Old 12-01-2012, 12:25 AM   #31
nuguy01au
Default Re: AU 2-3 High Series Cluster Upgrade
went straight into back of the cluster. you can find pin numbers and details in this thread also if you have your workshop manual that will help
nuguy01au is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2012, 11:10 AM   #32
BadTruck81
"Layin Frame"
BadTruck81's Avatar
Thanks mate saw it was pin 3 on the 20pin plug but couldnt find a diagram of pin locations for that plug?
BadTruck81 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2012, 03:19 PM   #33
shayne93
66 Mustang
shayne93's Avatar
So for coolant light, earth the black wire on header bottle and red wire on the header bottle to back of cluster?
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2012, 03:50 PM   #34
BadTruck81
"Layin Frame"
BadTruck81's Avatar
yeah that sounds right mate but couldnt tell you which wire on the cluster. but i havnt done it yet so might not be right
Old 30-06-2015, 11:44 PM   #35
TECHNO489
Exclamation Re: AU 2-3 High Series Cluster Upgrade
Originally Posted by Uncle_Ken View Post
I know this has been covered a million times but some of the main things have never been answered, I changed my AU3 Forte cluster to a AU3 Fairmont Ghia Cluster today, all working great, only thing is that i dont have a trip meter as the high series have it in the climate control? and havn't wired up the individual door ajar and the washer fluid senser
all the tec docs around give basic instruction on upgrading a series 1 and just say change this these pins, not very easy to understand
the instructions for series 1 are pretty much the same for 2/3 with one of the wires changing colour but all pin locations staying the same
The following wires need to be moved around, in order for the Mid/High Cluster to function correctly,
1. The Park Lamp Dial (+ Positive) Illumination needs to be moved from Pin 13 to Pin 2. - Brown
2. The Dial Negative Dimmer Illumination needs to be moved from Pin 21 to Pin 3. - Light Blue / Red
3. The ABS Warning Lamp Wire needs to be moved from Pin 8 to Pin 23 - Orange/Black
4. The R.H. Side Indicator wire needs to be moved from Pin 19 to Pin 26 - Green / Light Blue (Series 1 is White / Light Blue)
(Using the Photo Below) The Pin numbers start from bottom right and go in a U shape to the top right spread over the 2 connections, so a total of 28 pins one connection has 8 pins (that does not exist on base model wiring) and the other has 20 pins
this photos is of the back of a AU3 Fairmont Ghia Cluster with a AU3 Forte Wiring loom, with the pins removed from the connection
Hope it's okay to rebirth this topic
Hi
I get this and understand it but not real clear on pinout numbering.
I connected this Fairmont cluster today to my 1/2000 AU1 Falcon and noticed it mostly works > revs, speed, left blinker, volt, so on.
what didn't work. turn parkers on and cluster lights turn off instead of dimming, right blinker and abs don't show.
I believe this 4 wires will fix my problem. pity DTE is not in this new cluster as I like to view that option.
Anyway 3 more gauges are better then DTE so I will live with out it.
Before I start cutting wires and making changes I would like a little more info please.
What is the pinout numbering to start with.
Another thing, oil light stays on and needle doesn't move. do I need to buy a pressure oil switch?
Thanks
TECHNO489 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2015, 10:47 PM   #36
TECHNO489
Could someone please help me out.
I have done a lot of research and think this it correct
but I would like someone who has done this to let me know
if I am on the right track please.
Old 13-07-2015, 01:57 AM   #37
TECHNO489
Okay so I found the PIN layout order swapped the 4 wires around
everything worked like I had hoped but came across a new problem
not mentioned on the board anywhere.
What was happening was when I start the car everything looked fine until
I needed to put the lights on. With Parkers the Odometer light would go
out.
The pin layout is as follows in the following image.
I had to do a lot of meter testing to find my answer on the next problem.
The Od lights going out with parkers on is a earthing problem from pin 15
on the 2nd connector. I found by jumping the wire from 13 to 1 fixed the
lighting problem with Od not lighting up with Parkers.
