17-08-2012, 08:10 PM | #31 | ||
I have just completed a trans service and flush on a BA XR6 Turbo, using this and associated threads - thanks to the original posters. A couple of points I thought to add to the thread for anyone doing the same or similar:
Having the benefit of a car hoist and full workshop facilities and having installed a new trans filter and gasket, I chose to remove the rear trans line to drain the old fluid out. With the car up on the hoist and the owner installed in the drivers seat, it was a quick and easy job to have the car run and shut off to catch the old fluid and a drum pump was used for new fluid straight into the trans. For those of you playing at home and choosing to use the trans lines by the radiator - the lower line is the trans fluid outlet. I must admit I would rather work on an old XA, but mates will drive late model Falcons! Clint |
07-03-2018, 12:10 PM | #32 | ||
Anyone know which is the pump pressure side of the trans on a BF? Front or rear line? I'm going to guess rear so it's not starved of oil when the car accelerates....
30-05-2019, 03:26 PM | #33 | ||
Thanks to all the posters here for great write ups and responses. I just finished doing our 99 AU XR6, it's standard height so checking the level was done without putting the car on stands. I did find the drain and top up a little hit and miss as even when engine is switched off there is still flow expelling the old oil. Checked and filled up 3 times after going through the gears while stationary.
Ended up using 14 litres of TQ95, ran the flush process a little too long. Very smoothe, car has 200k on it but almost nothing stuck to magnet in pan, pretty happy with that! |
19-06-2019, 12:10 PM | #34 | |||
Any advice would be most appreciated!
1999 Ford AU XR6 VCT Auto 200k 1997 Galant VR4 TT 125k |
19-06-2019, 12:23 PM | #35 | ||
Perhaps you should have adjusted the bands while you doing the fluid change. Per: www.servotechnica.spb.ru/viewdocument/BOOKS/CAR/SY/UNSORTED/Update$20EP.TRANF or http://fordforums.com.au/wsmpub//eflwx/7-1.html
regards Blue Last edited by aussiblue; 19-06-2019 at 12:34 PM. |
03-11-2019, 05:44 PM | #36 | ||
Dear all I tried to do transmission service but bunk nut is jammed any other way to put oil in.
04-11-2019, 01:43 PM | #37 | |||
The plugs don’t need to be super tight as the o’ring seals it. |
04-11-2019, 02:19 PM | #38 | ||
The problem is that I already messed up with the plug tried most of the method and lastly tried chisel and hammer too but no luck.
04-11-2019, 09:27 PM | #39 | ||
This chap suffered similar travails recently, he triumphed in the end:
https://www.fordforums.com.au/showthread.php?t=11480847 |
