Old 07-10-2006, 02:14 PM   #1
NARCEA
5/00 AUII Forte
Default holidaying without car
Hi folks,
I will be leaving my car for two months to work in India over summer. The car will be garaged and covered, however was wondering if it's worth doing anything else, such as disconnecting the battery, before I go. It will not be started in the time I am away.
Cheers,
Ian
05/00 AUII Forte
NARCEA is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2006, 02:26 PM   #2
LUXO_8
windsor user
i'd just park it.........2 months isnt that long really to leave a car parked...
if you're really pedantic about it, disconnect battery, park it with low petrol (so you can put in fresh and not have a tank of fuel that "might" be off) and change oil and coolant if you must when you return
Old 07-10-2006, 02:37 PM   #3
mcflux
mcflux's Avatar
^^^ What he said.
Old 07-10-2006, 02:44 PM   #4
NARCEA
5/00 AUII Forte
Thanks guys.
Ian
05/00 AUII Forte
Old 07-10-2006, 03:31 PM   #5
atec77
Originally Posted by NARCEA
Hi folks,
Cheers,
Ian
Disconect the battery unless you can trickle charge it and paump the tyres up a little more , when you return a filter and oil should be done. You might like to pull the plug and spin it over adding oil before you leave , it will smoke a little on startup but wont gall a bore then .
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2006, 05:04 PM   #6
zippy450
99' AU 1
if you are goin to park it for that long time, discount the battery and fill it to the top with fuel to stop rustin in the tank and keep seals in pump moist. i know it is goin to cost but once you get back replace fuel and oils and coolant then it all should be sweet. well that is my thoughts anyways. it worked everytime i've had to park it for awhile for many of reasons
zippy450 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2006, 07:06 PM   #7
mcflux
mcflux's Avatar
zippy, the fuel tank is made of plastic ;)
Old 08-10-2006, 05:30 PM   #8
zippy450
99' AU 1
ok cool a plastic tank well yeah now i feel stupid....lol
