Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 30-08-2013, 01:27 AM   #91
EGOBFXR6
Default Re: Slotted disc rotor and pad sale.
Hi Matt,
This has been a really informative thread - Thanks for all the good advice
I'm looking to replace the rotors and pads on my FG F6 probably within the next 5,000-8,000km's and would like to ask a quick question. I have the 6/4 brembo set-up so I believe the rotors are 355mm/330mm.
I was thinking about using slotted T3's and was undecided about the pads. I am after a pad with lower dust than the OEM pads, reasonable life-span and which bite hard from the get-go.
Would the project MU NS pads all around be my best option? Any idea of the kit price posted to 6007, Perth - WA
Thanks Matt. Appreciate your time.
EGOBFXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2013, 08:53 AM   #92
2003BAZAQ365
Rookie ***ifier
Hi Matt
I'm looking to upgrade my pads and rotors to the front and rear of my BA XR6 sedan. At the moment I just have the stock pads and rotors but want to be able to fix the new pads and rotors as replacements without having to alter or buy extra brackets to fix them in. Rarely sees any track time just general speedy driving. What would you suggest?
Lachlan
2003BAZAQ365 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2013, 10:47 AM   #93
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by EGOBFXR6 View Post
Hi Matt,
Thankyou. The DBA T3 rotors would be my choice for sure and the PMU pads would be close to what you want although it is hard to get that perfect pad. The Hawk performance ceramic pads are better for low dust and low rotor wear but on both pads your request for " bite hard from get-go" is comprimised a little as we have found any pad that is low dust low rotor wearing will lose a little initial bite.
We could supply and send 4 rotors and 2 sets of pads for the 6/4 combo for about $1650. We may be able to reduce the cost a little if we can send from the WA warehouse.
Originally Posted by 2003BAZAQ365
Hi Matt
Lachlan
Lachlan we can do this with DBA T3 slotted rotors and DS Performance pads and you qill stop far better and this will cost about $900 but we can also go to the DBA T2 slotted rotors and Bremb brand pads for about $560 so there are some affordable packages there. Freight is extra.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 30-08-2013, 01:20 PM   #94
goose1000
BA Falcon
Hey Matt, just wanted to confirm that FG Falcon has 298mm rotor as standard
Cheers.
goose1000 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2013, 01:55 PM   #95
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Cheers.
FG falcon std model has 298mm not xR6T or XR8 fpv ETC
MATTHEW PEARCE
Phone 02 9609 1101
Old 30-08-2013, 02:44 PM   #96
EGOBFXR6
Hi Matt,
Thanks for the fast response. I really need that initial pad bite as I live next to a school, right next to a main road, and only a couple of minutes from the freeway. I just don't have the time for them to warm up before they bite...
I guess I'll have to live with a bit of dust - Hard biting pads are more important...
Do the T3's and PMU pads have similar life to OEM Brembo pads/rotors if driven the same way?
I'll be in touch again soon when I need to purchase the kit.
Thanks!
Old 30-08-2013, 06:01 PM   #97
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Hi Matt,
Thanks!
The lifespan on pad and rotor combinations differ and you can't say how long they last but the wear rate is pretty good.
You mentioned you didn't want to wait for the pads to warm before they bit which i can undersatnd but "initial bite" and warming up pads is different as they generally have different material compositions in them. High initial bite pads will generally dust up and wear the rotors harder but just because a pad doesn't have high initial bite it doesn't mean it has to warm up to work well. The Brembo aftermarket pads are close to what you want but are yet to make a pad in your shape so keep in touch as it may be soon.
MATTHEW PEARCE
Phone 02 9609 1101
Old 09-09-2013, 02:31 PM   #98
T2 TE50
Hi Matt,
Can you please send an estimate for front and rear disc rotors for AU 11 TE50 non brembo non premium set up
interested in DBA T3 or T2
Also price for recommended pads for rotors
Postage Perth W.A
Cheers Rob
T2 TE50 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2013, 03:09 PM   #99
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by T2 TE50 View Post
Hi Matt,
Postage Perth W.A
Cheers Rob
The TE50 i thought had atleast the twin piston 330mm kit with a grey caliper but are you saying you have bog stock 287mm front discs?
MATTHEW PEARCE
Phone 02 9609 1101
Old 09-09-2013, 07:09 PM   #100
T2 TE50
Hi Matt
You are correct twin piston 330 kit with the grey caliper, I was under the impression the premium brakes had the tickford logo on the caliper?
Old 10-09-2013, 09:47 AM   #101
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Hi Matt
I thought that (logo) as well but have seen some grey calipers with 330mm rotors that haven't had it.
I reckon you will pay around $950 delivered to perth for the front and rear T3 slotted rotors and Remsa brake pads.
MATTHEW PEARCE
Phone 02 9609 1101
Old 11-09-2013, 05:24 PM   #102
T2 TE50
Hi Matt
Whats the price for the T2 rotors set with pads
Old 11-09-2013, 05:52 PM   #103
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Hi Matt
No T2's made sorry and they have no T3 stock either. The only DBA rotor is a DBA 4000 with the factory eliptical slot for the same price as the T3.
RDA is the only other option
MATTHEW PEARCE
Phone 02 9609 1101
Old 11-09-2013, 09:08 PM   #104
xringer
Thumbs up Re: Slotted disc rotor and pad sale.
