18-06-2012, 09:23 PM | #31 | ||
how did you go Uncle Ken?
18-06-2012, 09:32 PM | #32 | ||
www.sctflashtuning.com
The only answer is to fix the car properly , the fans are on for a reason
The car is in limp mode and affecting other things . Take it to a professional and have it looked at .
Australia's No1 Ford Enhancement Specialist 103 Northgate Drive Thomastown VIC 3074 Phone: 03 9464 5100 Fax: 03 9464 5166 |
18-06-2012, 09:42 PM | #33 | ||
My fans have been on non stop for 6 months, it's a trans temp sender faulty, the wiring for it is $260 alone then labour to fit.
19-06-2012, 08:35 AM | #34 | |||
Next upgraded Mk1 Leopard
UK
19-06-2012, 09:42 AM | #35 | |||
Walking with God
GK
19-06-2012, 01:24 PM | #36 | |||
I'll be in Melbourne this weekend Uk
19-06-2012, 02:14 PM | #37 | |||
Walking with God
Once JC fixed (he's particularly good at doing that) the pod in the dash (replaced it with one from another high series dash), it was all good, and has been ever since. GK
04-07-2012, 11:21 AM | #38 | ||
Update..
Got the car to a sparkie today. Turns out one of the two fans had 'jamed tight'. So the second fan was spinning twice as fast to make up for it. Will have a closer look today to see what caused the drivers side fan to jam in the first place. UK
13-06-2014, 06:16 PM | #39 | ||
hi I have the same problem as fan stays on but have noticed ac is on it does not display on at the console at all but the compressor is still engaged so my ecu thinks ac is on so I can not turn fans off without removing fuses I have disconnected wire at front of compressor so that stops running could it be ac switch on console be at fault
13-06-2014, 08:57 PM | #40 | ||
Bugger. Mine was just the fans in the end. After I put in a new one one problems
UK
15-06-2014, 09:24 AM | #41 | ||
Walking with God
Job done!
GK
26-06-2014, 09:29 PM | #42 | ||
Q - CAR
Hey Uncle .... just read quickly though your post and it seems you needed to replace your fans to resolve problem?? Correct and if yes ... where did you buy fans from ??
Reason - my car has the same issue ... and looking to your resolve.
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. |
26-06-2014, 09:58 PM | #43 | ||
Hi Bluestripes,
I went to pic and pay less, got one out of 'good' wreak, checked I could test it on the spot, took it outside and powered it up straight away to check they worked. All good. didn't cost to much. Did the same when my son in law smashed my old AUII and wreaked the fans. UK
2 users like this post: |
