Old 07-09-2005, 07:21 PM   #31
Stampy
O and i ordered the SVT Snorkel from USA today ,(as per picture posted earlier),
Old 11-09-2005, 10:01 AM   #32
Stampy
look at this pic and tell me whats the brass sensor is for and where did it go before your mod mine is the same?
Old 11-09-2005, 01:03 PM   #33
orsest170
WRC Fanatic
orsest170's Avatar
Stampy,
I'm not exactly sure what the brass sensor is for. It was attached to the outside of the battery housing in exactly the same position it is in now - I simply cut holes in the heat shield for it and all the other wires (you need to cut a hole for the battery wires and MAF sensor wires to feed through) so they could be re-attached in exactly the same positions that they were originally in.
To get the heat shield dimensions exactly right (well as close as possible), I made a cardboard template. Because the cardboard is flexible, you can easily put the template in place without dismantling everything and see where alterations need to be made. It took about 4 revisions to get it right.
Basically, the heat shield attaches to the battery housing (I had to cut the front corner of the housing to get a flat surface to mount against) and the small heat shield you get with the typhoon (I assume you have that installed?). I pop-riveted the shield on, but I guess you could glue it on too.
The only problem I did have, was the intake tube hitting the heat shield (the intake moves slightly under throttle) and eventually dislodging the intake from the throttle body – you’ll know pretty quickly if that ever happens. That is why I cut a much larger hole in the shield than was needed around the intake and filled it with adhesive foam – haven’t had a problem since.
Panther Black XR5T
Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph
orsest170 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2005, 06:36 PM   #34
zetec
Zoom Zoom
zetec's Avatar
That's also fitted to the Zetec from memory, may well be a cheap heat sink? No idea really...
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 07:08 AM   #35
Stampy
it's a temp sensor for sure but whats temp is it sensing ,could it be the snow flake simble inside next to oil gauge ,detects temps lower than 5 deg or somethink
Old 13-09-2005, 12:13 PM   #36
zetec
Zoom Zoom
zetec's Avatar
No that's below the front bumper under the radiator.
2012 Mazda3 MPS
