Can anyone tell me the unmodified front speaker size for a Ford Falcon Forte Au1 and also the back speakers?
Are the front 6" or 6.5"? Thanks gents |
5x7 all Round..
6" will fit in the hole though, and will fit even better with a spacer.
AUIII Falcon Forte, with SIX Appeal |
#3 | |||
from what ive read
you get a piece of 10mm MDF.. make a template from the 5x7 hole in the front door so that the mdf covers the hole.. then cut ur 6.5" speaker hole out of the mdf spacer fit speaker and spacer to door and voila!! the door trim fits back on without interference ive never tried it but plan to do so soon.. hope that helps a bit good luck!
Have tried this and mounteed a tweeter in there as well.
You can see the MDF behind the grille .... I haven't painted it yet. ![]()
do you get a good sound with the tweeters there, i have mine mounted directly above in the triangle part in the corner of the window frame. they have a good sound there
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
