02-07-2010, 06:00 PM | #31 | |||
Nutty Professor
Due to popular request (largely by cynics), I'm going to try and explain the principle behind the concept without giving it away. It's quite long and boring but will make sense to anyone patient enough to read all the way through.
Ok, lets start at the beginning. For argument's sake, lets all imagine the barra 6 that we know and love. This engine (and almost all piston engines) run on what is called an Otto cycle (invented by some bloke called Otto). This means that all 4 strokes (intake, compression, power, exhaust) are the same length. This means that at the bottom of the power stroke, there is still some pressure within the cylinder. This is called backpressure. The other cycle that piston engines can run on is called the Atkinson cycle - invented by a Mr. Atkinson (not Rowan). In this system, the compression stroke is shorter than the power stroke. The idea is that at the bottom of the power stroke the pressure within the cylinder is the same as that of the atmosphere. This is more efficient than the Otto cycle, because there is no power lost out of the exhaust system, however, it produces much less power. The Toyota Prius uses a similar system to this. Whilst Toyota claim they have built an Atkinson cycle engine, what they have actually done is design the camshaft in such as way as to keep the intake valve open for part of the compression stroke, essentially accomplishing the same thing as a regular Atkinson cycle engine. My product, the Atkinson Charger, captures the waste energy/pressure in the exhaust system of an Otto cycle engine, and feeds it back into the engine (the energy, not the actual exhaust). This reduces the load on the engine, increasing economy and maximum power. No special tuning is required and aside from a modified exhaust manifold, almost nothing else needs to be changed. The only downside is that because the waste energy in the exhaust is being captured by the Atkinson Charger, a turbocharger becomes redundant. While the Atkinson Charger will not produce the power gains that a turbocharger will, it is significantly less expensive and less complicated than a turbo install. I think that explains it quite well, without revealing the design. Please feel free to ask any questions, or point out something I have missed.
02-07-2010, 06:02 PM | #32 | ||||
Nutty Professor
02-07-2010, 07:23 PM | #33 | ||
sounds great to be honest. i can point you in the direction of 1million young blokes who are willing to buy gear knobs and knN filters to make there car perform better. Priced right and youll sell a million easy
03-07-2010, 12:13 PM | #34 | |||
King of the Fairy's.
Interesting idea, when I saw atkinson I thought you meant using a different crank which I think is what the prius does? Im curious as to how you are going to use the exhaust gasses to produce more work in the engine, but I'll leave that one up to you. I have a few ideas but none I can think of that would help power wise. Mate I look forward to when you have the prototype ready to be unveiled. From what I've heard so far it sounds pretty innovative. Best of luck with it.
03-07-2010, 01:22 PM | #35 | |||
Thailand Specials
BP is on its way to kill you haha. |
03-07-2010, 01:37 PM | #36 | ||
Onya brother... there is always a better way of doing things,I look forward to the release.
The Stable. AU II XR8 Daily driver. BF XR8 ute (Red the only true Modification) My Toy. The boy, XT Ute 393 cleveland. Genuine XB GT. |
03-07-2010, 01:50 PM | #37 | ||||
Nutty Professor
03-07-2010, 01:58 PM | #38 | ||
Rockin '67
Sounds really good.
Once you have a before and after dyno sheet you will gain more interest. |
03-07-2010, 02:06 PM | #39 | ||
Watts a panhard.
I don't have low self-esteem. I have low esteem for everyone else. |
03-07-2010, 02:43 PM | #40 | ||||
Nutty Professor
The Atkinson Charger operates on a similar principle to the Power Recovery Turbine (more power from otherwise wasted exhaust energy) but uses far less moving parts, as well as a few that the PRT didn't have. This significantly increases reliability and reduces cost. I've been doing some quick maths, and theoretically - testing will confirm - the Atkinson Charger should be able to increase power by more than 20%, without using any extra fuel, due to less parasitic loss within the unit. A power increase of over 20% with no extra fuel consumption, all for around $1000 to fit a Falcon 6 sounds like a pretty good deal to me. Anyone else think so?
03-07-2010, 02:59 PM | #41 | ||
Watts a panhard.
So in essence it is an improved, automotive-fit PRT. I like it, and I like your style.
03-07-2010, 03:19 PM | #42 | ||
Good job 388.
It sounds like a low or zero boost miller cycle set up. The principle to an Atkinson engine is that the exhaust valve is held open later to reduce manifold vacuum and subsequently pumping losses. A miller cycle engine is similar but uses either a turbo or a blower to eliminate manifold vacuum and deliver either zero or slight positive boost improving fuel consumption and power over naturally aspirated engines. If the forced induction unit is small enough it will follow the torque curve and increase volumetric efficiency and also improve brake specific fuel consumption. |
03-07-2010, 05:31 PM | #43 | ||
Just slidin'
30 kw on my car, same fuel consumption for $1000?
Sounds great. Id be in if you could prove it for sure. How heavy would it be out of curiosity?
MD Mondeo - For the family
03-07-2010, 08:45 PM | #44 | ||
Falcon RTV - FG G6ET
How much additional 'heatsoak' would this 'un add to the motor? Heat soak is expensive.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
03-07-2010, 09:04 PM | #45 | ||
pursuit ute baby
sounds good to me... it sounds like an EGR setup to me... but without revealing more details, i cant really say for sure.
id be candidate for my 8, given you can show proof of its workings. |
03-07-2010, 10:23 PM | #46 | |||||
Nutty Professor
V6 and V8 engines really need two smaller units, only I4 and I6 can get away with one. Quote:
03-07-2010, 10:51 PM | #47 | ||
Rlegaur Mbemer
Sounds to be an interesting concept. Will this be just as effective on highly modified engines? e.g. 500+hp NA V8s? An extra 20% - now we're talking!
I'd happily donate a test-mule... well... when I say donate, I mean put it in my car and let me test it...
[YEAH NAH] Red EL XR8 with Trick Flow top end kit, 70mm tb, 73mm maf, 24lb injectors, tweecer, 3.73s & tired T5 = 275rwhp & 13.155@105mph NA. 12.375@116.73 N2O - Off the road, awaiting White EL Series II XR8, manual, high flow cats, single 3" exhaust and Quarterhorse = 236rwhp and 14.18@97.5mph - E7 heads FTW! - SOLD |
03-07-2010, 11:15 PM | #48 | ||||
Nutty Professor
Eventually, I will provide a couple to someone with a modified engine for cost price, and see how it goes. I might have to beef up the design a little.
03-07-2010, 11:20 PM | #49 | ||
Formerly D3v[]
i like your thinking, hopefully all your testing goes well and you can produce more of these things!
04-07-2010, 12:02 AM | #50 | ||
You dig, we stick!
Yeah, sounds good. When do you think it will be available?
"....You don't put the car through engineering" - Rod Barrett. |
04-07-2010, 12:31 AM | #51 | |||
Nutty Professor
The first units available for sale will be for a Falcon 6, and should be available within the next few months. Models for other makes will be available asap, depending on demand and sales volume. As soon as I can afford it, I will be setting up a stall at Qld Raceway, Willowbank and such, so keep an eye out for me.
I would like to have it ready sooner, but cashflow issues coupled with the legal pains in the *** of inventing something new are holding me back. I would rather develop it out of my own pocket, than have an investor/s cutting into my profits. Unfortunately, my pocket is empty.
04-07-2010, 02:07 AM | #52 | ||
Awesome a product you claim works but has never been tested, yes i am very interested
04-07-2010, 08:31 PM | #53 | ||
Watts a panhard.
Well, the basic design is sound and was used for years. The PRT was a good idea, just hampered in part the the metallurgy of the time.
