Guys, we have an AU2 SR and it lacks power. There is a slight misfiring, noticeable at idle speeds. Cars been serviced recently by a repairshop that does taxis. They reckon that everything's ok, i say it's a load of bull!!. Compared to another AU2 on duel fuel with no mods, the SR comes out 2nd best by a mile. The takeoff is sluggish and i'm a bit suspicious about the fuel ecenomy too. I think it's time to pull the old toolbox out! What do you guys suggest?.
Freedom is a wonderful thing!...... |
Formally Kia Chaser
Might have the wrong spark plugs then - or they've touched the idle settings.
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
Miami Pilot
![]() Join Date: Jan 2005
Could be plugs, leads, coil pack, clogged TB, air filter, trannie on the way out, O2 sensor, MAP sensor, blocked cat/exhaust, inlet manifold leak.........
@jc. Thanks m8, ya made me feel really good! (er, wanted!!). Missus will have me slaving now. I AM going to change the plugs and the leads and take it from there. Will keep you guys posted. Thanks for the replies, guys. :evil_laug
#5 | |||
Miami Pilot
Topgun sells a lead kit for the AUs at around $60 for the 6 (or $200 odd for the V8s) - though make sure you get the right set for your month/year of manufacture as Ford changed the coil pack clips on the I6s early on in 2000 (March, IIRC). Plugs and leads always the first things to change, and just work from there. Let us know how you go - we can then give more specific info once you have ruled some things out.
check that the accelerator cable gromets are in all good condition. ford did a recall on some AU's as the grommet became faulty and there was a severe loss in power. this may be something to check out. www.recalls.gov.au
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
