Swaytan
Hey Guys,
Regarding car audio, what the heck is a Capacitor for? They look like they've got something to do with power... |
Swaytan your a smart guy. A capacitor stores power. I need one for my car because when my sub is actually being used at a high volume level, my headlamps dim to the bass. A capacitor stores the power so it can use that rather than draining the battery and making the alternator working harder
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
beep beep
Think of it like a battery. However think that a battery stores long term power, and a capacitor can cover short term power. For instantanous requirements a capacitor can cover it far better than a battery and stops the dip (see FOCUSonTHIS for dipping headlights) from happening.
Capacitors can do more, but they store charge. Thats it. It is how the power gets drained out of them by the rest of the circuitry and 'capacity of charge' that depends on how the capacitor covers the dip.
Nothing to see here, move along, move along... |
#4 | |||
GT4.
![]() LOL |
#5 | |||
GRRRR.....
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit. Gone but not forgotton - Diamond White 2004 LX Fiesta If you sneeze with your eyes open, do your eyes pop out??
Get in the van!
Isn't the licence plate rattling in time with the headlights as well?
The Dad Bus (TM): 2004 BA XT Wagon, soon to be set up as a camper and tourer. |
Clio 182 CUP!
Hey - My cousin's VL Turbo does that.....
Lights, numberplate ; but you forgot to mention the rattling boot lid!
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
#8 | |||
GT4.
Capacitors are a waste of money and pointless. With you money your MUCH better off getting your grounding pointed fixed up (Not only amp/s but also battery grounds), getting a new aftermarket battery and new cabling if required.
Even just fixing up your grounding points will stop dimming in 90% of cases and a new battery is always a good idea and will give you more voltage (POWER) to play with. Don't waste money on a capacitor.
COLORADO RED FIESTA ZETEC MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes. ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001. |
#10 | |||
Swaytan
haha,
a friend of mine once went on a drive with a mate that had a subaru rx wagon. ALOT of base and abt 1 hr later they arrived home to find no back window... ive also seen people that dont have a rear vision mirror cos of too much base... it jus doesnt stick anymore. |
#12 | |||
Swaytan
I also had no idea that sort of thing could happen... Though, I've played with bass players that have bass amps so powerful, the retinas in your eyes shake every time they play a note... |
#13 | |||
striped
and considering that the stereo is powered by the alternator when the car is running, the battery has very little to do with it. a "good" battery is only helpful if the car is off. with regards to the capacitor, compare it to a power regulator. the amp gets a very consistent 14.4v (or 12v) without any fluctuations due to the alternator maxing out |
#14 | ||
Josh. do you have any idea what your talking about? I think not.
Batteries do not always put out 12V. When fully charged it will be maybe 12.5V and when empty much less. The aftermarket battery will keep its charge longer and thus you can play louder for longer. A capacitor is only for show. If your having troubling giving your amp good voltage a capacitor won't help. What will help is getting your cabling done right. THEY ARE SIMPLY A WASTE OF MONEY
#15 | ||
Focus Rookie
i agree with pioter that is certaintly the jist i got from reading on the websites and caraudio forums..
The voltage isnt always constant, why is there voltmeters on some amps and caps?! Even amps quote specs in 14.4v and 12v.. Caps are too expensive anyway..!!!!
04' Panther Black Focus Zetec Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters |
#16 | |||
beep beep
However, if you get a trough in your DC supply (eg sub 9volts) and everything else should be up to scratch (0 gauge cables, quality earth's, quality battery, etc), then this can cause your AMP's power to flicker on an off just like a city grid brown out. This isn't 'healthy' for solid state electrics. However if you are dropping down sub 9volts from a 12/13.8/14.4 volt supply then you have bigger issues that a 1FARAD or multiple capacitors will mask. You could be hurting your car's ECU, injectors, etc. I agree that a capacitor is extranous for most installs - however they have become part of the 'scene' and become a must have, and an easy fix for installers rather than ensuring that things are done properly from day one.
#17 | ||
striped
pieoter, did you read any of what i said before firing off that poorly thought out statement?
when the car is running, the battery doesnt power anything. therefore, whether its a new battery or an old battery, its irrelevant. so the voltage fluctuates from the alternator, its not only running the stereo is it? its got other ancillaries to power as well. what an aftermarket battery does is allow to you play the stereo whilst the car is off for longer. does SFA when the motor is running. and the reason why amps quote 14.4v and 12v are because they are the voltages that exist when the car is on (alternator is at 14.4v because it needs to have a greater voltage than battery to charge it) and 12v is when car if off and its running off the battery. with regards to a capacitor being extranous, ive found it to be useful. i ran an upgraded 130amp alternator, an odyssey 600 redtop, 2 gauge to the rear, and still found that lil charge light on my capacitor dimming a bit. and yes, i did do the earth cables, from the alternator, and also from the battery. |
#18 | ||
Swaytan
Look at what I've started...
#19 | ||
Yeh, good work Josh you know how a car electrical system works. Do you want a ИИИ medal?
If you got light dimming issues you simply didn't do the wiring properly. Capacitors are for show and to cover ИИИИ installs.
#20 | |||
GT4.
#21 | ||
GRRRR.....
maybe everyone should calm down a little bit, we don't want to scare all these new members away now do we?
#22 | |||
striped
i never said i had dimming headlights. i said the charge meter on the capacitor blinked every so often. you should also learn to read |
