#31 | ||
Would be an issue getting it past emissions testing I reckon - you'd probably need to scab the engine management system out of a stacked converted and complianced F250 as thats the only vehicle in our market using that engine.
#32 | ||
Listen to that whine! Kick 'er in the guts, Barry!
Perfect they used an XA, perfect for a post apocalyptic future where Australians are fighting over what energy reserves remain...
I6 + AWD |
#33 | |||
#34 | |||
Peter Car
#35 | |||
What is the rules around engine conversions - you can't go older than the body of the car and if you go newer it needs to meet the emissions of the newer vehicle you got the engine from. |
#36 | |||
What happens if you import and engine from a country that has little or no emission regulations? |
#37 | ||
Yeah I'm interested in this too, how does it work when its a crate motor?
#38 | |||
The Steering shaft position and Exhaust has always been the issue with the Territory The only V8 one I know of was was a Falcon Chassis with Territory Body, which I don't think was road legal perhaps this can be overcome with Turbos, take a look at the Miami XW in the build section and see what modifications are involved
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
#39 | |||
#40 | |||
they don’t actually do a full smog cycle test ya know… |
#41 | |||
found this on FB https://www.facebook.com/watch/?v=823749231030658 https://www.facebook.com/watch/?v=820796224659292
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP Last edited by Vesper Martini; 31-05-2022 at 11:09 AM. |
#42 | |||
#43 | |||
More a re-bodied V8 Falcon than it was a V8 Territory IMHO.
#44 | |||
If it’s branded as off highway, you can’t use it in an emission regulated vehicle (eg 350 SBC/454 BBC with carb hot cams). Maybe permitted with LPG and cat converters. If it’s an OEM replacement for a late model vehicle then it’s permitted provided all emission gear is hooked up, OEM harness and ecu, they normally just use a scan tool to check for fault codes… |
#45 | |||
#46 | ||
#47 | |||
FGII FPV F6 #406 BFII FPV F6 Typhoon R Spec #118 VK HDT Group A/Group 3 #3249 |
#48 | ||
#49 | |||
Sick Puppy
