20-04-2012, 05:47 PM | #31 | ||
Formerly HAMFIST
coupes and sedans share the same floor pan 100percent
and everything from the dash forward is the same as sedans Last edited by Coupes and More; 20-04-2012 at 05:54 PM. |
21-04-2012, 07:39 AM | #32 | ||
COUPE WHORE
I love spoilers front & rear ,to me coupes represent a muscle car era & are best suited with that type of look including wheels n Tyres ,but that's my personal choice .As for front spoiler go ahead you won't regret it if it's some thing that catches your mind .iv bought a few of them over the years (Xb/Xc)all from fomoco ford parts in Vic ,get on there web side there is a lot more stuff available now then ever
As far as ride hight LEAVE IT Standard if you go spoiler .Spoon drains ,drive ways speed humps all become a pain in the butt ,i reckon I kept the fibre glass industry afloat years ago when I fitted one on my dayly driver XC.Its now returned to factory ride hight with stiffer springs ,when fitted they give the elision of the car being lowered any way I live on a property in the hills & use my XC coupe on dirt roads n tracks (gingerly ) but my point is if it's kept standard ride hight it's 100% user friendly I also like the look of a standard hight front but dumped 2 inches at the rear With 15x10s & the biggest goodyear track tyres to can find mmmmmmmm getting excited ,gives it that flat out look siting still
Rides 1974 Malvern Star Dragstar pushbike mods; bald back tyre, big sissy bar, speckled paint job and buckled front wheel Last edited by cob115; 21-04-2012 at 07:46 AM. |
21-04-2012, 09:56 AM | #33 | ||
Hey Phil, Looks like you are getting into it.
2 inches all round. Forget the spoliers;)
I love Holdens.... |
21-04-2012, 10:12 AM | #34 | ||
moderator ford coupe club
i have had the front of my coupe lowered 2 inches since the late 80's (do front springs sag?). my spoiler has been on since 1990 and i have touched one gutter - it was miles higher than standard gutters and i should have known better
mine clears all normal gutters. obviously i try to be aware around driveways that have a steep rise in them, but usually i do not have problems. there is a friend's house that i couldn't get up because of the steepness of the road (down) and their driveway (up). there was 1 kfc around flemington that i was too scared to try one of their driveways, but that is the extent of my problems. not being an everyday car helps, but if you are aware and know what you can and cannot clear, then you shouldn't have a problem not being a holden, this is not a problem, but if it needs to go on the back of a truck, then the spoiler will get in the way. if they tow from the front, it is likely to be torn off, from the rear it may touch as it the road and ramps meet. mine is held on by self tappers, so that would not be a problem if it needed towing. as usual it is about keeping your eye on the surroundings and going from there and i am not sure if mine could get up wheel ramps anyway, but with the spoiler there is no hope - once again, check before doing anything Last edited by gtxb67; 21-04-2012 at 10:19 AM. |
21-04-2012, 06:00 PM | #35 | ||
Clevo power!
Quick note to say I'm in the shed working on it right now!
So far the driving lights have been wired up, once I got a proper chance to look at it, a quick fiddle, test and done Just replaced a bolt on top of the fuel tank that holds those vapor lines or whatever they are on, the old one was stuffed and not doing up tight so it was leaking fuel there. Pics later probably And hopefully more things fixed!
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread |
22-04-2012, 01:23 AM | #36 | ||
Clevo power!
