09-07-2006, 07:12 PM | #1 | ||
I've got a 1300 HC Escort motor in a 69 Corty, when i separated motor and box I noticed there was no spacer or stone plate to protect the fly wheel. Does anyone know where I can one in Southeast Queenland as the wreckers are struggling to find a second hand one.
10-07-2006, 10:19 AM | #2 | ||
Are you running the mk 1 Escort gearbox with the intergral bell-housing or the later Mk 2 gearbox with the separate bell-housing? I have a few spacer plates for a 2lt, which uses the same gearbox as all the mk 2s 1300/1600/2lt. I'm pretty sure it will fit a 1300 x-flow as my mk 1 escort van has a Mk2 gearbox (which also allowing me to use a bosch 2lt starter motor.)
PM me with your details and I'll send you a plate for the cost of postage. I'm in Melbourne. |
10-07-2006, 10:24 AM | #3 | ||
ohhhh.....Disregard everything I just said if you are still running an hydraulic clutch.
13-07-2006, 09:02 PM | #4 | ||
Hey dude, appreciate your offer, it's running a cable clutch, seperate bell housing (internal bolts), starter is on the passenger side, if this sounds right let me know.
02-08-2006, 05:04 PM | #5 | ||
hey,guys.Any of you know where I can get a floor shift gearbox for a Mark2 corty as I have the dreaded column manual.Itll have to have all the bits like ,stick etc to go with it.Or if you know a wreckers in Brisbane that might have one.
Cheers lotusman69 |
02-08-2006, 06:46 PM | #6 | ||
I've just taken the close ratio GT box out of my panel van. It was original fitted to a GT Cortina, but was converted to cable clutch. Open to offers.
02-08-2006, 06:52 PM | #7 | |||
02-08-2006, 08:18 PM | #8 | ||
wats hc
02-08-2006, 08:20 PM | #9 | ||
High Compression
