Old 21-08-2006, 03:10 PM   #61
cringe
cringe's Avatar
Cool
ordered a pin kit today.. they reckon i'll have it tomorrow.
gave up on making my own.
'08 FG XR8 Ute / Nitro / Manual / XR Sports Pack.
cringe is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 06:09 PM   #62
falconkid
On here daily
i ordered one today aswell, they said i'll have it tomorrow.
JIM
falconkid is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 06:09 PM   #63
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Good luck guys Pics of the install would be good!
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 06:32 PM   #64
falconkid
On here daily
the two sensors on the T5 are reverse switch and neutral switch, i know what the reverse switch does, but what does the neutral switch do.
JIM
Old 21-08-2006, 06:51 PM   #65
efgiar
rofl copter
efgiar's Avatar
the top switch on the gear box is ur neutral switch, it stop u from starting ur car if it is in gear. i disabled mine by bridging the wires. mal wood are pretty good with delivery, i ordered mine at 3ish oclock and got it first thing next morning.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 07:33 PM   #66
Christiaan
Christiaan's Avatar
the neutral switch is there to stop the car from being started in gear without the clutch switch enabled.
Basically, if the car is in gear, with the clutch in, it will start.
If it's in gear, without the clutch in, it won't start.
Old 21-08-2006, 08:22 PM   #67
efgiar
rofl copter
efgiar's Avatar
Originally Posted by cringe
You can still see machining marks.
Clutch looks brand new!
They weren't lying when they said the clutch was recently replaced.
nice. just clutch cable to remove now, and then can wheel the beast out 'o the shed. :evil_laug
that clutch looks likes it been thru a bit of heat? like red hot heat from when they tried to do a burnout and just burnt the clutch... maybe? lol
GQ patrol.
thats all
Old 21-08-2006, 08:30 PM   #68
kyro_02
V8 wannaabeee
kyro_02's Avatar
Originally Posted by SupahStah
Hypocritical paracite.
Supahstah
OHLOL
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 12:35 AM   #69
falconkid
On here daily
which way does the clutch plate face, does the raise splined section face the flywheel?
JIM
Old 22-08-2006, 12:19 PM   #70
cringe
cringe's Avatar
umm.. the way it is in my photo is the way it goes, i'll have a look when i get home..
ps. i got my clutch pin kit this morning.. man they don't mess around with the shipping.
Old 22-08-2006, 12:37 PM   #71
falconkid
On here daily
i havent got the pin kit yet...
still waiting
thats the way i put the plate in.
JIM
Old 22-08-2006, 02:11 PM   #72
Christiaan
Christiaan's Avatar
Yeah mate, it's good. Mal wood are a top operation. See how well the pin is designed? You could make your own one, but it wouldn't be as good as that one. Plus it'd take you longer and probably end up being more expensive in time.
Hope it all goes in alright. It's worth it in the end. I won't forget the feeling i had when i had a friction point with the cart, and it moved. It was aweeeeeeeeeesome!
Old 22-08-2006, 05:38 PM   #73
cringe
cringe's Avatar
Cool pin kit installed!
ok, kit installed, took all of 15 minutes.. :1syellow1
pedal matches with auto pedal perfectly.. although i have the manual brake pedal, might as well change it, but to get to clip on brake pin i need to unbolt a circuit box of some sort.. i'll do this later tonight.
but yeah the pin kit is well made, shipped quickly and fits perfectly.. really simple install and feels strong.
will fire up camera phone after and get a pic or two.. :1syellow1
also whacked the clutch cable in and hooked it up to the pedal, just looped and cable tied it in the engine bay for now, so i'm ready for the gearbox next.. just waiting for a shifter boot that i got on ebay.. (bay ford?).. so that when i install it all it's a nice finish.
Old 22-08-2006, 06:36 PM   #74
RavenLS1
So you say the Auto ECU is the same as the manual ECU ??
I do not see how it can be 100% fine if your running an auto ecu on a manual box??
no, i did not say anywhere in my post that they are exactly the same, what i did say is that i run an auto comp with no problems, IE revs hanging.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 11:43 PM   #75
falconkid
On here daily
my conversion is finished, the only thing that gave me the s@#ts was the dicky little clip on the clutch pedal that holds the cable, what a piece of c^&p they are. finally did some home mods to it and it worked a treat. i love the 5 speed, i have 3.91 diff gears too!!! great fun
JIM
Old 23-08-2006, 04:25 PM   #76
cringe
cringe's Avatar
i got my shifter boot off ebay today. it clips right in where the auto section clips in.. this is gonna be a sweet idea swapping this manual in once it's done.. just have to pick up spigot from autobarn tonight.. then i think i have everything.. except for the resistor for the temp sensor wiring..
