Old 15-09-2006, 11:58 AM   #31
Pieoter
I use Cartest for the simulation. You input the power and torque and it automatically creates a torque and power curve or you can do it yourself too. It takes alot of factors into consideration such a Friction of tyres, clutch grip, gearing etc.
Still wanna give the fez a go but next week is not good for me. The fez is in for "regular" maintenance.
COLORADO RED FIESTA ZETEC
MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes.
ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001.
Pieoter is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 02:08 PM   #32
mitch_lx
Candy White GTI
mitch_lx's Avatar
Default lr vs ls
Liar...
Volkswagen GTI Polo.
Candy White, Anthracite heated Sports leather seats w/ Red stitching.Tinted Windows, Eibach Pro-Kit springs,Whiteline Front/Rear adjustable sway bars,Cupra R intake, Forge Turbo Inlet pipe,BMC panel filter, APR stage one flash,
Dunlop SP sport MAXX, Forge Polished upper front strut brace. 3'' downpipe and highflow cat
Loads of fun :
mitch_lx is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 02:43 PM   #33
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Keep us informed and I might give me 'chair a go down the 400m!!
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 04:22 PM   #34
melbzetec
Old enough to know better
melbzetec's Avatar
Here are the figures I've been trying to find.
LR Focus vs. LS Focus
Bore (mm) 84.8 vs. 87.5
Capacity (cm3) 1988 vs. 1999
Compression ratio 10.0:1 vs. 10.8:1
Maximum power 96kW @ 5500rpm vs. 107kW @ 6000rpm
Maximum torque 178Nm @ 4500rpm vs. 185Nm @ 4500rpm
Stroke (mm) 88.0 vs. 83.1
Ratio 1 3.417:1 vs. 3.40:1
Ratio 2 2.136:1 vs. 2.14:1
Ratio 3 1.448:1 vs. 1.45:1
Ratio 4 1.028:1 vs. 1.03:1
Ratio 5 0.767:1 vs. 0.80:1
Bore and stroke are quite different (LR smaller bore, longer stroke)
More torque for LS
Gear ratios close but different
Now, all we need is someone who understands what those differences actually mean in a practical sense!!!!
Would love to know
Old 15-09-2006, 04:45 PM   #35
BlackLS
Anyone have the final drive ratio, and the rolling diameter?
Just on the engines, the Duratec has an "oversquare" engine, where the bore (piston dia) is greater than the stroke (rod length). This means that there is less friction and a stronger crankshaft. Whats interesting is that the Duratec has a higher compression ratio compared to the Zetec, where the Zetec should have a higher compression ratio. This is probably where the extra power comes from.
The Zetec is good, as the longer the stroke, means more lower torque (think longer leaverage). Thats how the 2.0 Zetec has a good low down compared to the Duratecs dismal torque until you hit 2500 rpm, Even have a look how close the torque figures are to each other. Its is also evident with the peak power in the Zetec at a nice lazy 5500rpm compared to the 6000rpm in the Duratec.
If you were racing a unopened LR Zetec2.0, experiment by not going to redline to shift. Shift at 5500, or whatever rpm so that when you change, you drop to 4500rpm at the nice fat torque band
If your racing an LS, at the launch bring it to about 3000rpm and slip the clutch so much as you aren't breaking traction, the ghey feather-light clutch doesn't help much here. You'll probably destroy it though doing this a lot though as well. Once your clutch is out all the way 6100rpm changes. You'll have to touch 4th gear as well, so don't waste any time in 3rd gears redline trying to make the line
Old 15-09-2006, 04:53 PM   #36
BlackLS
With the ratios I wouldn't be suprised if they were the same gearing, with the LS ratios just rounded.
Old 15-09-2006, 05:31 PM   #37
melbzetec
melbzetec's Avatar
A beautiful summation BlackLS. Thankyou for that. The "oversquare" nature of the Duratec was the thing I found most interesting from the figures.
The Zetec was definitely designed for low down torque. When you look at the exhaust set up, you find the same thing (shorty header etc)
I must look around and see if anyone has shaved the head to lift compression...and what the results are
Old 15-09-2006, 05:39 PM   #38
Pieoter
Just ran some more Simulations
LS: 6.9Second 100m, 16.2 @136kmph 1/4mile, 30.1 @173kmph 1km
LR: 7.0Second 100m, 16.7 @132kmph 1/4mile, 30.7 @170kmph 1km
I would presume that both the LS and LR have the same gearbox which i beleive is the IB5 unit. Because of the difference in tyre size the LR has effectivaly a closer ratio box.
