Old 15-08-2011, 06:02 PM   #61
HP-0351
1409hp 1190lb.ft 18psi...
Default Re: Raging Rhino XYGT @ WSID!
nice work
The Daily 2003 BA GT Falcon http://fordforums.com.au/showthread.php?t=11367185
The Weekender: 1971 Twin Turbo XY Falcon
http://fordforums.com.au/showthread....=twin+turbo+xy
HP-0351 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2011, 08:12 AM   #62
XT302
10.704@128.77mph at yesterdays test and tune.... ALL by a owner built 393 with dual plane airgap fitted
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2011, 11:02 AM   #63
XT302
Old 10-09-2011, 11:21 PM   #64
THE CADBURY KID
My mate run a 11.7 in his xd with a 550 fwhp 393, his is auto though.
Maybe your motor makes more than 500 hp
THE CADBURY KID is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2011, 10:01 AM   #65
XT302
It has been engined dynoed, made a tad more than 500 I say a GREAT effort considering it has a dual plane airgap fitted
Old 12-09-2011, 02:15 PM   #66
THE CADBURY KID
that question was meant for the op.
Old 03-10-2011, 10:03 AM   #67
XT302
I understand who your post was aimed at, I was assisting your argument in a round about way, no harm intended to either just getting involved in the discussion.
PS: TO RECAP ON THREAD (SAVES ANYONE READING IT ALL, ALTHOUTH IT DOES MAKE FOR SOME GOOD READING)THE OP IS NOT THE OWNER AND HAS ABSOLUTELY NOTHING TO DO WITH CARS CURRENT PERFORMANCE, THIS HAS BEEN THE CASE SINCE THE ORIGINAL ENGINE GRENADED.
Old 10-10-2011, 12:57 AM   #68
BOTTLEDUP
What mph? If its a genuine 550 flywheel HP it should be running 11 flat or better in an XD... On slicks of course.
Great effort for a dual plane 2V Clevo, manual too!
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2011, 09:53 AM   #69
xdclevo
The Fun Mobile
xdclevo's Avatar
Yep, your mate is missing near a second off his ET.
Mine is in the 550HP region and runs 10.7's in an XD full weight.
Good old 2V power but. haha
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2011, 04:43 PM   #70
Stefan
Stefan's Avatar
Is it not the exact same engine combo as put together by the OP, just rebuilt by the owner? What has been changed?
The owner told me last time I saw him at the track that it was still the same combo that Steve put together. Seems like a real nice genuine bloke so I'm certain he wouldnt lie to me.
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2011, 06:59 AM   #71
XT302
You are correct owner is a nice guy and I am pretty sure he wouldn't lie.
BUT like the OP he may not tell you everything...
I can say this if it was the exact same as when OP built it, shouldn't it have blown up after a few thousand kms an still be running 11.5@122 not what it is now?
Old 16-11-2011, 09:57 PM   #72
Stefan
Stefan's Avatar
OK, the engine using mostly the same parts, still makes the same power ie 500 odd horsepower. Must be a coincidence I guess.
You don't thing going from 3.25s to 3.9s, fitting a jerrico and practice would make any difference in the ET?
Anyway runs real nice, well done to Ante..
Old 16-11-2011, 10:27 PM   #73
XT302
NOW it is MOSTLY same parts?....there are some photos that indicate PLENTY of different parts were needed due to the catastrophic grenading of the OP built engine
As for 500 odd horsepower engine dyno says your odd is a BIG number, also now there is a difference in RWHP...
3.25 to 3.9 was a difference, some agree different gearboxes use up different amounts of power there was a difference in gearbox change, so for those two changes and the practice there was a ET and MPH difference.
So what is the theory of the multiple increases in MPH?
There would be some that would agree increase in MPH is generally a indicator of a increase in HP?
Old 16-11-2011, 10:36 PM   #74
dieseltrain79
Also Box probably sucking up less power so getting more to the ground .
You can have a 500hp engine using different gearboxes getting different power to the grounds due to each one sucking up " X " amount of HP doing so .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2011, 10:40 PM   #75
XT302
So the first time back at track with the new box shows the difference the Jericho made (gears had already been changed) there was increase but from a number of runs very consistent, if you watch this car both car and driver are SUPER CONSISTENT. So changes to vehicle can be easily guaged.
Where does all the other multiple increases in MPH come from? not being smart, as I know where they have come from, just going back to the original question by Stefan
"Is it not the exact same engine combo as put together by the OP, just rebuilt by the owner"
Old 16-11-2011, 10:49 PM   #76
XT302
Can anyone tell me a car that weighs 1595kgs what kind of HP is needed for 122mph and 128.77mph?
Thanks
Old 16-11-2011, 11:28 PM   #77
Stefan
Stefan's Avatar
Well you're the guy that said it still has 500HP a few posts ago, does it or doesn't it? Either you don't actually know or you're spinning BS.
