe the engineers at Ford knew just a tad more about power trains than our rag-tag bunch of apprentices and newly qualified tradesmen! Russ |
05-12-2013, 11:25 PM | #94 | ||
T3 TL50. Only one made. The other two were series 2 cars converted the series 3 spec by Tickford for brochures etc. So there is only one car, one of the Black ones, with the correct series 3 model code on its ID plates.
I'm not sure if a TL is a muscle car, but neither is a Landau. They are both cool though. PS. They are only 14 series 2 TL's, so the're not plentiful either.
Oooh baby living in Miami....
06-12-2013, 10:28 AM | #95 | ||
XD police interceptors also came with 2 radius rods. I had a XD 351 GL ex cop car and it had the 2 rods including the factory mounting points on the chassis both sides, same as my XD 351 Fairmont Ghia ESP
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
06-12-2013, 09:28 PM | #96 | ||
Of course the T3 TL50 is a Muscle Car.
Limited build number, badged and numbered by Fords then performance arm - Tickford. It carries a factory stroker version of the 5.0 litre Windsor loaded with all Aussie performance parts including the specially Tickford designed 8 trumpet inlet manifold, 82mm progressive throttle body and was the first Aussie Ford with a cone style air filter. Backed by a strengthened driveline to handle the 5.6L engines 250kw/500nm the 4 speed ESS auto coupled with the purpose built LSD differential resulted in a WSID qtr mile time slip of 14.2 secs in factory standard form including tyres. If that is not deserving of a Muscle Car tag I don't know what is. But of course my opinion may be a little bit biased
5 users like this post: |
06-12-2013, 10:47 PM | #97 | ||
335 kw of goodness
Fully agree!
CAUTION! STILL Contain's opinion's & fact's that may offend !!! : 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
06-12-2013, 11:12 PM | #98 | ||
Oo\===/oO
Wouldn't a landau be what the Cougar is to the mustang in a way?
06-12-2013, 11:32 PM | #99 | ||
As is mine. I'm a huge fan of the muscle barge.
07-12-2013, 12:23 AM | #100 | |||
P6 LTD
Your XD may well have had the 9" fitted from the factory but I very much doubt it. The 9" was dis-continued for the XC as of November 1978 and for the ZH/P6, January 1979, see below From the introduction of the XD, all vehicles were supplied with the Borg Warner differentials. Note H/D notation on some of the axle types Back in the '70's pretty much any thing went. In that, nobody can guarantee that your car was or was not fitted with the 9" diff. However, the factory fit was BW for all XD's. What you need to bear in mind are a few facts. First up, Ford had a review of internal manufacturing costs circa 1975/76, I have the report, just can't find it now. Within the report it showed that the costs of making the 9" diffs were much more expensive than the externally supplied BW diffs. Following on from that, the 9" was well overrated for the XC 351 and very much so for the XD 351 so why would they discontinue the 9" in the XC range and then bring it back again? What also has to be taken into account is a number of inherent design faults for the late XB and all XC 9" diffs, all of which were resolved with the BW design. These faults were as follows; 1) The axle bearings upon failure, required for the whole shaft to be replaced, not an ideal situation. 2) The hemisphere given shock loading was also subject to failure, namely cracking around the bolt PCD 3) No oil drain hole, who would have thought???? 4) The clutch packs, given some proper loading and even after time, wore out. In that, the LSD now became a single spinner. Regarding the BW 4 pinion LSD, these had the cone type clutch and the limited slip function, lasted a lot longer than the 9"s did. So you have to ask yourself why would Ford continue with an out-dated, over-rated, more expensive and heavier differential than that of the BW????? Lastly, the 9" was still in production during the XD era and well into the '80's. Thing is, all of these 9" diffs were for the F series trucks. As you would be aware, the housing was much wider than the sedan one. Perhaps there may have been spares available of the passenger 9" housing the early '80's, who knows but to me it is very clear, the XD series never had the 9" as standard fit. |
4 users like this post: |
07-12-2013, 08:23 AM | #101 | ||
If we are going to continue slightly off topic .. Build numbers for Right-hand-drive, AMI-assembled Javelins/AMXs (pony cars not really musclecars) in Port Melbourne (what is now part of Toyota):
1968 90 javelins 1969 50 javelins / 24 AMXs 1970 70 javelins 1972 48 javelins |
07-12-2013, 08:46 AM | #102 | |||
07-12-2013, 09:11 AM | #103 | ||
What annoys me is the lack of appreciation of future rare muscle cars by some .
