Old 01-01-2014, 08:45 PM   #1
SILENT_RAPTOR
Default AU1 and AU2 rotor's
Ive got the majority of the setup I need to change over to au2 brakes, the only thing I don't have is the rotors.
My question is, is there a physical difference between series one and series two rotor's?
Pretty much bought new rotors and pads a few months ago before I decide to change to au2 twin piston setup.
AU1 XR8 btr
GT40p setup
14.341@95.91mph
TFS 185 heads setup
13.853@100mph
Baby 60-1 t4
11.7@121mph 12psi
SILENT_RAPTOR is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2014, 09:35 PM   #2
FTe342
FTe342's Avatar
Default Re: AU1 and AU2 rotor's
Completely different set up
New rotors slide on over studs and are held in place by wheel
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2014, 02:02 AM   #3
SILENT_RAPTOR
That's how they are with series one as well ,besides how they go on as I don't see any difference and see no reason why I cant just reuse the rotors that are already on it?.
AU1 XR8 btr
GT40p setup
14.341@95.91mph
TFS 185 heads setup
13.853@100mph
Baby 60-1 t4
11.7@121mph 12psi
Old 02-01-2014, 02:31 AM   #4
AU1XLS
AU1XLS's Avatar
They are different specs from DBA Cat
Series 1
Dia 287mm
Thickness 24mm
Height 70mm
Min thickness 21mm
Series 2
Dia 287 mm
Thickness 28mm
Height 65mm
Min thickness 25.6mm
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2014, 08:56 AM   #5
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
You'll need the new discs but don't forget the matching S2 callipers either. But if you're going to go that far anyway, bypass the S2 discs and callipers and go straight to BA discs and callipers. They are a direct bolt on for AU S2, they are bigger again and are a marked improvement over AU brakes.
MINE- AUII Forte
Old 02-01-2014, 12:02 PM   #6
bartsau
bartsau's Avatar
I have just completed the change from Series 1 to BA brakes. I also, had a set of series 2 brakes sitting here and I can tell for 100% sure Series 1 is not compatible with anything else! Not a massive visual difference between BA and series 2/3 but. By the specs the discs are about 11mm? larger in diameter so I think that speaks for itself. Hence I now have BA brakes on the front They are awesome compared with the AU 1's....
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 02-01-2014, 08:09 PM   #7
peterljohnson55
peterljohnson55's Avatar
Any recommendations for both supplier and price for a set of BA front slotted rotors and callipers for and AU2?
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2014, 09:07 PM   #8
Bushbasher
Bushbasher's Avatar
Mate, just go to a wreckers and pick up a pair of callipers. As for discs, some will tell you to spend up a bit for DBA or RDA etc but I bought a set of no name slotted discs on ebay and they have not been touched or needed looking at since fitting 80k ago, but I bought soft pads that don't chew up the disc. Sintered and metallic pads will eat the discs no matter what brand you buy but it depends on what you are looking for. If you want max braking then expect to chew discs. If, like me you want improved brakes over original and only need the occasional big stop then a softer pad will suffice. With my Fairlane, the new setup is still 2 car lengths better @ 110kph than original with the soft pads and that's good enough for me but I'm sure I could improve that another car length or even 2 with better pads ....but at the cost of the discs being chewed up.
Bushbasher
MINE- AUII Forte
Old 03-01-2014, 12:32 PM   #9
SILENT_RAPTOR
Thanks for the reply's, I got most of the brake upgrade from a series2 au for free off a mate who was throwing them out.
AU1 XR8 btr
GT40p setup
14.341@95.91mph
TFS 185 heads setup
13.853@100mph
Baby 60-1 t4
11.7@121mph 12psi
Old 03-01-2014, 12:51 PM   #10
GK
Walking with God
GK's Avatar
Thumbs up Re: AU1 and AU2 rotor's
Freebies are good when you can get them!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