Hi Matthew,
I would just like to say a very BIG thank you for your fantastic customer service and expert advice in helping me with the upgrade of my BA xr8 ute brakes to 325mm fronts/328mm rears.All the rotors/calipers/pads/seal kits /braided lines were EXTREMLEY good prices and all turned up today in Brisbane.The gloss black powder coating on the calipers looks great and is an excellent job.Thank you for taking the time to explain the pros and cons of the questions I asked.I was very impressed by your expertise on the calipers/rotors/pads for my ute and how I drive it.
I will recommend you to anybody, so if anyone needs anything to do with brakes,please give Matthew a ring at RACE BRAKES SYDNEY.Thanks again Dave/Xringer.
xringer is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2013, 10:34 AM   #105
T2 TE50
Hi Matt
I had checked the front disc as I was the same opinion that the TE,s had the larger discs but to my surprise I have the bog stock which is very disappointing as I was not too happy about the braking on my car,now I know why.
My apologies for stuffing you around,
I might have to re think options as I still have some wear left on pads and rotors
Old 14-09-2013, 12:07 PM   #106
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Hi Matt
No worries when your ready let me know
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-09-2013, 07:16 PM   #107
tbf001
Hi Matt
Chasing some DBA T2 slotted rotors to suit std BFII wagon front and rear, also pads to suit options please.
We carry a bit of weight as the norm and tow quite frequently if that's makes any difference.
Any advantage of braided lines to a std setup?
Postage to 3804 please.
Regards
Mick
tbf001 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2013, 11:16 AM   #108
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by tbf001 View Post
Hi Matt
Regards
Mick
Hi Mick we can supply the DBA T2 slotted and some Brembo brake pads that are very good and low dust with freight to 3804 for $620 or if you would like the Remsa pads we have on special then we can do this for $560 delivered thanks mate. Braided lines are better than rubber for sure as they do not flex or split like rubber ones and will cost you $280 a set extra thanks for all 4.
MATTHEW PEARCE
Phone 02 9609 1101
Old 24-09-2013, 01:58 PM   #109
Bulletime
Hey mate, after a quote on two bottles of ap racing 5.1 brake fluid shipped to 2611.
Does it come in any bigger quantities?
Also I've had half a bottle sitting around for 12 months, would it be any good?
Cheers.
Bulletime is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2013, 02:21 PM   #110
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Cheers.
$55.00 delivered only 500ml but cheaper by the case lol. The fluid may be ok if it had the lid on tight and stored in a dry area.
MATTHEW PEARCE
Phone 02 9609 1101
Old 24-09-2013, 03:40 PM   #111
Bulletime
Lol thanks pm sent.
Out of curiosity how much is a case and how much do u get?
Old 25-09-2013, 09:34 PM   #112
Idiotbox
People there no damm good
Idiotbox's Avatar
I am after a price on DBA rotors & Bendix Ultimate pads to suit 2006 Ford BF MKII XR6 Sedan non turbo
DBA 4504 Front T3 Pair
DBA 4505 Rear T3 Pair
DB 1473 ULT Front Pair
DB 1675 ULT Rear Pair
+ Shipping to 4500 in Brisbane
Could you also recommend someone to fit them locally & estimate of cost to fit?
Thanks
Idiotbox is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2013, 08:56 AM   #113
2003BAZAQ365
Rookie ***ifier
Hi Matt
Am I able to purchase the front t2 rotors and Brembo pads off you this week?
Lachlan
Old 26-09-2013, 10:00 AM   #114
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by 2003BAZAQ365 View Post
Hi Matt
Lachlan
Lachlan that was for the std BA XR6 set up and the T2 rotors you want are slotted? Yes i have this stock here is it pick up or being freighted?
DB 1675 ULT Rear Pair - These will be DB1376 pads with the non turbo BF
Thanks
Just confirming it is a BF XR6 non turbo with std rear brakes as the rear pad number you have listed is for the larger rear vented disc but the rotor number is the std size .
To supply the above items with freight is $880 or if you wanted Ferodo DS performance front pads and Ferodo Formula rears which are both equivalent if not better than the Ultimates it would be $870. Fitting price we charge would be $240 so around that price but i have no one locally and really any decent mechanic can do this job.
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-09-2013, 01:17 PM   #115
2003BAZAQ365
Rookie ***ifier
Yeah it was to replace the standard BA XR6 system with the slotted rotors and performance pads. Do you also sell the brembo caliper covers or should i source them elsewhere? How much extra is the freight to braemar NSW?
Lachlan
Old 26-09-2013, 01:48 PM   #116
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Lachlan
$50 for freight about 40 or so kilo's and we don't do the covers sorry mate.
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-09-2013, 04:27 PM   #117
2003BAZAQ365
Rookie ***ifier
I might be able to pick them up tomorrow hopefully if not ill have them delivered. How's much just for the front rotors and pads?
Old 26-09-2013, 05:21 PM   #118
FLOORED
Race Brakes Sydney
FLOORED's Avatar
About $280 pick up for front T2 slotted and Brembo DB1473 pads but let me know as i will hold them for you.
MATTHEW PEARCE
Phone 02 9609 1101
Old 27-09-2013, 12:33 AM   #119
2003BAZAQ365
Rookie ***ifier
Yeah Matt my dad will be there tomorrow to pick them up, not sure exactly what time. His name is Geoff and ill also let him know what I'm after. Cheers look forward to putting it in on Saturday.
Thanks
Lachlan.
Old 07-11-2013, 10:30 PM   #120
Bulletime
Hey after a quote on QFM A1RM for standard fg xr6t fronts, shipped to 2611.
Cheers,
