#31 | ||
It’s been more white smoke with this one, the number of head/bore issues over time.
I’ve read that the original PCM/TCM config can be heavily edited for immo bypass and a bunch of other deletes relating to body control, is this actually correct? To “strip down” a PCM/TCM to run a standard (ute?) map with no ABS, no dash, immobiliser off etc, would be the ideal goal. |
#32 | |||
Thailand Specials
#33 | ||
I meant the GM electronics.
#34 | ||
Thailand Specials
2 users like this post: |
#35 | ||
so what is it?
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
#37 | |||
Ahh OKay, I'm confused...
![]() Quote:
#38 | ||
Sorry, the thread meandered.
![]() The empty van went to an arborist as a dog shed or grow room or something. I needed it out of the way promptly. The truck is the workhorse, trying to keep it running is the quest. |
#39 | ||
praek tih kl jo kr
The VN - VS series V6 you just pull the engine and trans including all the engine harness and ECU right up to behind the glovebox, from memory there are only 3 or 4 wires to make it actually run, the gauges and stuff you have to nut out using the GM wiring diagram.
#40 | |||
surley you could get a cheap mazda engine to fit
#41 | ||
2.7 out of an 2000s hilux/hiace. Good torque and will do a billion km, they seem to like turbos too...
