30-01-2019, 10:56 PM | #31 | ||
https://www.bmwblog.com/2019/01/14/p...-toyota-supra/
Here you go, photo comparison with the Z4 from various angles Cheers, |
2 users like this post: |
31-01-2019, 11:05 AM | #32 | ||
Interesting video about the tech specs of the Toyota Supra's new engine the B58 (BMW engine)...
2020 Toyota Supra Engine - Detailed Review Of The 2JZ Successor Some of the B58 specs: - 3.0L Straight 6 turbo charged - Direct fuel injection - Closed deck block - Electric Arc Wire spray on the cylinder walls (0.3mm thickness) - BMW's Vanos (variable valve timing) - BMW's Valvetronic (variable valve lift) - Twin-scroll turbocharger - Air to water intercooler |
31-01-2019, 11:16 AM | #33 | ||
Virtuous Bogan (TM)
To be fair they havent done a bad job, I dislike the integrated rear spoiler and for once think a big spoiler would actually make it look better!
The Mk4 was pretty spot on for me, I think the new one could have taken a few more ques from it.
31-01-2019, 12:07 PM | #34 | ||
Peter Car
From all reports from BMW owners the engine they have chosen isn't very modable. Anyone who thinks this new Supra will be able to compete with a 2JZ original will be pretty dissapointed. The 2JZ was legendary for being able to handle a tonne of boost and make big power. The BMW engine isn't well regarded for those 2 things at all.
I think the Z4 looks a lot better. The front and back of the Supra look silly. |
31-01-2019, 12:09 PM | #35 | ||
I'm curious as both Z4 and Supra look to be heading for the GT3 class.
the previous Z4 GT3 were fitted with the 4.4 V8.. I think not available for road going models I wonder if both of these will stick to the b58 engine for their GT3
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
31-01-2019, 02:06 PM | #36 | ||
I wanted to love this and may have been tempted to get a small rear wheel drive car with very good handling dynamics.
But the engine choice is disappointing. Also no manual. And the body- looks like someone who has ocd with slapping on flaring smooth bulges into all parts of body- not smooth and clean. Looks boy racer and does not work for me now. Maybe they were aiming for the 20-27 year old age bracket?
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
31-01-2019, 02:22 PM | #37 | ||
31-01-2019, 03:13 PM | #38 | ||
From the 86, it's a bigger boy racer.
31-01-2019, 03:33 PM | #39 | ||
250kw 500NM no good? and it has paddle shifters for manual shifting
31-01-2019, 03:42 PM | #40 | ||
Render unto Caesar
[QUOTE=baboon;6250456]Maybe the sound of it will sell you?
Sounds like any other BMW x40 model.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
31-01-2019, 04:10 PM | #41 | ||
Yes fair point. I will keep an open mind- need to see in metal and try and get a drive in one to see. Be interesting to compare it to the M2 I took for a drive recently.
31-01-2019, 04:23 PM | #42 | ||
I've read the M2 is a little beast it uses the older legendary N55 engine.
would be an interesting comparison
31-01-2019, 11:34 PM | #43 | ||
M2 can now be ordered with the Comp pack with a de-tuned version of the S55 engine found in the M3/4.
01-02-2019, 07:09 AM | #44 | ||
5.0 means business
I think for the money a actual Bmw will be better like a 1-series M or similar lighter cheaper fun same engine. And a Supra desperately needs a manual.
Windsor V8 Enthusiast! Turbo Barra Lover! |
01-02-2019, 12:35 PM | #45 | |||
Peter Car
Looking at the 0-100 times between the new and old one it's really not much of an improvement. Certainly not as much as you would expect 20 years of evolution to bring. Just shows how good the 2JZ was in it's day. |
01-02-2019, 12:43 PM | #46 | ||
agreed 2JZ gives nothing away to the newer engines, but I guess it didn't have the same emissions standards to adhere too.
let see what future editions of the B58 will give. If anyone loves an inline 6 this is it for you now..
01-02-2019, 12:59 PM | #47 | ||
Peter Car
Mercedes now have a turbo straight 6.
