#61 | ||
Also a camber kit may be a good idea if you don't like the idea of replacing the rear tyres every 20,000
#62 | ||
WRC Fanatic
You would only need a rear camber kit (front has camber adjustment already), and even then it’s not a necessity. The camber on my car was only slightly out (although it’s an XR5 and it has a different suspension set up to yours, so it’s probably not a good guide), but as long as you rotate your tyres regularly, you will still get good mileage.
You should be able to find a mechanic who will fit them for $150 or so, and after getting a wheel alignment, probably get away with it for around $500 - $550. I’d offer to help you myself, but I don’t have the required gear, and because I had someone else do most of the work, I wouldn’t be 100% confident of what I was doing anyway.
Panther Black XR5T Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph |
#63 | ||
XR5 Pilot
Thanks for the offer
![]() Wish I'd saved the extra money to get the XR5...Insurance would hurt though!
'08 Ford Mondeo XR5 in Thunder |
#64 | |||
WRC Fanatic
#65 | ||
Getting a xr5 turbo insured for an under 25 is only 2-4% more than a zetec, unless heaps of people that match your demographic in your area have crashed heaps of xr5turbos.
#66 | |||
WRC Fanatic
#67 | |||
XR5 Pilot
#68 | ||
REMZ
So since youve put the superlows on. u think you can put 20's on it? without flaring out the guards? but how big can you go on the 2006 ls focus?
:king: THE KING IS HERE :king: |
#69 | |||
#70 | ||
here's some info i used when changing the coils in my XR5, http://www.focushacks.com/index.php?modid=54
Very easy job to change the springs in the focus. Jeff |
#71 | |||
i want to do the same thing you have done with your intake silencer, i have read what you did about 20 times but i'm still a bit lost. also does it make much of a difference in sound with the intake noise. cheers |
#72 | |||
When insurance was up for renewal in Nov last year, I changed to AAMI, $2100 a year with $2000 excess... |
#73 | |||
#74 | ||
have you got 20s on your?
#75 | ||
Hi Guys
I have my Focus CL with the 17" Zetec Wheels. I want to get it lowered (slightly) as I think it sits too high on the wheels. I actually want it to look like factory height rather than 'looking' lowered. I know the Zetec sits around 10mm lower than the standard and I believe the XR5 is another 15 mm lower so I was hoping to lower it no more than 25mm but preferable around 15-20mm. I have spoken to Pedders and there Sportsrider suspension lowers the car 35mm and I spoke to the distributors of the Eibach springs and they are lowered 30mm. What would be my best option for lowering the car around 15-20mm? Also if someone has a lowered Focus on the Factroy 17" could you post a side profile shot and let me know how much lower than the standard suspension it is? |
#76 | ||
Old enough to know better
Might be worth finding out what a set of genuine XR5 springs will set you back
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
#77 | ||
Hey Aston.. go jump over to www.fordxr5turbo.com and post on the forum you might be looking for some XR5 springs.
A few people have changed to the eibachs so they might have some sitting in thier garages. |
#78 | |||
See post 26. |
