Old 23-05-2012, 08:05 AM   #1
ab56452001
Default Uhf
Hi, thinking of fitting a Uhf/Cb, reckon i can of run it of the cig lighter to keep the unit portable, only uses 5w max so should be o'k'. Might put antenna on a front light bar,fender or of the tow bar with a adapter, does anybody know a place that sells front pax side fender mounts already made up ?,cheers.
ab56452001 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2012, 08:42 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Uhf
Hi ab5632891649346124
Check out prestigecom - they usually have a pretty good range of UHF gear.
Why do you want to run an in-car unit if portability is a concern?
Personally, I run one of these: http://www.prestigecom.net.au/index....oducts_id=2008
It's a 5w handheld. When you say your UHF only uses 5w max, are you talking about the 5w transmit strength? Or does the unit only draw 0.42A @ 12v? I'd find that number to be a bit low.....
As for antennas, have you considered the option of the old magnetic base? I'm considering getting one for my handheld.
But if you want to go the screw-on path then prestigecom (amongst many other places!) will sell you a very good antenna and a bonnet mount for under $100 easy.
Old 23-05-2012, 09:27 AM   #3
ab56452001
Default Re: Uhf
Thanks for reply, i also have a Jeep Cherokee that i want to be able to swap over the radio with when i go on trips, id like to keep an antenna fixed in both just makes it easier i reckon,cheers.
Old 23-05-2012, 09:47 AM   #4
ab56452001
Default Re: Uhf
Its me again !, just looked it up, .5 amp recieving and 2.0 amp sending, should be no probs,ta.