As I don't know if the white wire on pin 15 serves any other purpose
I thought it would be a better idea to put a Diode between 15 and 1
to allow power pass one way with Parker lights on. This works perfectly.
The following images shows the finished project
Old 20-07-2015, 04:11 AM   #38
TECHNO489
Thought I would share a few more images. Got the plug from local wreckers.
I will be using this plug now instead of what I already did.
This it the small 12 pin plug, shows what colour cod wires go where.
Old 06-03-2016, 02:40 PM   #39
Barnzey
Barnzey's Avatar
Hi You seem to know a bit about the au cluster looking at some of the post, I was wondering if you could help... Im tring to put AU stereo controls into an EL.. Ive chased the wiring from clock work spring and RED/WHITE wire from there goes into the cluster and then come out as a RED/BLACK and a ORANGE and BLACK going to the stereo...
What happens in the cluster to go from 1 wire to 2 wires. I have looked every online and cant fine anything
Hope you can help
Thanks inadvance
Graham Barnes
Barnzey is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2016, 04:23 PM   #40
TECHNO489
Hi Mate, this is the best I can offer. Wiring says nothing about stereo being connected to the cluster http://www.fordmods.com/ford-technic...ter-upgrade-d4
My only guess is the cluster wires are for dimming the stereo lights.
This is images of my old cluster, it's nothing great but maybe it will help.
http://oi63.tinypic.com/s5bf5y.jpg
http://oi64.tinypic.com/vbyud.jpg
http://oi67.tinypic.com/spw0hs.jpg
http://oi65.tinypic.com/dxidfq.jpg
Old 22-03-2016, 01:38 AM   #41
Fairlane Al
Originally Posted by bodes-sh View Post
has been mentioned a few times around here, au1's had a "proper" oil pressure gauge, that actually moved as oil pressure changed. au2 and 3 only had a basic one that would just sit sorta half way all the time, without actually measuring the oil pressure, so they just ran a normal oil pressure switch instead of a pressure sender...
hope that makes sense...
Sorry to sidetrack this thread but does that mean the oil pressure gauge in AUII and III cars is effectively a glorified oil pressure light-it doesn't show me variations in the oil pressure in real time?
Is it possible for me to retrofit an AUI sender to my AUII Fairlane and get a "proper" gauge or not?
Fairlane Al is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2020, 01:05 PM   #42
BenLange
Lange212
Cheers to the bloke that posted pictures and all the info for the wires for the cluster upgrade, you saved me heaps of time!!
So ive put a series 3 fairmont cluster in my series 2 ute. Everything works except for when i turn the car off and the lights are on, it doesnt make the warning noise like the standard low series cluster did. Anyone else had this problem?
BenLange is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2021, 04:25 PM   #43
Ricknel76
Thanks. This was very helpful. I have got my S3 XR dash now working in my S3 Forte.
Just did the odo light fix.
Only problem I had, was when I did the wiring to get the odo back light working, ended up activating the Smartshield. Couldn't start it.
Not sure why. Pretty sure I followed the instructions.
Maybe coincidental. I have snipped out the odo light wiring and had a locksmith reset BEM.
On the bright side, I now have a spare key.
Ricknel76 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2022, 07:50 PM   #44
Regan
Thumbs up Re: AU 2-3 High Series Cluster Upgrade
Hi
Thanks
G’day - moving forward some 6-7yrs since your foray into cluster up grades on the AU Falcon it enabled me to carry out an up grade on my AUII XLS ute from low series cluster to a sedan XR series II cluster - following your steps it all seems to work ok - I used a high series AU cluster connector from a dash I was given which made the whole swap easy as thanks to your posts and other info within the ford forum site
Regan is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2022, 05:03 PM   #45
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
That's what we hope when we share our ups and downs, great to hear the info still helps
Old 01-03-2024, 05:14 PM   #46
Shen Long
i know this is a very old thread, i was just wandering, I've done all the things needed to upgrade my Ford S3 Futura to a high-series Ghia cluster, but for some strange reason, i can NOT get the illumination to work [cluster lights]. Any ideas???
Shen Long is offline   Reply With Quote Multi-Quote with this Post
