06-11-2009, 04:32 PM | #31 | ||
when i get it for nothing dosent really matter
06-11-2009, 05:35 PM | #32 | |||
SKID IT
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
06-11-2009, 05:44 PM | #33 | |||
Just slidin'
So you can prototype, and mould a plastic one and make a profit for $275? Id like to see that. You were the one that was trying to sell an intake pipe that you made from bits of steel you found in a bin for $200 a pop.
MD Mondeo - For the family
06-11-2009, 07:20 PM | #34 | |||||
AU DIE HARD
Regards Whoosha P.S I have 2 Arcon boxes left at the GB price :
06-11-2009, 09:26 PM | #35 | ||
dont get me rong, i just modded mine just then to sit behind the heaed light and the snorkel, so its right under
06-11-2009, 09:28 PM | #36 | |||
get ya facts straight
06-11-2009, 09:34 PM | #37 | ||||
Just slidin'
06-11-2009, 09:37 PM | #38 | ||
thats was ages ago, i have gone a different way with it now, i just modded the pod to sit behind the head light and the snorkel, so no more engine heat,
going back to tafe next week, i have been given a few more bits left over before we move to sunny bank
06-11-2009, 10:45 PM | #39 | |||
07-11-2009, 12:44 AM | #40 | ||||
AU DIE HARD
07-11-2009, 02:51 PM | #41 | ||
Aw sick! You notice many changes in performance/noise/fuel?
07-11-2009, 03:46 PM | #42 | ||
Update of my intake, welded it on last night, excuse the welds ran out of argon so i had to use the stick welder doh!!!!!!
This is the trial fittment i did before welding it This is it welded with the welds grinded back, wont go any further grinding becuase it will get polished laters It works very well and in fact very repsonsive mod i have done Here is a pic of my intake desgin, still going over it and finding the best solution to it will have it done hopefully next week, when i can afford couple of hose clamps cheers matt
07-11-2009, 03:51 PM | #43 | ||
Is that all mild steel?
07-11-2009, 03:54 PM | #44 | ||
no its stainless steel, i wouldnt use mild steel
07-11-2009, 04:05 PM | #45 | ||
A nice powder coating would smarten it up a fair bit.Good work.
Can the pod still be taken off without moving anything else,I see it sits almost flush.I guess it depends how much pipe is in the filter housing.If its hitting a nice silicone joiner where the weld is would look good. Last edited by FreddyDUZ747; 07-11-2009 at 04:11 PM. |
07-11-2009, 04:22 PM | #46 | |||
It can be taken off, bit of a pain in the *** though, but i do it the hard way becuase i dont want to break the fibre glass i have to shorten the bend where the filter connects a little other wise pain in the *** to get the filter off, after i shorten it will be easy to put it on, rather then pulling the whole thing out other wise works preety good, ill end up getting the intake polished up eventually
08-11-2009, 01:18 AM | #47 | ||
SKID IT
should of gone althe way through and put the pod under the bar out of the engine bay
08-11-2009, 01:29 AM | #48 | ||
where the pipe goes through the glass, there are mounting holes there, so ill make up a plate and mount it there, stick the pipe through the plate then ill measure it up and tig weld the pipe to the plate, then ill cut the pod side of the pipe and silicone join it there so its easier to remove is need be,
i can buy bends and that off ebay, preety good ones as well,
08-11-2009, 01:43 AM | #49 | ||
i would of gone through the bar but i seem to have some sort of abs unit there, if anyone can inlighten me on it
08-11-2009, 07:41 AM | #50 | ||
Just slidin'
Wont be ABS in a series one Forte.
08-11-2009, 11:56 AM | #51 | ||
dont no, well what can it be , becuase its right behind the plastic guard on the front left, its like it has lines running from it or something
08-11-2009, 12:15 PM | #52 | ||
Just slidin'
Only thing there is the Horn?
08-11-2009, 12:30 PM | #53 | ||
brb i go and get a pic
08-11-2009, 12:36 PM | #54 | ||
I love reading these forums, especially when the arguments start. Refering to fdr906 and the monty. I personally would be listenin to monty as he seems pretty switched on with his 6's. I'm not a 6 cyl fan, go for a drive in a v8 and you will understand. Fdr906 i'm sure your new intake will look gr8 (apart from the welding and the gringing), but will it give you any performance at all. All the joins and welds, how much penetration from your welds do you have , that can distrupt you air flow cant it?
08-11-2009, 12:43 PM | #55 | ||
there is no argument here mate, i will be after xmas for my birthday in january be going for a dyno run with the intake and extractors( possibly the new stainless set) and have a look, plus it is for me to see what is letting the car down,
like i said i havent finished the pipe work there and the weldes wont be seen, its a tempory like that to see what it does, anyways here is what i have there, i didnt realise a horn had some lines or something running out of it
08-11-2009, 03:53 PM | #56 | ||
That picture is actually very helpful for me in another problem! Evaporative emissions charcoal canister is my informed guess. Looking at an AUIII XR8 which is making a lot of ticking noise in that area...
08-11-2009, 04:28 PM | #57 | ||
Just slidin'
Ahhh, I thought it was the Carbon cannister but wasnt game to say anything incase I was wrong,lol.
08-11-2009, 04:53 PM | #58 | ||
thanks, better clean it up and get another inner guard for it cheers
08-11-2009, 05:08 PM | #59 | ||
Just slidin'
I dont even have inner gaurds, lol. Part of my "go faster by taking off car parts" regime.
08-11-2009, 05:31 PM | #60 | ||
LOLLOL, thats the trick, shed much wieght as you can, doesnt the inner guards keep the rear bar and front bar nice and steay so it dosent flex around??
