Old 22-03-2005, 07:38 PM   #31
Steffo
LPG > You
Steffo's Avatar
Originally Posted by Quasi
Keep in mind, also, that Seton won two V8 Supercar championships with that engine in the 90s, including one in an EB.
What does a $100,000 specially built 600hp race engine that is built that way (5.0, pushrod, EFI) because of a specific set of rules have to do with normal street cars? A 351W will always be more capable then a 302W because of its larger deck which enables larger bore sizes and larger strokes/rods to be used for capacities in excess of 7.0 litres. The furthest you can take a 302 is 5.7 litres.
Old 22-03-2005, 07:47 PM   #32
Psycho Chicken
Psycho Chicken's Avatar
And someone correct me if I'm wrong but aren't all Ford V8 supsercar engines since the introduction of the V8 rules Wheezers?
Old 22-03-2005, 07:53 PM   #33
Perana
Perana's Avatar
Yes they are... Not much in common with road going wheezers though!
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 08:14 PM   #34
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
Fords in v8sc use a motorsport block not the road car block.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 08:16 PM   #35
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
But that'd never win you a race in the pub!
351W was a pretty good truck motor anyway....
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 08:19 PM   #36
Psycho Chicken
Well naturally, would you spend $100,000 on an engine and use a $500 block?
Old 22-03-2005, 08:19 PM   #37
Barry_v
rocknrolla
Barry_v's Avatar
its still the same block, just made stronger and the cylinder walls thicker to cope with lots of re-bores. they have big port alloy heads too. the inlet manifold is the biggie, totally different to a road car setup.
Barry_v is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 08:27 PM   #38
Gammaboy
Gammaboy's Avatar
funnily enought those heads are closer to clevo's than windsors....
Old 22-03-2005, 08:34 PM   #39
Barry_v
rocknrolla
Barry_v's Avatar
yeah they are massive ports. the inlet manifolds resemble nothing road-going though, they run an offset distributer they're so big. i think they used to run the injectors outside the manifold too, do they still do that?
Old 22-03-2005, 08:43 PM   #40
Psycho Chicken
Yeah I know it's the same design but it's not the same jobbie you'll find in the $250 302 you get out of the Trading Post.
Old 22-03-2005, 08:50 PM   #41
Gammaboy
Gammaboy's Avatar
The Yates heads they run started life in the early eighties with canted valves, a unique exhaust port and intakes that were basically a 4V clevo with a port stuffer... I dunno exactly when the transition was made, but they now run a non canted valve geometry, unique exhaust ports and an intake thats derived from the earlier stuffed 4V type.... I think they start with the Yates head casting thats intended for Nascars running restrictor plates (smallish ports), more room for optimising the porting.
Old 22-03-2005, 10:29 PM   #42
Quasi
Boss 290 BA GT Goodness
Quasi's Avatar
There wouldn't have been any of the teams spending $100,000 per engine in 1992/93 (unless you count staff wages).
Originally Posted by Barry Sheene on a V8 Supercar telecast
Welcome to beautiful Phillip Island.....gateway to hypothermia
The Toy - 03 BA GT In 'Venom', Silver BF Stripe Kit, Non-Premium Sound, Cloth Trim, Auto, 19" Staggered Vertini, Custom Exhaust, Roof DVD
Member of the FPV & XR Owners Club of ACT
Web Links To Check Out
Shannons Club Garage
Facebook Photo Albums
Quasi is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 10:21 PM   #43
Bossxr8
Peter Car
Bossxr8's Avatar
I believe they still do. I can remember seeing a few pics of the engines with the injectors inside the inlet trumpets on top of the engine.
Old 24-03-2005, 04:57 PM   #44
347Stroker
347Stroker's Avatar
Well guys, I am putting a 351 Windsor into an EL, so at least there will be one on the road, finally.
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 05:06 PM   #45
Jase
-Village Idiot-
Jase's Avatar
I comtemplated it also aye.
Should bolt straigh ontot 5L mounts... the 351C's do, and i think the stud patten for the bell housing is all the same aswell.
Should be fun, loooots more torque!
Jase is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 09:44 PM   #46
GTENVY
GTENVY's Avatar
Just going back to the Boss/SVT Cobra R engine comparo, the research I've done the Boss 5.4 Block is a F series truck block, where as the 5.4 in the cobra R was a limited run, they used specific casts for them which are design to only be used a certian amount of times, then throw em away. I found this looking on one of the US sites. Agree about the 351w, much stronger block standard and the bolt pattern for the auxileries and bell housing are the same. Been thinking about doing this to my EB XR8, but getting an XB coupe shortly. There goes the funds for that upgrade :
FM Mustang GT, manual - Daily driven
Live, Love, RACE
SOLD: AU III XR8
Originally Posted by nstg8a
cars are to be driven, ornaments are to be looked at. the two should never be confused.
GTENVY is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 05:13 PM   #47
Cobra
Bear with a sore head
Cobra's Avatar
I remember reading in a US magazine that said the SVT Cobra R block was from a Lincoln Navigator which I thought was the same as the F-Trucks?
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 12:32 AM   #48
Bossxr8
Peter Car
Bossxr8's Avatar
It is basically the same, the only difference I know of is the Navigator uses 4 valve heads and the F series don't, but the blocks are still the same though. The special tooling used on the Cobra R was for the heads, and FPV couldn't get them as they were stuffed, but they managed to get the upgraded Cobra R versions anyway, but I still have no idea which american vehicle uses them as when they were first installed on the Boss motors they weren't used on any other vehicle, they were unique to the BA, but i'm sure they will have been used on something else as why else would they have bothered to upgrade the Cobra R heads if they weren't going to be used in the US.
