Old 10-05-2009, 08:40 PM   #31
RspecAU
BA GT-P Owner
RspecAU's Avatar
Originally Posted by BLACKAUXR8
i paid 350 for the whole bearing and hub assembly for mine in queensland from a local bearing shop.
The easiest way to check your rear IRS mounts is fold the seats down so you can see the top and bounce the car. Mine had always been torn at the top. Very obvious tears in the rubber. I've had my Series 3 xr8 3 years and have done 100,000km in it since buying it and have wrecked 3 sets of IRS mounts. There easy to change once you've done a few
Thats better than the 400+ from ford that i was quoted.
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 10-05-2009, 09:29 PM   #32
RspecAU
BA GT-P Owner
RspecAU's Avatar
A couple of pics of a stuffed top shocker mount i had laying around in the shed.
BUILD NUMBER 006
Old 20-05-2009, 04:03 PM   #33
V8 EF Fairmont
Originally Posted by FTe342
Be aware that the new top are different to the originals and you will need a thick spacer washer or two std washers to take up the extra space or the nut runs out of thread on the shaft before the mount gets tight. If you don't do this you will still have a rattle from the shock moving up & down thru the mount. Plenty of workshops haven't noticed this difference and had to do the job again after the noise is still there
Can the top nut be removed and washers installed whilst still in the car? I have just had the tophats replaced and there were no washers used as spacers. This all but eliminated the noise, however I've noticed there were no spacer washers used and was wondering whether I could put these in myself whilst the assembly is still in the car, and hopefully completely eliminate the noise.
V8 EF Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2009, 07:49 PM   #34
5L
[ 5L ]
5L's Avatar
just got my IRS mounts changed today, the people who had done the mounts in the past had put the washer on upside down so as the suspension bloke was telling me it was using the rubber mount correctly.
put washers in aswell as shown in the how to guide on here.
with new mounts, new shocks and lowered springs it has completely tranformed my car.
www.ignitionimages.com
Old 20-05-2009, 08:15 PM   #35
RG
Back to Le Frenchy
RG's Avatar
A little OT here but it is related.
I've been having a chat to Pedders about this and unfortunately they have no plans to make an aftermarket version of them.
They did say however that there is one on the market, god knows where though.
Old 20-05-2009, 08:22 PM   #36
Peuty
Afterburner + skids =
Peuty's Avatar
Pics of new suspension?
Oo\===/oO
Old 20-05-2009, 08:45 PM   #37
aufairmontghia
XR6
aufairmontghia's Avatar
I wanted to update everyone.... More fun & games guys!!!
I wasn't convinced with all my previous dealings, so I brought the car to Ultratune near my work as I know them there.... to my suprise they told me the whole left side was stuffed!!! Drive shaft, hub & disc etc...
I couldn't believe my luck!!!!
I parked the car home & i started driving our spare car.... On Saturday I took the car to a drive shaft specialist, they looked at the car & said the drive shaft was OK..... More than likely it was the HUB!!!
You can imagine what I was thinkin by now.... I was going nuts!!!!
I can't believe how so many so called proffesionals have looked at the car & not one had said the same one thing..... Just want to take your life savings!!!!
I now believe if you want something right then you do it yourself!!!!
I put the car on stands & pulled the wheel off.... Unbolted rear caliper, removed rear disc, then hand brake shoe.... I ran the car & noticed the rear hub was wobbling out of round!!!! So I found the problem....
Now I'm trying to remove the pack nut so I can remove the hub...
All the sockets I've used including tonight aren't long enough to grip & crack the nut.... Damn
Will have to chase another socket tommorrow...
Any ideas on the best way to remove hub if I'm fitting a new hub & bearing???
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2009, 09:02 PM   #38
bloggs24
http://www.fordforums.com.au/vbporta...article&id=319
That might be able to help you out.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2009, 09:04 PM   #39
5L
[ 5L ]
5L's Avatar
ill put up pics of before and after of the rear IRS mounts. the rest of the pics ill put in my build thread to keep this thread on topic.
as you can see the top washer is on the wrong way (was the same on both sides)
new rear mounts fitted as you can see they are much straighter, and the washer is around the corrects way.
Old 21-05-2009, 01:09 PM   #40
aufairmontghia
XR6
That's one stuffed mount!!!!!!!!
Old 04-07-2016, 12:04 PM   #41
champ
champ's Avatar
Default Re: Au Rear Top Shock Mounts Worn (IRS)
Thank you.
champ is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2018, 02:06 AM   #42
TickfordTiger
see this forum also :
https://fordforums.com.au/showthread.php?t=11353903
I have noticed these replacement internal polyurethane bushes are now available for $110ea from wholesale suspension
They also sell complete (changeover) shock / spring mounts also $275ea.
https://wholesalesuspension.com.au (02) 98318825
https://www.ebay.com.au/itm/FORD-AU-...T/272728046549
https://www.ebay.com.au/itm/FORD-AU-...A/272724624580
Falcon Unbelievable !!!
T1 TL50 Build No. 014 - Liquid Silver
T1 TL50 Build No. 017 - Liquid Silver, Sunroof
TickfordTiger is offline   Reply With Quote Multi-Quote with this Post
