06-06-2007, 10:12 PM | #61 | ||
Jack will probably cry when he see's this!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
06-06-2007, 10:13 PM | #62 | ||
BA Mk2 XR6 Turbo
i felt bad posting the image. but it stops others claiming ownership
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter |
06-06-2007, 10:28 PM | #63 | |||
Sad to see.
Who would've ever thought it would end up like this?
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
06-06-2007, 10:34 PM | #64 | ||
BA Mk2 XR6 Turbo
heres the engine the day i took it out of the car.
btw the tyre was only a quick fix until i shifted some **** around i put here on car jacks x 3....1 on each engine mount and one support trans. since then the engine has had many cleans and is almost ready to go other than intake manifold. rocker cover is now same as body colour (red). she needs 1 more good clean before going into my car. she has had a few flushes with oil and the rust killing stuff used inside engines that havent been turned over in a while and has had a 2min no compression cranking test which it passed with flying colours. (few oil pump still works) meaning all plugs out and no manifolds and tranny in park and 1 x working car and 1 x set of jumper leads onto starter motor. shes as quiet as a mouse which is pretty good since i dont think its been turned over in 2yrs. (i think) and oil flows perfectly (few) before and after seen below brad
06-06-2007, 10:34 PM | #65 | ||
Never late with a V8
Its amazing what can happen to what was once someones pride and joy... My old EA (Budget Built) ended up getting crushed after i was rid of it
My Rides (Daily)2004 Explorer V8 Limited (Project/Cruiser)XE Fairmont Ghia- 351 Cleveland, Toploader (Work) 2014 Kenworth K200 Aerodyne (Classic) 1969 Mini K, 1340, twin SU's The beginning is near!!! Body by Ford. Soul by NudgE
06-06-2007, 10:40 PM | #66 | ||
BA Mk2 XR6 Turbo
it took me 2 weeks and about 6 different peoples advice including an engineer before deciding to not go with the original plan of doing up the white ea.
main reasons.... k-frame - cut away trans - required custom brackets as had been auto-man-auto-4speed auto body - bonnet was bent badly dash - not present - not that its hard to put in wiring - 3 speed....needs to be 4 speed diff - untested so another variable in an already big enough problem brakes - not used in maybe 2yrs - again another variable car history - not really known basicly too many variables. ive known my car history since it was 6 weeks old....its been owned by a direct family member since it was owned by ford rep. sad but had to be done. brad
06-06-2007, 10:42 PM | #67 | |||
windsor user
06-06-2007, 11:06 PM | #68 | ||
The 'Stihl' Man
Its not really sad, it was an EA, and you did the right thing by you and thats what counts.
If someone brought my EL and then wrapped it around a pole then thats their issue not mine, its just a car.
07-06-2007, 02:16 AM | #69 | |||
Does Steve have a car?
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
07-06-2007, 09:04 AM | #70 | |||
That picture hurts :( Sundeep |
07-06-2007, 09:23 AM | #71 | |||
Team Urinal Cake Racing
07-06-2007, 09:30 AM | #72 | ||
At least it got sold to an enthusiastic E-Series member who has Jack's EA living on organ-donor style.
Maybe someone should make an RIP thread (a pics/bio thread that is) for all the great/notable E-Series cars previously owned by prominent members which have either been stacked or parted out or sold-then-trashed or returned back to stock? |
07-06-2007, 09:32 AM | #73 | |||
07-06-2007, 09:46 AM | #74 | ||
BA Mk2 XR6 Turbo
if you all gonna get soppy......its memory will live on in the new and improved EA2 and it will be loved forever.
