#361 | |||
3..2..1..
fully understand the flares, i had the same issue on my surf back in nz, but i got away with none at all, but i had the bunnings flares ready to go if the cops had a whinge lol. |
#362 | |||
#363 | |||
Constant annoyance
![]() well sort of any way glad to hear there is some actual plans for it, rather than the constant work in progress beaten up old hiluxes i've seen around
GT Club - no longer for ford enthusiasts, now for fat old men who need air con and power steering for the maccas drive through. |
#364 | |||
and dont worry i got big plans for it once i get my cortina out of the shed ![]() |
#365 | |||
3..2..1..
#366 | |||
#367 | ||
253 block and drop whatever crank in you want.
#368 | |||
#369 | |||
#370 | ||
http://www.carsales.com.au/all-cars/dealer/details.aspx?Cr=5&R=9284771&keywords=&trecs=29&__s id=12DF7CE7B208&__Ns=pCar_RankSort_Int32|1||pCar_P riceSort_Decimal|1||pCar_Make_String|0||pCar_Model _String|0&__Qpb=true&tsrc=allcarhome&__Nne=15&seot =1&__N=1216%201246%201247%201252%201282%2042949666 24&silo=1011
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. ![]() Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
#371 | ||
Mr. Multiple Projects
1985 KB laser Turbo white lightning 3 door EFI 1927 Model T 1998 GU Patrol 2004 Forester Turbo 2006 Corolla Wagon BLAAAAAAACK |
#372 | |||
#373 | ||
#374 | |||
#375 | |||
I totalled my XR6
I'd take the V8 over the 6 any day. That being said, I'm definitely not a fan of the 250s, never have been, never will be. I put them in the same "over rated" category as the 202. I now have my flame suit on, so fire away. ![]()
#376 | |||
The Thread Killa
This, however... ![]() ...is very funny, and is the definition of "WIN".
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle |
#377 | |||
Constant annoyance
it'd be a personal preference thing i guess anyway. I look at it this way though, they are practically the same size engine. But the characteristics of the 250 are more suited to 4wding than a 253 as the 250 has better low down torque, with its over square stroke. depending on how you set them up. So you're getting a better performing engine. (It's not all about max hp at 10,000 revs with 4wd's) The 250 is by far a more reliable engine also, far less prone to overrev damage and much cheaper in parts and replacements. Then there is the benefits of how much easier they are to work on. All straight engines are a godsend when you have to get the spanner out. That'd be the first time i have heard a straight 6 called over rated.
#378 | |||
I totalled my XR6
I'm more a fan of the 4.0 I6 used in Falcons EB onwards, mainly because I have more experience working on them etc. A couple of mates of mine have XBs and XCs with 250, one is cross flow, the other pre-cross flow... and they're both pretty gutless. I realise these are old engines but one has been rebuilt in the last 5 years or so.
#379 | ||
I saw a great win today for a personalised plate. Was on a Holden HSV something. Plate was (V8 2NV). Pretty clever I think.
#380 | ||
clever? 2nv type plates have been around for ages.
#381 | |||
#382 | |||
Constant annoyance
If you've had a play around on a properly set up 250 you'd sing a different tune (350 holley, alloy head, decent intake manifold, exhaust) great engines, some of fords finest work! the tractability and reliability - even when they should have failed - is legendary.
#383 | |||
Off smelting
#384 | |||
Boss 335
#385 | |||
Everyone walked past it thinking that it was a standard XR8. Including me... A second look made you realise it had only 2 doors and looking at the work done to the doortrims, seals & the like it looked very very factory. Great job for those involved
Official member of the OCMD Club "Semi - Silhouette" 2003 BAGT #514 2007 GT500 factory supercharged motor built! Sensation Blue 2011 FG GT-P # 101 KPM Streetfighter Monster 5.2lt MMR short motor / Stage 3 MMR heads / Boss 302 Exhaust cams FR20 Simmons / Tein Coilovers / Eaton Tru Track / Very scared 305/25/20" Nitto Invo's ZF fitted with a NIZPRO Stage 2 input shaft & Excedy Clutches http://www.fordforums.com.au/showthread.php?t=11408502 |
#386 | ||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
For those around Geelong I pulled up beside a Jag XJU.
I think I recall seeing it a few years ago, ill pop pics up tonight but lets see who can guess what it is? Old bloke owns it who i reckon did the work.
#387 | ||
Not so much a car fail but a driver fail today. At the traffic lights a 2pm, driver beside us opens his esky and grabs a can of XXXX. Oddly enough the make of car was...... talk about asking for trouble
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
#388 | ||
Browsing here and there..
We need more wins in this thread!
#389 | |||
moderator ford coupe club
although you need very little work to have more power than a 253, comparing them to a 253 is not fair. when i started driving in the late 80's, a 250 was compared to a 202/186, the 302 was compared to the 253 and the 351 to the 308. the biggest engine was compared to the competitors biggest engine. plus holdens have traditionally been smaller, which meant it was fair to compare their smaller engine to fords larger one |
#390 | |||