Old 23-08-2006, 04:47 PM   #77
cringe
cringe's Avatar
Cool cupla foaters!
here's my new shifter boot.
here's the malwood clutch pin kit.
here's how my clutch pedal sits next to my auto brake pedal (to be grinder'd).
: oh yeah, my amp power wire ran through the clutch hole.. dammit! out:
more stuff 'bout this at www.cold7.com it:
Old 23-08-2006, 04:56 PM   #78
Professor Farnsworth
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
you people are wizards. i'd love to convert my 5 litre EL Ghia to manual.. but i've got a chronic knee injury from work :( I miss manuals a lot.
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 07:17 PM   #79
efgiar
rofl copter
efgiar's Avatar
you dont need to, its a bit of a squeeze but ive never unbolted the fuse box to do it, even with the abs module up there its even tighter but still can be done
GQ patrol.
thats all
Old 23-08-2006, 09:41 PM   #80
BLSTIC
man, that is identical to the one i made. I just had a longer thread and a cone washer. No reason i couldnt fit a spacer on it though, i just didnt have the time.
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 09:47 PM   #81
Christiaan
Christiaan's Avatar
You don't need to change the brake pedal. Just hacksaw/airsaw the auto one.
Old 23-08-2006, 10:42 PM   #82
cringe
cringe's Avatar
i got in there tonight and got the clip off the end of the brake pin, but the bastard wouldn't move.. dammit.. have replaced the clip again..
efgiar, once you get the clip off yours is the pin easy to slide out? or super tight?
Old 23-08-2006, 10:50 PM   #83
Christiaan
Christiaan's Avatar
The brake pedal is one of the most awful things to change. I rate it in the top 10 "**** jobs i hate performing on a falcon", along with parcel shelf work, and changing diffs.
Just airsaw/hack saw the goddam brake pedal!
Old 23-08-2006, 11:48 PM   #84
MRE-40L
there once was a
MRE-40L's Avatar
FOr the ECU Auto trick
place a 1.2kOmh resistor small black plug
and on the large white plug ,place a 7.2kOmh resistor
black - white trace
yellow - no trace
hope fully this will help
MRE-40L is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 06:43 PM   #85
efgiar
rofl copter
efgiar's Avatar
no it will be very tight, would be like that from factory, i used a hammer in there but had to move the abs module to do it, try getting a socket on it (just to sit on it not to undo anything) and hit the socket with a hammer so that the socket lets you hit it without hitting the actual pedal box if u kno what i mean. its not THAT easy but its so much quicker then replacing the pedal box
OR u can do what has been mentioned and cut the pedal off on 1 side or grab the manual one and compare it to ur auto one for were to cut it, IIRC they are very similar arm lengths/bends just gotta know were to cut the pedal, thats even easier, but use a hacksaw or a airsaw not a grinder because it will stuff ur carpet.
GQ patrol.
thats all
Old 24-08-2006, 10:49 PM   #86
cringe
cringe's Avatar
got spigot bearing tonight..
i love those autobarn freaks.. they reckon a thrust bearing and a spigot bearing are the same thing.. lol
Old 24-08-2006, 11:40 PM   #87
efgiar
rofl copter
efgiar's Avatar
lol stick to car audio!
GQ patrol.
thats all
Old 24-08-2006, 11:47 PM   #88
RG
Back to Le Frenchy
RG's Avatar
Autobarn, car audio wtf. They told my brother in law that he couldn't run a sub off a 2ch amp. : :
Also try to make sure that you have plenty of time to do the conversion and that you get everything right, it's no fun continually getting back under your car to fix stuff ups, especially when they are someone else's stuff ups.
Old 26-08-2006, 04:13 PM   #89
cringe
cringe's Avatar
auto is out now.... pics soon
Old 27-08-2006, 09:12 AM   #90
cringe
cringe's Avatar
Cool box swap
roomy workshop (NOT!)
shrunken brake pedal.
The manual box is in.. but i was too tired last night for any photos..
gotta go get some oil and an exhaust gasket this morning, then can test drive it.
more about this stuff at www.cold7.com
