19-08-2011, 02:54 PM | #31 | |||
let it burn
We've got a Wertheim carpet shampooer so Id probably use that as the water would help keep the mercury from being recirculated. But no, I'll avoid it by not having those stupid lights anyway. Dont know how true it is, but I recall a bloke on TV stating how they can increase skin cancer risks too, so he bought several wholesale sized boxes of the incandescents before the ban kicked in. |
19-08-2011, 03:26 PM | #32 | ||
Cruising...
Do the globes make a low electrical ''zzzzzzzzzzz'' sound before they go? When im on the computer at home i sit under 3 of these p.o.s's and they dont sound healthy....
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
19-08-2011, 03:28 PM | #33 | ||||
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
20-08-2011, 09:20 AM | #34 | ||||
Force Fed Fords
In my research I've found that the bulk of the globes are made in China and sold to Woolworths and Westfarmers for less than 50 cents per unit. These things are built to a price so the glue holding the tube to the plastic base is reknowned for failing when the buggers warm up. Apparently only the phillips or GE type are the least problematic of which I haven't been able to find.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
20-08-2011, 11:34 AM | #35 | |||
I love Holdens.... |
20-08-2011, 01:19 PM | #36 | ||||
Force Fed Fords
20-08-2011, 11:28 PM | #37 | |||
let it burn
The whole notion that changing the lighting habits of domestic properties was somehow going to be revolutionary change was stupid in reality, but was politically clever. Domestic use of electricity is around 10% of all electricity produced in this country (similar stat for oil too AFAIK). and then factor in that lighting is a small amount of all our electrical use, its water heaters, room heaters, aircon, ovens, TV and surround sound systems, etc and to a lesser extent (as we use them for short periods at a time) kettles, toasters, hairdryers and other high power consumption devices that make up the larger part of domestic use. Then theres tools etc. Point is domestic lighting is bugger all of less than 10% of all electricity consumption. And hey, i believe global warming is an issue, and man is at least in part responsible and even i know the lightglobe issue was nonsense. Just bring back the old ones. |
21-08-2011, 12:45 AM | #38 | ||
whoa....thanks for the headsup about normal incandescents being withdrawn from the market. I was aware that it had been talked about and wish Id stockpiled them, I hadnt needed to buy any for a couple of years and had a look down the local bunnings today and realised the reality!.
The reg is flawed for a number of reasons. Ive had two of the compact fluros fail and start smouldering(who knows what would have happened if they had been unattended, and have had several of the woolworths ones break just while pushing them into bayonet sockets. As others had noted, they simply dont put out the quoted light output and take several minutes in cold temperatures to produce worthwhile light, not good for a sensor light at the front door etc. Sure, they are a good idea if they are in areas where you need the light more than a hour a day, yet I have a number of places about the home/shed where I only need the light to work for a minute or less per day. The amount of energy the globe needs being really quite irrelevant, but Im forced to now compromise with these expensive globes and will have to install several of them to replace the 150W and 200W filament globes that I have in several places. It doesnt appear that this basic restriction of choice has been applied to any other consumer item. We can still purchase a 500W plasma versus a 150W LED version or even buy a thirsty Hummer compared to a thrifty golf diesel, or for that matter a even a 2000W infra red light(bar radiator), not happy. |
21-08-2011, 02:51 AM | #39 | |||
let it burn
For the other stuff, just look for halogen globes, they look like a normal old style globe with a car headlight globe inside the glass. Essentially thats what they are but obviously 240 volt and purpose built. They cost about $3 and seem to last as long as the old lights did, pretty much anyway. |
21-08-2011, 07:18 AM | #40 | |||
21-08-2011, 11:32 AM | #41 | ||
I don't think the problem is the concept of CFL but as is typical these days the products we get from chain stores are cheap crap.
21-08-2011, 11:36 AM | #42 | ||
It's the electrolytic capacitors that do the blowing in the compact fluoros.
The cheap chinese made fluoros are usually intended for the 110/220v market, in spite of being labelled as 240v. If you get some slight excess mains voltage the driver transistors short out, then AC voltage finds it's way into the secondary side electrolytic capacitors. It's the capacitors that explode like fire crackers, the glass assembly is usually in the way and is the most obvious casualty. |
21-08-2011, 11:48 AM | #43 | |||
Call me Spud
In saying this I have had a few of these work fine for an hour, then begin to flicker and even flash on and off after being bought the day before. The one in the family room always flicks like a power outage when you first hit the switch, only once and is a split second thing, but initially it seems like it is shorting. Might go get hologens. Last edited by Spudz27; 21-08-2011 at 11:55 AM. |
21-08-2011, 11:58 AM | #44 | ||
nope!
I have a gross of incandescent 75w bulbs stored in the shed.
Black Ute and a small brown dog of dubious pedigree |
22-08-2011, 10:26 AM | #45 | ||||
Force Fed Fords
People who stocked up on incandescents could make a small fortune selling them on ......................... The Black (light) Market.
22-08-2011, 02:03 PM | #46 | ||
FG XR6T trayback
Replaced all incandescent bulbs in the house with the compact fluros when they first came out, about 15yrs ago.
None have failed, or blown yet. The older ones may have been better quality. |
22-08-2011, 07:12 PM | #47 | ||
Landau = GT with the lot!
I don't know if it's the quality of the bulbs or the quality of the power supply making them blow, but I've lost count of the number of these energy savers I've thrown in the bin. Going to give these halogen jobbies a go and see if they last any better.
22-08-2011, 07:31 PM | #48 | |||
IWCMOGTVM Club Supporter
Daniel |