So to add to what I put up before, I got a few things done after that:
First here's a pic of the fixed fuel vapor line(?) part, you can see a stain from leaking fuel, new bolt and all good, much better than the dodgy side of the road fix I did on the trip home! Tightened up the passenger side windscreen wiper so it works now. Tested the washer squirters but they dont work, didnt get into fixing them though. Glued one of the center pieces of the steering wheel back in that had come off, the black and metal insert piece. Not sure if you can see but the inside of the wheel is missing a piece of black plastic on the right hand side of the lower arm, any ideas to fix it? Find another stuffed wheel to cut a piece out of, or someone know of something else that fits? Then with the help of my girlfriend we fixed up a few things inside, few screws tightened on trim bits, one rear ash tray popped back in, dont have the other one though. Do you have it around somewhere Pat? Checked the indicators and they are ok, so dont need replacing. Dad started working on the rear side clearance lights, they didnt have globes, looks like they need new fittings though, so thats not finished yet. Also pulled out the jack from in the boot, it's the original bumper ripper jack, I plan to replace it with a proper jack. Does anyone want it for originality purposes? Everything is there I think in the vinyl bag, which isnt in the best of shape. Oh for those who havent seen, check out the dealer fitted cloth seat inserts! 70's baby! About the spoiler and lowering, I do prefer the earlier one over the later XC one, so thats what I was looking at. I'm not a fan of lower at the back than the front, think I've seen too many XE's like that and put me off that look For now though, spoiler is on the wait list, more important things to spend money on first, later on though I would like to go up to 15" wheels, probably globes, and spoiler, would have to see where it sat before I went lower, I'm not a fan of taking 15 minutes to get over a speedbump! And a pic to make it look like I actually did something... I think I was just having a look see underneath, found a silicone'd up hole in the floor to investigate later. Also looked at where to use a proper jack on it while I was on the floor. Checked the rear brakes and I have drums on the rear, wooo modern technology! Also had a quick squizz at the suspension bushes and I think some new ones will be on the shopping list. Thats all for today, spent most of the day putting a roof on a carport, indirectly linked to the coupe. Its for my trailer and dads caravan to go under to make more room in the shed for the coupe! Its a very nice shed by the way, at the moment it has the coupe, a toyota starlet, a 10x5.5 tandem with a 14 foot catamaran on top, the caravan and heaps of working room down the side!
22-04-2012, 07:30 AM | #37 | ||
Regular Yobbo
No,sorry phil,the original rear ashtrays were removed years ago.The owner did not want people smoking in his car.LOL.The windscreen washer worked not that long ago,might want a wiggle.
My alcohol content has to much blood in it. "I BLEED BLUE " QLD number plate....V8 COUPE !!! for sale,make a offer! |
22-04-2012, 08:40 AM | #38 | ||
You can buy those inserts for the steering wheel from eBay or Fomoco website
http://www.fomoco.com.au/Shop/shopexd.asp?id=19488 http://www.ebay.com.au/itm/FORD-FALC...item5ae5629bc1
He who dies with the most toys wins!! "Target acquired .... target engaged ..... TARGET ANGRY!!!" |
22-04-2012, 09:35 AM | #39 | |||
Clevo power!
22-04-2012, 12:34 PM | #40 | |||
Nice pick up of the coupe. Congratulations. As for the steering wheel save some $$$ and just get it restored buy one of the many GS-GT steering wheel restorer around the country. My pick has always been http://www.rimblowrestorations.co.nz/ allow around $500. including postage to NZ or just ask around on here as there are guys in OZ that do them for $350+. But I personally have never had anything to do with them or know there quality. Let me know how you go as I have to get one done myself. If I can get it done cheaper to the same quality I will. Cheers Ryan
XA Falcon 500 Hardtop Build Thread |
22-04-2012, 04:49 PM | #41 | |||
Clevo power!
22-04-2012, 04:52 PM | #42 | ||
Regular Yobbo
Minor detail Phil.
22-04-2012, 08:20 PM | #43 | |||
Clevo power!
29-04-2012, 01:36 AM | #44 | ||
Clevo power!
Holy crap I tell you I've giving poor ebay and my credit card a work out! And keeping the posties in a job.
So far I've bought a door handle, haven't fitted it yet. Parcel shelf, also not fitted. Boot carpet, been in, now back out, but I should put it back in for now (got other trim bits to do in the boot still, later) Stuff thats not here yet: air cleaner sticker (sheer coz I damn well can factor, thats an extra 20 horses right there ay?). Plastic boot lock cover and ignition and door locks set because I'm having lots of trouble with the ignition and a bit of trouble with the passenger door. Progress report: During the week dad fixed up the rear side indicators and number plate light, should the number plate light have a lens over it or is it just the bare globe hanging out? Today: I welded up a small rust hole in the boot floor, so glad I could borrow a MIG, just wouldn't have happened with the trusty old arc! The sun visors didn't have the stoppers on the end to hold them in the clip, so I bought some from bunnings last week and made them fit today. I made up a bolt to hold down the spare wheel, found a proper one with the butterfly top in the shed but it was to short, small amount of drilling, grinding and welding later and the top was welded to a longer bolt. I freed up the movement of the drivers seat, so I can now sit where I need to! Not heaps left for a roadworthy now, just the passenger door, radiator and windscreen washers really. Plan is now to get a permit next weekend to get it to the tyre place for new fronts and an alignment, mechanics for inspection and service. Then take the radiator out and get it fixed, also see if there's a thermostat in when we do that because I don't think there is. Then roadworthy, rego and driving...everywhere...all the time...because I can! After that it's just mostly interior and boot trim pieces, with the boot I'm planning on boxing it out with storage boxes on the sides to put the jack and stuff in (not the original jack but one that works without wrecking the car).
