Old 02-04-2013, 07:05 PM   #1
CONGO MILLENNIUM
Default Replace cig socket in AU
I ve searched but I can't find how to replace the cig lighter socket in our AU2 forte. Can it come out from the front or does the centre dash need to come out to gain access? Some thing was jammed into the socket then removed now the fuse keeps blowing. 😠
CONGO MILLENNIUM is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2013, 09:14 PM   #2
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Default Re: Replace cig socket in AU
From memory you need to take the stereo out. This will give you access to the ciggy bolt that holds it in.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2013, 10:11 PM   #3
CONGO MILLENNIUM
Thank you Evgeni apart from needing those u shaped thingies to take out the radio will I need to disconnect any thing else? ����������
Old 02-04-2013, 10:32 PM   #4
Evgeni
Auto Nerd
Evgeni's Avatar
Ok just had a look. Take the stereo out, take the ash tray out. There is 4 screws that hold the front panel in. Two behind the ash tray and the other two along the top outer edges of the stereo recess. This frees the front panel and it looks like the ciggy lighter just pushes in or pushes out once you undo the spade connector.
Old 03-04-2013, 03:29 AM   #5
CONGO MILLENNIUM
Thanks mate ill give it a go