I'm sure you can find a drag racing calculator on the net and can punch in some numbers.
I'll leave you to it, obviously no point having a discussion with someone that is unable to contribute anything factual.
Old 17-11-2011, 07:20 AM   #78
XT302
It has been engined dynoed, made a tad more than 500 ( and since that post rw dynoed)
Above is what I actually said.... Hasn't changed
You are right to a certain extent though, It's not my place to share any facts with you. I was just enjoying the discussion.
Anyway why you getting so upset, when the op said 500ish there was non of this hostility, hence my question about the HP then and now
Old 17-11-2011, 08:25 AM   #79
Stefan
Stefan's Avatar
Sweet, no hostility mate, just working it out.
Old 21-12-2011, 09:14 PM   #80
XT302
Just now new ET PB 10.703 , you little beauty
Old 27-12-2011, 06:55 PM   #81
HP-0351
That's a quick manually shifted genuine GT
Old 27-12-2011, 07:15 PM   #82
protd
TUFF FORDS
protd's Avatar
how much rwhp did it make on the dyno?? or is it all top secret? i'm sure telling the hp of the motor aint giving any secret info away..
my mates xf runs 128mph with 410rwhp on street radials
protd is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 07:38 PM   #83
protd
TUFF FORDS
protd's Avatar
is this car running a different engine again?
in the first page the owner says its a pavtek 393 gold stroker with 3v heads and duel plane intake, i'm a bit confussed is it the pavtek engine or a new owner built engine?? sorry if i missed something just trying to work out whats going on here..
Old 27-12-2011, 07:39 PM   #84
HP-0351
Don't know about the XY Lee re HP.
I know this Genuine GT run 10.51@129.98mph through a 4 spd on its first and only pass as it wasn't fitted with a cage and was asked to leave.
Full weight car incl AC, Sunroof and PS was functional during the pass lol. Thought it was tough and sorry for off topic.
http://cacklingpipes.com/081010_wsid...y01008_133.JPG
Old 27-12-2011, 07:53 PM   #85
HEMI POWER
N/A BOSS 390+
HEMI POWER's Avatar
Originally Posted by HP-0351
Don't know about the XY but I know this Genuine GT run 10.51@129.98mph through a 4 spd on its first and only pass as it wasn't fitted with a cage and was asked to leave.
Love it.Nice looking car that.
WOOOOOOOOOO
FPV GT 03 /341 RWKW OF N/A POWER.
XB GT 73 /OLD FORD MUSCLE
ALL AUSSIE MUSCLE
HEMI POWER is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 08:44 PM   #86
XT302
Help you with the facts, 10.56@129.9mph and far from being it's first pass and if I find the photos of the engine on that pass no a/c etc fitted. TAKING NOTHING away from Adam XBGT, ran HARD/FAST many a time prior to this fitted as Roy as stated ac etc, but for this pass was set up to move
http://www.falcongtclubnsw.com/forum...php?f=1&t=5151
For those that cannot see the above llink a copy of what I posted/thread started at the time
"For those that don't know Adam (Detroit Customs) ran a 10.56@129.9mph XBGT four door, with sunroof on Friday night through a manual, although not a toploader as that called it quits at the WSID drag day still HUGELY IMPRESSIVE.
Possibly could have gone faster with clutch adjustment, BUT were kindly asked to leave WSID as car had no cage etc.
Although ET droppped there was not much of an improvement anywhere else ( I think it actaully 60ft quicker and mph higher with toppie) but Adam and Sash can correct me if I am wrong.
Anyway BIG CONGRATULATIONS to Adam and Sash and team from ANRACING.
JOB WELL DONE"
What you Roy posted at the time
"427ci small block
alloy heads ( i think they are Edelbrocks...cant remember at the moment)
11:1 comp
roller cam
Jericho box
4.88 gears
546hp at the rear wheels...i have seen the dyno sheet
full weight car with full trim, no glass panels etc
awesome effort by Sash from AN Racing"
Andreas correcting your post
"CHI 3V's, TFC, 950 HP!
Awsum!"
THE MACHINE, sadly been reported stolen
http://www.wolfpac.com.au/adam.htm
Old 27-12-2011, 08:48 PM   #87
XT302
Car has had 3 engines Lee
No1 engine built by OP grenaded No2 engine sourced from PAVTEK (still owned just occupying garage floor space )then the current engine was built by owner and has run what it has to date.
Old 27-12-2011, 08:56 PM   #88
XT302
To be honest I don't recall, was run up mainly to check fuel mixtures, luckily now a easier method is engaged for this.
XF auto? STOUT mph.
Old 27-12-2011, 08:57 PM   #89
protd
TUFF FORDS
protd's Avatar
thanks clears it up for me, i read topic 3 times and thought i was going mad
Old 27-12-2011, 09:03 PM   #90
XT302
I am looking forward to some updates on the XR, ps either AVIS (as you suggested) or straight white tinter gets my vote.
