#31 | ||
Giddy up.
Genuine OEM fuel filter to suit AUII XR8 sedan please.
#33 | ||
https://www.ebay.com.au/itm/Genuine-...frcectupt=true
Example above. I can only get for $22 + freight if required. |
#34 | |||
Giddy up.
Also I forgot to ask, a genuine Ford Motorcraft power steering pressure switch to suit the above mentioned vehicle. Regards. |
#35 | |||
Power steering switch that sits in the rack is available, $100 plus freight. |
#36 | ||
HUGH JARSE
![]() Join Date: May 2005
Hey GT
I am after a silver spear insert driver's door 2008 FG XR6 ute. Cav |
#37 | |||
Will need your VIN to confirm as there are a few different coloured spears available pending on a few things. If its the standard satin silver spear for XR then it is no longer available. There are a few others that are though. GT |
#38 | |||
HUGH JARSE
The driver's one in my ute which I have only had for a short while is black. I took it off and it is silver that has been painted black rather poorly - so I am going to sand it back and repaint it silver. What could possibly go wrong? ![]() ![]() ![]() Cheers Cav Gratuitous ute shot follows ... ![]() |
8 users like this post: |
#39 | |||
#40 | ||
Ford T3 Partsologist
Careful - There are 2 types of Fuel Filters
With IRS - AFG55 / BG 9155 B or With Out IRS - AFG60
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() Last edited by Dingo; 04-12-2020 at 10:44 PM. |
#41 | ||
Giddy up.
#42 | ||
WT GT
![]() Join Date: Jan 2006
Hi GT, do you have indicative pricing for the 19 x 9.5” rear rims and caps in standard grey finish as per FGII RSpec and FGXR8 to suit 05/2011 GT?
Asking for a friend ![]() Sent from my iPad using Tapatalk |
#43 | ||
#44 | |||
You will need to be very specific about which wheel you are exactly after, if you have a picture or part number, that will also help. |
#45 | |||
WT GT
I need the rims that would match the exact style of the original 2011 rims in finish. I'll do some research. |
#46 | ||
#47 | ||
#48 | ||
G’day GT
Can I please have a part number for a Universal Joint rego 5600MO As on Microcat there is no part number listed for a universal joint for a T3 TE50 2002 you have to buy a complete tail shaft........... Thanx Darren
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() Last edited by Dingo; 07-12-2020 at 11:00 AM. |
#50 | ||
Gday GT
yeah i thort as much , just wanted to check as MC only shows up to 31st of October 2001 thanx again Aaaaarrrrrrrrrooooooooooooooo
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() |
#51 | |||
You might find they are the same? |
#52 | ||
Complete set of rubbers for the doors?
doors and frames S1 AU Fairmont also very long shot, can you tell me if the tailshaft is different on a T3 TE/TS50 manual is different to the XR8 manual sedan? |
#53 | |||
Yes the shafts are different from a T3 T Series Manual and a XR8 manual. The T series us shaft TAU3 4602 A and the XR uses ERT 4602 A. Get back to you about the seals. |
#54 | ||
thanks mate, would be appreciated.
#55 | ||
#56 | ||
Hi GT can i get a price on a SY territory rear console bin latch part no 5R7ZA11675AASH
Cheers Eric |
#57 | ||
#58 | ||
Giddy up.
Hi GT,
Are the rear bleed screw in the brake calliper's still available for AUII XR8 standard PBR brakes. Also the rear exhaust rubber hanger ?, although I have a Herrod exhaust on it now but not sure if they used the genuine rubber mount or not ?. Cheers. |
#59 | |||
Brake bleed screw is not available from Ford, how ever I am sure they are available from aftermarket brake specialists or auto stores. Yes rear rubber hanger for AU2 XR8 is still available, $10 + freight each. Cheers, GT |
#60 | ||
Giddy up.
Cheers, mate, does the rear rubber hanger have a part number on it or pic, I'm trying to establish if the one I have that is stuffed is a genuine one or not, I assume even though Herrod did the exhaust that it would have been designed around all the original hangers etc, and therefore theoretically should use the existing rubber mount.