Id still go the 2L duratec unit
Final ratio for both is 4.06
[EDIT] Mixed up LS and LR
Old 15-09-2006, 05:44 PM   #39
BlackLS
LS: 6.9Second 100m, 16.7 @132kmph 1/4mile, 30.7 @170kmph 1km
LR: 7.0Second 100m, 16.2 @136kmph 1/4mile, 30.1 @173kmph 1km
You can just see the torque-pull from the Zetec being so useful on the quarter mile. the 16.7 is closer to the other 2 runs I did that night (16.5 with floormats in place, red hot underbonnet air temps from idling, spare wheel in place etc.
Pietor, does that include the driver in the weights?
EDIT: Disregard my Dribble
I knew the figures were a bit rich!
Old 15-09-2006, 05:54 PM   #40
Pieoter
Sorry I mixed up the LR and LS figures :( they are fixed now
Those figure and using the kerb weight. This includes a 75kg driver, 70% fuel, all fluids and spare tyres etc. Basically how it would be most of the time. So without a spare tyres and less fuel you can cut though figures down.
As the speeds increase the LS gains a bigger and bigger advantage (as aero drag builds up the extra power gives the LS the edge).
Old 15-09-2006, 05:59 PM   #41
BlackLS
When I ran I had 10% fuel but a big 100kg driver - me!
Old 15-09-2006, 10:49 PM   #42
melbzetec
melbzetec's Avatar
The gearbox on the LR Zetec is actually an MTX 75 not an IB5. It was different to the CL and LX models.
And I think 17" wheels were standard on the Zetec
Old 16-09-2006, 12:39 AM   #43
zetec
Zoom Zoom
zetec's Avatar
LR Zetec had standard 16" wheels Stephen, shame on you. Mind you mine shall shortly have 17"s on it... but I digress!
Focus ST170 had a Getrag 6-speed close ratio
Focus RS had a 5-speed MTX 75. Interesting. It's a tough box the old MTX75.
2012 Mazda3 MPS
Old 16-09-2006, 01:16 AM   #44
Pieoter
Yep sorry. They do use the MTX75 box. IB5 was used on the 1.8models
LS zetec has 205/50 R17 tyres = 2000.6mm circumference
LR zetec has 205/50 R16 tyres = 1920.8mm circumference meaning an extra 21rev per km compared to LS
LR zetec R has 215/45 R17 tyres = 1964.4mm circumference meaning an extra 9rev per Km compared to LS
So you can see that for each rev of the driveshaft the LS will travel further.
LR Zetec came with both 16 and 17inch rims stock depending if it was the Zetec R or normal Zetec
Old 16-09-2006, 07:15 AM   #45
melbzetec
melbzetec's Avatar
Thanks to Pieoter, and apologies to Matt. I always muck up that wheel thing. My Zetec came with the 17" wheels, but then again mine was an oddball car I got directly from Ford. So I get confused what was standard and what wasn't.(Glad to see you still lurking about Matt...........not at work every single hour of the day!!!!!!!)
Old 16-09-2006, 08:38 PM   #46
mauro
04 focus
does any body know were i can get performance parts for 1.8 2004 focus in melbourne
mauro is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2006, 09:52 PM   #47
melbzetec
melbzetec's Avatar
Hey Mauro,
Welcome to the forums.
The basic answer to your question is....you can't.
The internet is your friend here. I'm not too sure if 1.8.04 is LR or LS.
If it is LR, both the UK and the US can be your friend. If LS, then the UK/Europe is your only hope.
Apart from a K&N or BMC filter, or the K&N Typhoon, there is little to be had in Australia, and the cheapest way is to bring things in via mail order.
Check out the Euroford club website for some useful links. www.euroford.com
Old 16-09-2006, 10:41 PM   #48
simonr
Focus Rookie
simonr's Avatar
www.eurofordclub.com ;)
04' Panther Black Focus Zetec
Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters
simonr is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 07:03 AM   #49
melbzetec
melbzetec's Avatar
Old 17-09-2006, 10:50 AM   #50
Zetec20
Zetec20's Avatar
hey i think he meant 1.8 litre 2004 model, which would be the LR :P
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 01:45 PM   #51
amlohac
amlohac's Avatar
Herrod. Herrod. And more Herrod. I met a guy in albury here who had a 1.8L LR that had Herrod mods, exhaust, intake, even had some kind of performance chip, LSD all that stuff. It was basically thier project car and they sold it to him. So give them a call they might steer you right.
amlohac is offline   Reply With Quote Multi-Quote with this Post
