Closed Thread
Old 21-05-2021, 08:59 PM   #1
ben131185
Default ac blower fan
got an issue with the fan.
aircon and heater are working fine when the fan is running.
fan generally wont run, turn it upto full and give an area under the glove box a hit and the fan kicks in, sometimes comes on if we hit a bump in the road too.
once its running it seems to stay on, but does fluctuate in power to some extent.
i'm assuming the fan is stuffed.
has anyone here had a similar problem?
ben131185 is offline
Old 23-05-2021, 10:18 AM   #2
russellw
russellw's Avatar
Default Re: ac blower fan
It's possible that the bearing in the fan is stuffed but if it isn't noisy when operating (like a bearing noise) then it might just have something blocking it.
russellw is offline
Old 23-05-2021, 10:44 AM   #3
11ford11
Is this on all speeds including hi speed
Check for power and earth on wiring also check for burnt connections
If it starts working by giving it a tap with a hammer then probably fan motor is kaput
11ford11 is offline
Old 23-05-2021, 09:29 PM   #4
ben131185
yes its on all speeds.
ill have to get in behind the glove box for a closer look.
from what i've read its a complete dash out job to replace the motor which i dont think i'm keen on doing.
Old 23-05-2021, 10:34 PM   #5
mad2
Regular...with metamusal
deleted due to wrong section .... thought i was in "B" series, instead i'm in "AU"
mad2 is offline
Old 23-05-2021, 10:39 PM   #6
On an AU, it’s dash out. Truly.
Should’ve quoted you before you edited your post!
Ah well, here’s a picture of Kim Kardashian in a bikini, just to fill out the post a little.
Citroënbender is offline
Old 03-06-2021, 09:02 PM   #7
ben131185
well i cant see anything wrong by looking at it. i'm guessing the fan motor is flogged out.
ill leave it as it is for now.
Old 08-01-2022, 11:14 AM   #8
ben131185
the fan is not working at all now.
i can get a used replacement for $75 (nothing available new)
has anyone removed the dash/replaced the blower motor before?
dash out seems like quite a big job, and i cant really find any info on this.
Old 04-02-2023, 01:09 AM   #9
Peterceez
It’s be hide the glove box. 2 screws and a plug. That’s where it is in my FG Ute and same place for my TDi territory
Peterceez is offline
Old 04-02-2023, 06:22 PM   #10
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Peter look at the date. Wrong forum.
Uncle_Ken is offline
Closed Thread
