Does anyone have any pics of the in dash frame for the genuine sat nav?
Thanx
Graham South of DARWIN NT AUIII Flash Cab project (nearing completion) |
XR6T BA 2002
XR6T 2002 BA
I need pics of the frame that bolts behind the dash to hold the sat nav screen. It is completely different to the standard head unit framework.
Thanks any way.
Thank you, Thank you, Thank you.
No worries. They're probably the best of the photos I took, but I do have more.
That last pic, I was making some paper templates which could be used to replicate the brackets in the future. The bracket to relocate the head unit and mount the LCD unit are just spot welded in over the "standard" dash frame, so a standard frame could potentially be converted in situ. I opted to remove both dashboards, disassemble both dashboards and swap the entire internal metal structure, which is when I took these photos. What are you up to? Looking to add SatNav to your AU? |
I am wanting to do something similar, without using all the genuine gear (the map updates are just way too expensive). Your pics may allow me to modify what is already in the car, without having to track down an original sat nav frame (I can leave it for someone who wants to stay all genuine).