i saw a middle aged woman drive into the bunnings carpark a hsv coupe4. (Awd hsv gto monaro). Front and rear bars both torn up, car all marked up and paint damaged. How can she treat such a car so poorly? This is a classic example of someone who needs an old pulsar as a daily drive if they are gonna treat them like dodgem cars. a hsv coupe4 is a certain future classic |
2 users like this post: |
07-12-2013, 09:33 AM | #104 | |||
I am Groot
.. McLaren F1 Dick Johnson Racing "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
07-12-2013, 09:53 AM | #105 | |||
just because people state factory in an ad doesn't mean it's true |
07-12-2013, 11:07 AM | #106 | ||
07-12-2013, 11:10 AM | #107 | |||
FAWD - No Boundaries
Whilst talking to these enthusiasts... I was told there were Seven Force 7V's which survived the crusher. All of them were pre-production models and were never intended for sale to the public (meaning they hadn't yet moved to the full-production stage, which then would have been sold to the public) I seem to remember a Wheels or MM magazine article (way back when) on one that had been shipped to England by a keen collector !?? Amongst all the other P76's there, was one Wagon. According to these Guys.. The Wagon body style had been cleared for production... and this one is the 1st full-production Wagon.. and the only one to make it down the line. Well.. almost ! I was told that the day Leyland ceased production in Oz... this Wagon hadn't quite made it to the end of the line... This one looked to be only 99.5% finished.. with the tailgate window seal missing (& perhaps a few other things as well).... and the chrome trim around the Wagon side widows looking a bit "hand made" !?? All other Wagon bodies were crushed. This Wagon is however, a Factory V8 4spd manual... which I thought was a pretty cool combination to have.. especially if it was the only one to have survived ! (It's the cream one in the pics on that link... & has been kept in great original condition too !!) These guys did acknowledge that there are other P76 Wagons around... but were aware of the actual Dude's that made them by converting Sedans into Wagons.. and were also fairly sure where they all are now. It was great to see so many of these uniquely Australian cars gathered in one place... 6's & 8's... coupes, Sedans & Wagon (& a home made V8 Ute too!)... Autos & Manuals... base models through to Targa Florios (Blue & Green) Clunkers, well kept originals & fully restored... and all the colours of the rainbow (and, of course... Brown ) Did the P76 rate as Muscle Cars ??? Hmmm.. Legend has it, Leyland had intended to take on the "Big 3" at Bathurst with the Force 7V ... but closed it's doors before that ever happened. It was "only" a 4.4Ltr V8..but the cars only weighed in at 1200 odd kilos.... so who knows !?? the Rover 3.5Ltr V8's didn't do too badly on the Mount (in latter years).. so perhaps it would have gone OK !?? Sadly... we will never know. I personally believe that what has helped to create what we now more widely term as "muscle cars".. was the on track performances of these cars... and especially at Bathurst. Though not all of the later production car versions did actually race around "The Mount"... if their spiritual ancestry can be traced back to these fore-runers that did... then it only adds to their credence (in some way). On the flip side.... if you have ever recently had the chance to jump back into an old 60-70's car for a drive... You probably realise fairly quickly, that it doesn't require much "muscle" anymore, to drive your modern day car... and wondered "how the hell did we put up with driving something that requires so much effort.. everyday !?" Perhaps this is the one thing that's more true to the core of what defines a "Muscle car" !?? Not so much, how much muscle it has.... but how much muscle you needed to drive it hard and keep it under control !?? (or maybe the two combined !??) Anyways.. just food for thought.... Dhru
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
07-12-2013, 11:41 AM | #108 | ||
For those interested... here's a few pics of the various P76's (All factory V8s)
The only Wagon... and a Force 7V Coupe (more a hatch back)... and the (home made) Ute... and the Targa Florio... Blue... and green (2nd car from front)..
07-12-2013, 11:26 PM | #109 | ||
Awesome photos of the P76...a car that deserved a far better fate than it ended up with. Shame Leyland went down the tubes and seemed to have the same "workmanship" problems that the parent company in England underwent.
Family friends of ours had a yellow one exactly like the one in the right side of the bottom picture, except it had the steel wheels and hubcaps. It was a V8 manual, and was an amazing car to drive. Unfortunately it got written off in a crash. Last edited by 2011G6E; 07-12-2013 at 11:47 PM. |
08-12-2013, 09:00 AM | #110 | ||
Great pictures of the Leyland P76. Thank you for putting a smile on my face. Many memories.
08-12-2013, 09:47 AM | #111 | ||
The body style actually suits the ute well.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
08-12-2013, 10:08 AM | #112 | ||
EBs and BFs etc being described as Musclescars.....
FKNLOL Musclecars are 60s and 70's built fullstop. and its not just any old car with a V8. List is simple GTs GTRs, Chev powered Monaros, R/Ts, SL/Rs. |
08-12-2013, 10:47 AM | #113 | ||
In your opinion BUT not according to the people at Australian Muscle Car magazine. Maybe you should get a job there and straighten them out
08-12-2013, 11:31 AM | #114 | |||
go, stop, turn, heater and aircon that works new muscle is cool muscle now go sail your boat off the edge of the world |
3 users like this post: |
08-12-2013, 11:42 AM | #115 | |||
How people's minds change as cars age just as it probably will with the modern muscle cars. Last edited by 5.8; 08-12-2013 at 11:47 AM. |
08-12-2013, 11:55 AM | #116 | ||
I personally dont want to get bogged down debating if we can call the more modern iron muscle cars or not........however i do think the Bathurst homologation specials from all 3 Au manufacturers made during the Series Production era of the 60s and 70s are deserving of being called 'Super Cars' instead of 'Muscle Cars'
Cheers Mick |
08-12-2013, 01:43 PM | #117 | |||
A poof's car... |
08-12-2013, 01:54 PM | #118 | |||
Even the fact they the coined the Landau as the rarest Aust muscle car underpins the fact they have no idea. |
08-12-2013, 02:16 PM | #119 | ||
Oo\===/oO
So muscle cars dont stop and turn? Looks like the phase 3 aint no muscle car...
08-12-2013, 02:22 PM | #120 | ||
