#61 | |||
Rob
thanks for bumping this thread up. i bought a LS focus on the weekend for my inlaws and it seems to have this same problem. the other time i noticed almost the same sort of 'shunt' was at 100 - 110 in 4th. almost like a really noticeable lockup of the converter. not sure if its related at all. 20focus05 - you still at rowell and searle? its interesting you mention the TPS could be faulty. the one i bought, when you go to take off, has not much reaction to the first bit of accelerater travel and then suddenly you are off. can this be adjusted? are they 'fly by wire'? |
#62 | ||
I wanna XR5
Hey Prydey I have only just left them last week. I have a 15km drive now instead of 100
LS are drive by wire and I dont think TPS is adjustable. I have also now heard about the software updates which are fixing the problem. The only real problem we have seen with the focus is soloniod failures. we had one guy who had codes retrived and it says something like valvebody issue but all it is is one of the shift soloniods. he was qouted $2500 to replace valvebody, we did it for about $800 to replace soloniods, I also dismantled valvebody and replaced gaskets because the code that came up can relate to a gasket blowout. I have driven an auto LS and though the same about accel.
Great Wall X240. Bouncing around the APY Lands Ex Ford owner and member of this great site for ages. South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@* |
#63 | ||
Rob
cheers.
if left, can the 'shunt' get worse, or become a bigger issue. as you may be aware the car is my inlaws and i didn't mention it to them because i doubt they'd even notice. |
#64 | |||
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
#65 | |||
#66 | ||
I wanna XR5
These transmissions are the same as the mazda 323, protge, 3, 6. Ford call them a different name.
Remove pan remove filter replace filter replace pan with new gasket fill it up, sometimes they will have a buzz after a refill sounds like cavatation(have never found the cause) We over come this by over filling give it a short run then remove oil back to level. There are no adjustments required to bands, all preset. These Transmissions rarely have major issues, most problems we have seen are related to solonoids.
Great Wall X240. Bouncing around the APY Lands Ex Ford owner and member of this great site for ages. South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@* Last edited by 20focus05; 28-09-2010 at 06:23 PM. Reason: more info |
#67 | ||
Hi guys, I also have an auto LS Focus which seems to be have a few issues.
My focus mainly drives on the freeway, and recently, when I start to slow down or get off the freeway, it doesnt know what gear it wants to be in and usually hold onto 2nd. When it does eventually change gears it does make a clunking sound. Would anyone know what the issue might be? |
#68 | ||
If you have done 80,000 + klm check the CV joints in the drive shaft especially when slow cornering they make a noise if worn
