Old 11-09-2012, 11:38 PM   #1
BHDOGS
Default Diff change now no traction control or abs
I changed my series 2 au diff for a diff I brought now in told the diff I put in didn't have the tone wheels for the abs sensor ect. I'm advised an axle
Change will fix this by putting them on is this hard to do and doable at home anybody done a write up? Cheers
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2012, 01:19 AM   #2
Nic302ef
Cocoloko
Nic302ef's Avatar
Default Re: Diff change now no traction control or abs
assuming its live axle? no very easy to change axles, dismantle the brake set up on each side, undo 4 bolts holding the bearing plate in place, adn slide the axles out, sounds easy, but depends how often you swing spanners i guess.... if you installed the diff your self it shouldnt be a problem.
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build.
2010 Territory: family bus.
79 P7 LTD 351.
Nic302ef is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2012, 12:45 PM   #3
BHDOGS
Yup live axle sounds sweet I'll try it myself no bearings needs to be replaced or anything? And I'm assuming the diff oil will need to be drained
Old 15-09-2012, 06:37 PM   #4
Nic302ef
Cocoloko
Nic302ef's Avatar
can re-use the bearing they will be fine just re-use the same cup thats in the diff housing you pull your axles from
79 P7 LTD 351.
