Old 11-08-2013, 07:40 PM   #1
GK
Walking with God
GK's Avatar
Default MB Diesel Filter Change Question
I was thinking of changing the diesel filter, as it looks like an easy job. What are your experiences of the bleeding/priming of the system?
My workshop manual states that simply turning the key over for 10 seconds (this can be done 3 times) could be enough to get the system primed again. If the car starts, the system is primed.
Has that been enough for you all? Or have you needed to purchase a bleeding kit?
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 15-08-2013, 08:28 PM   #2
commz
Default Re: MB Diesel Filter Change Question
Was enough for me, I just turned it to the position before ignition about 6 times and it started fine (MB Zetec)
commz is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2013, 11:57 AM   #3
nevetsg
nevetsg's Avatar
I happened to do mine last week. I tried turning the ignition on/off/on/off etc. but no go. I could see the air in the fuel line. Maybe I just suck and let too much in...
Anyways, I made this to bleed it out and it worked like a charm:
There are 2 holes in the lid, one for the bike pump tube and one to hold the end of the vacuum over.
Mondeo 2011 MC Titanium TDCi. Ink Blue.
RIP: Mondeo 2008 MA TDCi. Colorado Red, Leather, Bluetooth, sunroof, Tow pack. C.R. Tech tuning box
nevetsg is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2013, 02:35 PM   #4
GK
Walking with God
GK's Avatar
Thanks for the input guys.
I was beginning to wonder if the average Mondeo owner never did jobs like this! LOL!
Cheers,
GK
Now gone!
On LPG
Old 17-08-2013, 02:51 PM   #5
nevetsg
nevetsg's Avatar
It was pretty easy to change but required the biggest socket I had and a tub to catch the fuel.
I didn't have any clean diesel on hand to fill the new filter before installing. I am thinking that is where all the air came from.
Sent from my HTC Vision using Tapatalk 4
Old 17-08-2013, 05:57 PM   #6
GK
Walking with God
GK's Avatar
I'll ensure I get some diesel and soak the filter beforehand.
Did you get the filter from Ford? How much was it?
GK
Now gone!
On LPG
Old 18-08-2013, 03:31 PM   #7
nevetsg
nevetsg's Avatar
Just had to hunt down where I jotted down their quote. Too lazy to get the recept out of the glove box...
autopro carramar - 97235667
6/46 The Horsley Drive, Carramar, New South Wales
oil - $18.35
air - $30.35
fuel - $26.5
cabbin - $18
Old 18-08-2013, 04:53 PM   #8
GK
Walking with God
GK's Avatar
oil - $18.35
air - $30.35
fuel - $26.5
cabbin - $18
Cheers again.
nevetsg, you are becoming a good source of info!
Cheers,
GK
Now gone!
On LPG
Old 18-08-2013, 08:47 PM   #9
nevetsg
nevetsg's Avatar
I only know what I know from google and YouTube..
Nevetsg.
Old 19-08-2013, 04:17 PM   #10
GK
Walking with God
GK's Avatar
LOL!
BTW, could you take a few more pics of the bleeding gagdet you made up?
Cheers,
GK
Now gone!
On LPG
Old 19-08-2013, 04:36 PM   #11
nevetsg
nevetsg's Avatar
There is no more to take pics of... Other than my vacuum...
**By no way am I a mechanic or subject matter expert**
-The tube is a standard bike pump extension and there are 2 holes in the lid of a jar.
-Drill 1 hole big enough for the bike pump tube and screw it in (connection was not perfect).
-I just drilled my 2nd hole the same size, you can see it just before the 'Dolmio'.
-Connect the pump tube to the top of engine, over to the right with cover off.
-Start up vacuum and place over 2nd hole. Diesel should start to splutter and flow into the jar. you can see how much I sucked through.
-First start took a few sec of cranking because I still had the rear in the air so the bleeder was not level and the most high point.
-checked the seal around the new filter for leaks.
-Took pic of my new tool for the forums.
-Poor fuel back into the tank using the high flow adapter thingy.
-Tackled the evil that is the Cabin filter change. But that is another story.
Old 19-08-2013, 06:17 PM   #12
GK
Walking with God
GK's Avatar
No worries!
By vacuum you mean the vacuum you created when you cranked the engine right?
I also have changed the cabin/pollen filter. It was a right royal pain in the butt. Next time I will replace the hex screws with Phillips head screws to make it easier to get them out with screwdrivers.
GK
Now gone!
On LPG
Old 19-08-2013, 06:29 PM   #13
nevetsg
nevetsg's Avatar
By vacuum, I mean one of the things you use to clean your carpet. Stick the end of the hose over the hole in the lid to create a vacuum in the jar.
Nevetsg.
Old 20-08-2013, 08:51 PM   #14
GK
Walking with God
GK's Avatar
Nevetsg.
LOL!
Thanks!
GK
Now gone!
On LPG
