Old 18-04-2007, 07:50 PM   #61
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Coil Pack arrived today. Very nice (new ex Ford). Will fit it on the weekend, will let you know how I go. If that fails I will look at fuel reg and pump. Then, suicide will be considered.
Please don't take the 'suicide' pun seriously! Suicide is bad, mmkay.
How did you get on Russ?
Cheers,
Mike
Old 18-04-2007, 10:03 PM   #62
hfcrussell
hfcrussell's Avatar
OK,
Got the car back today. Much better than before.
I have to say yes it was the fuel pump....
They changed pump and sender and some seals.
Was NOT cheap though, not much change from $500.00.
Just happy to have it fixed.
Russell.
1973 XAGT Coupe T B T B , , 1974 XBGT Sedan T B B M, 2011 Territory Titanium TDCi, 2014 Ford Ranger XLS 4x4 Dual cab 3.2TD 6 speed auto, 1974 XBGS Coupe Y L P 2
hfcrussell is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2007, 06:53 AM   #63
MNM96
MNM96's Avatar
Originally Posted by hfcrussell
OK,
Russell.
Good news, back to her old self again! Bring a smile? I would happily spend $500 to get mine right.
Cheers,
Mike
Old 09-01-2024, 11:23 AM   #64
david lee
Default Re: AU II hard to start cold.
i have an au xr6 series 3 that wont start in the morning at first turn of the key 2nd turn will start will start first time all day. the mech cleaned the throttle body because before of this problem it was hesitating at stop. new plugs didnt fix the problem and he said leads-coils good. still same problem. he said fill the tank with 98 and use a bottle of injector cleaner. well it seems to have fixed that problem. now i have the hard starting problem cold
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2024, 07:11 PM   #65
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Fuel filter?