01-02-2019, 02:17 PM | #48 | ||
haha thought there might be at least another somewhere
02-02-2019, 09:00 AM | #49 | ||
Did not know this but the exhaust manifold on the B58 engine is integrated into the head. The integrated exhaust manifold has coolant passages which lower the exhaust gas temp into the twin scroll turbo charger. This also allows the coolant to heat up quicker on startup, but also notice there is a complex coolant management system attached to the head as well...
Interesting design, which means they've optimised the exhaust manifold and for the aftermarket there is no way to replace this part? |
02-02-2019, 11:48 AM | #50 | |||
Thailand Specials
In that case you can't use a twin scroll turbo on those engines (in the case of the 2L Ecoboost the head is interchangeable with the 2.3L which doesn't have integrated exhaust manifold) Interesting read below https://jalopnik.com/automakers-are-...lds-1796305029 I had a bit of a look under the bonnet of an FG Ecoboost recently, if you want to change the turbo you need to use a T25 style turbo. Last edited by Franco Cozzo; 02-02-2019 at 12:15 PM. |
02-02-2019, 12:53 PM | #51 | ||
So much more complex engines now...
Just read about the BMW Valvetronic (variable valve lift technology)... This engine doesnt use a throttle body to regulate air into the engine, it uses the intake valves to regulate the air. The throttle body still exists but used only as a fail safe, and during normal operation the throttle body is wide open therefore near atmospheric pressure is at the valves... Apparently this design means more fuel efficient during normal driving (low load) conditions... |
03-02-2019, 04:51 PM | #52 | ||
Sounds like what this guy was talking about a few years back
https://youtu.be/S3cFfM3r510 Sent from my LYA-L09 using Tapatalk |
03-02-2019, 09:14 PM | #53 | |||
03-02-2019, 10:45 PM | #54 | ||
Limited supply
Rebadged bmw and at best Toyota styling ?
03-02-2019, 10:46 PM | #55 | ||
03-02-2019, 11:04 PM | #56 | ||
Thailand Specials
How good are Toyota?
If its not white goods and the worlds most boring commercial vehicles, their shift to bring back some excitement and targeting a younger market, their best efforts are a Subaru and now a BMW. Who remembers 1990/00 Toyota? JZX100 Toyota Chaser: MKIII Toyota Supra: MKIV Toyota Supra: W20 Toyota MR2: JZS171/UZS175 Toyota Crown: Turbo 4 cylinder Turbo 6 cylinder (1JZ and 2JZ engines) V8 (1UZFE) 2019 Toyota: Last edited by Franco Cozzo; 03-02-2019 at 11:13 PM. |
03-02-2019, 11:07 PM | #57 | ||
03-02-2019, 11:15 PM | #58 | ||
Thailand Specials
Ford GT (supercar) Ford Mustang GT350 Ford Focus ST Ford Focus RS Ford Fiesta ST (my family has one of these in the driveway) Ford F150 Raptor Don't you worry about Ford - they've still got big hairy balls, Toyota chucked on the blonde wig and pink dress and has been standing on the Grey St in St Kilda for a long time now. Toyota used to be a household name for fast cars when I was a wee woglet - see my quoted post. Remember when they made short work of Ferrari in 2016 at Lemans? Just like the 1960s? There is a reason a 22 year old Toyota Supra with 2JZGTE engine from the factory floor is asking for around the same coin as the new Toyota Supra, might have something to do with it not being 2019's 'Toyota' Lexcen. Last edited by Franco Cozzo; 03-02-2019 at 11:27 PM. |
03-02-2019, 11:26 PM | #59 | ||
The GT? That doesn't make them any money.
The 'performance' Focus is dead. A few years and it won't exist anymore, only the 'trend'. The Fiesta? yuck. Good for grandma I guess. The Mustang, about all they're good for. How long can they hold on to the V8 though? F150? HAHA are you serious? That thing is as desparate as their shareholder's, and just as cheap. |
03-02-2019, 11:33 PM | #60 | |||
Thailand Specials
Nice straw man, if you want I'll take you under my wing and show you how propaganda is done properly so it might take me longer than 15 seconds to deconstruct your thinly veiled trolling attempt. |