now that thats out of the way..... i have started making a build thread for my ea2 and once im happy with it ill post it in the build section. as for the dead thread thats not a bad idea. kinda like build section but opposite. seen as this car started the club how about it be the 1st dead thread? ill show that 1 car can give life to many other cars (parts trading) hehe btw. theres no better way to learn that stripping a car. ive learnt soo much....i still need to learn a hell of a lot more but gotta start somewhere. my dad left for work on sunday morning with the car intact and only taking 1 car spot and when he got home sunday night 50% of the car was stripped and struine all over the garage and driveway....whilest he wasnt impressed at the mess, he was impressed how quick they come apart. ive kept everything inc nuts n bolts bar the bare min to keep car together....ie 1 bolt holding bonnet on, 1 bolt holding doors.....gotta love electrical tape...wood screws holding front wheels on. brad
07-06-2007, 10:03 AM | #75 | ||
Maybe an AMC style "MIA" thread :P In Jack's old EA's case we've got our first result, we could post pics of the EA in its prime and the shots of it now (from your above posts), state what was done to the EA, its significance, etc etc.
Then move on to other cars like -jjM-'s EB (although most of us here are aware of the outcome in this case), etc |
07-06-2007, 10:30 AM | #76 | |||
Sundeep |
07-06-2007, 05:08 PM | #77 | |||
The 'Stihl' Man
I get what you mean, but it could have been worse.
07-06-2007, 06:35 PM | #78 | |||
Tuned @ Pitlane Frankston
I still remember Karl, me, Wayne and Jack at his house, looking at his Mitsubishi Garret truck turbo back in the day.. Could've been a nice car, but that's what ya get i spose, when time and effort gets the better of ya..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
07-06-2007, 06:46 PM | #79 | |||
The 'Stihl' Man
07-06-2007, 07:17 PM | #80 | |||
Also i don't quite understand what you are asking me to do?? |
07-06-2007, 07:50 PM | #81 | ||
Well, my interpretation of your post suggested a general disdain for EAs.
Let me reword my intial post: "Why don't you make for a Knight Rider love interest and **** Hoff?" But, since your initial post was merely in jest, I'll take back my first response to you, and the above sentence is said in good nature :P |
07-06-2007, 08:06 PM | #82 | |||
Parts bin special
On topic, I never saw this car as I joined up a bit later on, but I certainly understand the significance of it. It's a real shame to see it in that shape.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
08-06-2007, 02:22 PM | #83 | |||
Former E-Series Member
G'day all,
Interesting to know the fate of the EA, not worth getting emotional over though - it's the experience that counts, and the Club it spawned which is going strong as always. Good job with the motor BJ, I knew it would be a nice powerplant when up and running. Quote:
08-06-2007, 02:27 PM | #84 | ||
PM me if you want
It's a shame to see it crushed, and the repairs are not that all that hard really (not much different to what I have doen to my car), the biggest thing against it was getting a road worthy from an un-registered state.
08-06-2007, 02:36 PM | #85 | ||
BA Mk2 XR6 Turbo
thanks jack. yeah im hoping itll be a wicked power plant when finally installed.
no matter wether you a ford or holden fan, the ford I6 is one sexy looking motor. now that its body coloured on the rocker, clean silver on the head and black on the bottom end it looks like one mighty beast (will post pic over the weekend) everyone whos sees the block comments on how good/powerfull the I6 looks. as my engineer said....its not the hours of labor required by you brad, nor is it the money required by you brad.....its the idiots at vicroads who will give you the hard time. b.t.w i wont mention the engineers name becuase of his lovely comment. hehe. he said if it was registered it would be a different story but unregistered considering i already have a registered ea wasnt worth the extra effort and $$$. offers for the shell went far n wide. but no body was interested so it met its match with the crusher. brad
09-06-2007, 12:59 PM | #86 | ||
Lol @ Jacks Avatar :P
10-06-2007, 10:39 AM | #87 | ||
eec tweaker
the hardest part of the repairs to jacks EA would have been refitting a new k-frame. i would have used a modified sump.
I looked into this but dont have the space nor time these days. I think its pretty sad to see it go. it was a very low KM ea in excellent condition. |
10-06-2007, 11:05 AM | #88 | |||
10-06-2007, 12:09 PM | #89 | ||
windsor user
AFAIK the only thing that happened with the k frame was the front crosss bar cut out for clearance........would have taken nothing at all to weld in a new bar at the front of it and hit it with some paint....
10-06-2007, 12:11 PM | #90 | |||
