#331 | ||
Hello GTLEGEND, I am chasing the boot badges for a BA MK2 XR8 sedan, please.
1. Falcon Badge 2. Series 2 Badge 3. XR8 Badge |
#332 | |||
Can get these badges for you. The Falcon and Series2 is actually one badge, $50 plus postage if required. XR8 boot badge, $65 plus postage if required. Cheers, GT |
#333 | ||
#334 | ||
Fantastic, could I please get some instructions of where to send some money / details please and I will get this sorted in a lickedy split.
#335 | ||
hi.
I have just checked ebay just now and Bayfords have the BA Falcon MK11 badge and the XR8 Boot badge. Cheers |
#336 | |||
Ford T3 Partsologist
see post 332 https://www.fordforums.com.au/showpo...&postcount=332 **
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() Last edited by Dingo; 29-05-2021 at 01:25 PM. |
3 users like this post: |
#337 | ||
![]() Join Date: Oct 2006
In relation to this thread https://fordforums.com.au/showthread...68#post6584168
a) do new Genuine Ford Brake pad come with new caliper bolts? b) What the price per caliper bolt for the FG Falcon and SZIi Territory? c) Is there any discount for bulk buying caliper bolts?
regards Blue |
#338 | ||
WT GT
![]() Join Date: Jan 2006
Hi GT, need the passenger side Windscreen Weatherstrip Insert Moulding for the Fiesta please. They are use once only apparently and this one has been on an off a few times
![]() https://www.ogulftour.com/index.php?...ucts_id=262353 2011 WT. Many thanks. |
#339 | |||
a) I don't think so, some come with shims, but I need to get confirmation and get back to you. b) Not sure which bolts you are referring to exactly so I have priced both as to change pads, you can just undo one slide bolt and lever caliper to one side, or to totally remove caliper from knuckle. Caliper to slide bolts: Territory/Falcon $23 each normally $28. Caliper to knuckle mount bolts Territory $6 normally $7.50 c). Discount is the same regardless if it 1 or 100, Ford don't offer bulk price discounts apart from the discount we are already getting for the Forum regardless of quantity. |
#340 | |||
$40 plus freight if need be.. Cheers, GT |
#341 | |||
regards Blue |
#342 | |||
But photo attached to assist, if you want a VIN number can also provide ![]()
Current rides 2014 FGX G6E Turbo Tuned by Walter@Oztek performance 504rwkw on e85/420rwkw on 98 with a PCMTec flex fuel tune Previous rides - 2010 FG GT (335 build #152) 437rwkw - 2012 XR6 turbo Ute 345rwkw - 2007 Force 6 (build #91) 330 rwkw - 2010 GTE (build #2) 425rwkw - 2010 50th anniversary turbo ute 365 rwkw |
#343 | ||
![]() Join Date: Jan 2005
Hi ,I have a FG G6E turbo (2009) and the red/white courtesy light has broken in the drivers door.
Are these fittings available? If they are available what is the cost? Thanks for your time. |
#344 | ||
WT GT
#346 | |||
#347 | |||
The door trims are obsolete unfortunately. |
#348 | ||
Thanks for trying
#349 | ||
Hi GT,
Am chasing set of genuine roof racks for a 2013 ford territory. Please let me know if you have any leads. Many thanks |
#350 | ||
Hi mate are you still chasing the door skin? I may have one available on one on my wrecks? Let me know
#351 | ||
#352 | ||
![]() Join Date: Jun 2007
Hey mate, chasing a header tank for AU falcon, doesn’t need the sensor.
Proud owner of the ugliest Ford ever made |
#353 | ||||
#354 | ||
#355 | ||
Magna , Thanks for the information
#356 | ||
#357 | |||
VIN number attached in photo below. Cheers Graeme ![]()
#358 | |||
Can get you the 8 way side seat trim for driver seat. $130 plus freight if required. PM me if you want me to get for you. GT |
#359 | ||
I am after a Co2 sensor pre cat for a BF MK11 RTV any one know the part number ? I been advised to go stock.
TIA Marty |
#360 | |||
The sensor on the cat has a part number of 5W6Z9G444BA and can get for $260 + postage (normally $300). GT |