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread Last edited by Phil B; 29-04-2012 at 01:42 AM. |
29-04-2012, 01:56 AM | #45 | ||
Regular Yobbo
There is a new thermostat there.
29-04-2012, 10:09 AM | #46 | |||
Clevo power!
29-04-2012, 10:25 AM | #47 | ||
Regular Yobbo
It needs a choke,and i think the gauge is on the apathetic side,like me.They dont run as hot as the modern cars.
30-04-2012, 08:52 PM | #48 | |||
Clevo power!
One other thing, should there be a plastic lens over the number plate light? Or does the globe just hang out bare? Oh and more stuff arrived today!
01-05-2012, 12:58 AM | #49 | ||
Clevo power!
I'm also planning on getting new suspension bushes all around for it, they look like original rubber ones and are a bit cracked. Any recommendations as to where to get them, what material to get them in and what to avoid?
01-05-2012, 04:41 AM | #50 | ||
Regular Yobbo
The thermostat in it,runs a cooler heat range,you can replace the sender unit in the tank,the bulb should have a housing and lens.
01-05-2012, 08:24 AM | #51 | ||
Clevo power!
Ok I'll get round to that at some point.
Does anyone know where to get that lens from?
01-05-2012, 11:30 AM | #52 | ||
My 76 coupe doesnt have a lens housing for the rear number plate bulb and Im its second owner - no crashes prior to me buying it
would like to see a picture of one |
01-05-2012, 01:32 PM | #53 | |||
I'd recommend rubbber bushes for rear springs. Rubber for castor rod bushes. Perhaps urathane for lower control arm. You can buy complete lower control arms which includes a new ball joint and bush. For upper control arms, it probably should have the greaseable metal bushes, if so keep them. For swaybar, I'd use urathane. Bursons or Conventary or Repco should have them but they will try to sell you urathane bushes. Just tell them you want rubber.
01-05-2012, 04:17 PM | #54 | |||
Clevo power!
01-05-2012, 06:04 PM | #55 | |||
Sway bar saddle and link pins in urathane are good as it will make the sway bar more effective. The lower control arm won't transmit much noise or harshness. IMO the castor rod needs a rubber bush to allow more flex. The upper control arms are probably the older style metal joint with grease nipples. It use to be popular to retrofit later model arms with rubber bushes but this trend seems to have been reversed in recent years with the older style becoming more popular again. You have air shocks in the rear end. I would bin them and replace the shocks all round with some good ones, like Konis. Look at a rear sway bar too.
01-05-2012, 06:51 PM | #56 | |||
Clevo power!
The problem with all this is though that I'm itching to get it on the road and drive it, but new shocks would make it nicer. I definitely plan on doing the bushes before I get new front tyres and a wheel alignment because that makes sense. Would new shocks need a new wheel alignment? Thinking of doing them after I've driven it a bit, get my fix, then have it all organised and drop them in.
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread Last edited by Phil B; 01-05-2012 at 07:02 PM. Reason: Checking |
01-05-2012, 06:52 PM | #57 | |||
Regular Yobbo
01-05-2012, 07:04 PM | #58 | |||
Clevo power!
I'm thinking I wont bother about a lens cover until the globe breaks. It is pretty protected up there. Hell I could probably get an LED number plate light for a trailer and fit that lol!
01-05-2012, 07:07 PM | #59 | |||
01-05-2012, 07:24 PM | #60 | |||
Clevo power!
About tyres, are those Bridgestone Eagers a pretty good tyre? Worth getting them again when I get new tyres? I have no idea how they feel because the only thing I'm used to is a ute on light trucks!
