Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 14-10-2014, 02:17 PM   #31
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Reduced Cheap Black Brembo 6 Pot front kits
Originally Posted by Bluey.the.Coyote View Post
Yes brembo 4 pot up front and stock caliper rears with rotors done front and rear
I don't know what the pads are, haven't pulled them out yet, I think rotors are ADB? White and red box I think I saw at his place ages ago.
Not all combo's work well you may need to check the brands. Genuine front Brembo 4 pot pads are $390 a set or you can buy pads from $120 a set but you should machine the rotors first and a rear upgrade would benefit you as well if you go to the larger 328mm vented rear PBR FPV style set up under $1000.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 14-10-2014, 05:07 PM   #32
Bluey.the.Coyote
Bluey.the.Coyote's Avatar
What front pads would you recommend for a daily driver that gets driven hard on weekend?
Bluey.the.Coyote is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2014, 06:04 PM   #33
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Machine the rotors first and then fit the pads and i have listed the top 4 pads we sell from top to bottom. We also do Remsa and project mu plus others but these are popular and good.
In my opinion all FG automatics with brembo 4 piston front brakes are more prone to noise than other models.
1.Ferodo DS2500 if stopping is your priority $300 Best street/track option
2.Bremtec Evolve $180 dusty - Dusty inbetween hawk and ferodo Lower level street / track option
3.Hawk Ceramic $185 low dust - less initial bite but better than Bremtec - Performance street
4 Bremtec Endure $120 low dust - less initial bite - Performance street
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-10-2014, 07:59 PM   #34
Bluey.the.Coyote
I'd assume the ferodo is the dustiest since it'd be the most aggressive/softest pad for the highest grip?
Keen on option 2, not a track car and I trust your opinion
I'll pull one of each current pad out and list what I have (assuming the number is still on it).
Cheers for all the advice and help!!
Old 14-10-2014, 09:59 PM   #35
g6eturbosam
2011 FORD FOCUS LW TREND
I got the bremtec euroline but not so sure. Matt where is the euroline in this list?
Sent from my iPhone using Tapatalk
g6eturbosam is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2014, 12:55 AM   #36
Bluey.the.Coyote
my mechanic mate reckons not many (if any) will machine slotted/drilled rotors (confirmed front rotors are ADR2102S Dim and ADR0505SD on the rear
what would you recommend for rotors then? ADB again or???
cheers again mate
Old 15-10-2014, 10:08 AM   #37
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The Euroline were not listed on this particular list as the inquiry was for the Brembo 4 piston pad and they don't do the 4 pot shape in the Euroline range. The brembo 6 piston caliper is in the Euroline range and would be number 2 or 3 on the list and they are similar to the Hawk pads and cheaper.
The Ferodo DS2500 is one of the best street/track pad available and then you either go more street or more track but there are many good pads out there and help is what i do.
cheers again mate
Thats correct you will find most people stay away from machining these rotors but they are machinable if with in thickness.
DBA is always my first option i can count how many issues i have had on one hand over the years and they back there product.
MATTHEW PEARCE
Phone 02 9609 1101
Old 15-10-2014, 10:26 AM   #38
g6eturbosam
ok cool i hate dust!
Old 26-10-2014, 02:07 PM   #39
g6eturbosam
Kit 2 are on the car
