03-06-2015, 09:30 PM | #31 | |||
AWD Assassin
Considering the shortfalls and compromises with the HSV and FPV cars , they do pretty damned well. Whack the S/C Miami in a focus and see how it goes....
Old RIDE 2006 BFGT Gone but not forgotten New RIDE 2018 AMG Mercedes A45 Angry AWD assassin
03-06-2015, 10:45 PM | #32 | |||
Stock Fg F6 in steel R35 G.T.R |
04-06-2015, 01:15 AM | #34 | ||
04-06-2015, 01:59 AM | #35 | ||
Boss 335
04-06-2015, 02:04 AM | #36 | ||
geez if this thread isn't trolling I don't know what is.......lucky you didn't start it Hulk.
04-06-2015, 02:07 AM | #37 | ||
04-06-2015, 07:26 AM | #38 | |||
Manual is more fun to drive and auto is faster, simple as that.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi ---------- Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's |
3 users like this post: |
04-06-2015, 09:35 AM | #39 | ||
irregular member
I drive a stock (apart from KPM intake & fatter rubber) XR6T ute and in the current conditions it is making way more 270kw.
Past 2 mornings have been minus 4 degrees and this turbo just sings!!! I really can't believe how much harder it is going, I'd love to dyno test it at this temp or put it down the strip, it actually feels as quick as the GTP335 I used to own! |
04-06-2015, 11:16 AM | #40 | |||
GTS-R might come along closer to the end of commodore production, if it comes it will be biblical, the GTS is very good platform to start with...
FG XR6T Ute
300rwkw |
04-06-2015, 12:10 PM | #41 | ||
I don't see them doing anything major with the engines. Why would they? Their only competitor in that segment trickles cars out in limited numbers, so there's no real reason to spend big $$$ updating a car that's reaching the end of its model run.
04-06-2015, 12:17 PM | #42 | |||
Member
04-06-2015, 01:33 PM | #43 | ||
They will have more mid range torque (which is easy, its a big donk) compared to the 5.0l, but peak power is pretty similar. The point is the badge says otherwise!
They are only just quicker over a 1/4 mile, not sure what people are getting out of them but haven't heard of any under 12.1-12.2? Which is basicallty .1 or .2 quicker than a GT/GTF..
FG XR6T GU Patrol Duramax |
04-06-2015, 01:42 PM | #45 | ||
My comment is not due to the power run nor the quarter mile time. It's directed at the LSA engine. Personally I think it's old hat, but what isn't old hat when it comes to Chev engines. The LSA doesn't come near the Coyote for capability. It surprises me to see the amount of money and mods going into the LSA GTS cars only to match what the Coyote can do tune only.
If GM aren't overstating the power then they must have some serious losses going on to have 120kw less at the rear wheels. Benny.
GT 335 MKII, ZF6, Tein coilovers, YT snout, 61mm pulley, KPM 1500HP fuel system, 1000cc injectors, E85, KPM exhaust, BMC air filter, KPM Streetfighter intercooler, built tail shaft, Truetrac, 479rwkw - 950nm. |
04-06-2015, 02:05 PM | #46 | ||
Member
Well absolutely in that regard the 5.0 is far superior. Also helps that the factory exhaust and cats on the FPVs are very good. The LSA could have come out in the 90s and it still wouldn't have been cutting edge.
04-06-2015, 02:31 PM | #47 | ||
Render unto Caesar
ECE vs DIM?
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
04-06-2015, 02:40 PM | #48 | ||
04-06-2015, 02:42 PM | #49 | ||
Bathed In A Yellow Glow
04-06-2015, 02:47 PM | #50 | |||
FG XR6T Ute
300rwkw |
04-06-2015, 03:42 PM | #51 | ||
Member
GTS tends to require a full exhaust and pulley to record similar figures to a tune-only GT (again, standard Ford exhaust is good). However the GT will require an intercooler to make that power consistently and reliably. So neither car has a distinct cost advantage when lightly tickled.
04-06-2015, 04:32 PM | #52 | ||
Trev
Until the first corner?
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
04-06-2015, 04:41 PM | #53 | |||
as in chopped
Look what Ford did with the XR8, it's pretty close to an R Spec GT. Also they look like bringing out an F6 with XR6 Turbo badges. It's all about the sales.
-> Reading this signature was pointless <- |
04-06-2015, 05:12 PM | #54 | |||
I hear your argument but must admit that there is more to a car than just HP well for me anyway. I have driven a GTS and i like the seating position. For some reason the seats are too high in a Falcon. Cant get the steering wheel high enough, The steering and handling of the GTS is a fair bit better though and i am comparing it to R-spec susp falcons. The std GT susp is too soft. Overall yes i thought the GTS was a better car. its also say 20k more than a GT-P but when you're spending 80k spend an extra 20 and buy the better car. Ohh and as for the bloke who made mention about the I6 turbo powerplant. This engine is a marvel of Australian engineering and a Miami v8 doesnt even come close. |
04-06-2015, 06:09 PM | #55 | ||
When you say numerous mods what do you mean? There's a performance shop that recorded high 10s out of one on street tyres with a pulley upgrade, extractors and hi flow cats, Cai, and a tune.
Pretty basic mods. What times are coming out of tune only GTs? |
04-06-2015, 07:00 PM | #56 | |||||
I think you misunderstood 40RDT’s post. He's asking a question of GTBenny’s post. Quote:
Smile - I dare you |
04-06-2015, 07:15 PM | #57 | ||
04-06-2015, 08:38 PM | #58 | |||
Are you talking about Active Automotives GTS in WA? I think it has run a mid 10 with those mods, on stock rubber too. Good number for such minimal mods
FG XR6T Ute
300rwkw |
04-06-2015, 08:46 PM | #59 | ||
Stock rubber running mid 10s? What type of stock rubber are we talking here again?
GTF Smoke with Black stripes. |
04-06-2015, 09:10 PM | #60 | ||
275 Continental ContiSportContact 5P
FG XR6T Ute
300rwkw |
