Old 28-12-2011, 06:29 PM   #1
oldtimeraver
Default au ford alternator help
A very avid reader of this forum first time posting
Need help with my au s2 fairlane alternator its only 9 months old qnd now it seems to only want to work when it wants to one minute its charging than its not its driving me crazy please help anyone
cheers jason
oldtimeraver is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2011, 07:14 PM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: au ford alternator help
Hi Jason and welcome. Is your Fairlane a 6 or 8 and is your power steering pump above it and is said pump leaking by any chance? It could be that your alternator is full of hydraulic fluid.
Bushbasher
MINE- AUII Forte
Old 28-12-2011, 08:23 PM   #3
oldtimeraver
my fairlane is a 6 and the power steering is not leaking replaced the hose when i fitted the alternator
I just think the car dosn't like me now after the work ive done on it in the last week eg; new ball joints, front brake upgrade, plugs oilchange and flush ...lol
Old 29-12-2011, 01:02 AM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Doesn't hurt to degrease it anyway
Have you double-checked the plug and charge wire? Also the main fuse may be worth a look...
The alternator earths through the case, were the bolts and holes relatively clean when you fitted the new unit?
Any specific engine revs or conditions where it won't charge? i.e. full throttle, idle, etc...
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2011, 06:36 PM   #5
oldtimeraver
problem found faulty diode found a auto elec that was open and had him check it out so new alternator
Old 31-12-2011, 09:27 AM   #6
Bushbasher
Bushbasher's Avatar
That should be a warranty job. Take it back to whoever you bought it from and get it swapped.......... unless it's an Ebay cheapy of coarse, but even some of them have a 12 month warranty if you check the fine print.
Bushbasher
MINE- AUII Forte
Old 03-03-2012, 11:11 AM   #7
Big Chris
Hi all,
a bit of a thread hijack but along the same line,
was looking at an AU 3 yesterday,
I am wondering what side effects a faulty regulator / alternator has on the dash / air con / accessories?
What it was doing is the dash plays up, the guages drop to zero after the battery light comes on, it seems to go back to normal after the battery light turns off.
It only does this after the car warms up, seems fine when the engine is cold. This does not seem to cause any issues of with the running of the engine, it still drove fine and indicators etc still function.
I still have to go through the engine bay and check wires etc, the battery terminals look suspect as well as some lugs attached to the terminals not being fitted very well and are dirty and corroded.
Is there a return line on an AU like an ED that feeds information to the dash for the battery / alternator light?
Thanks all
Chris.
Big Chris is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 01:21 PM   #8
BREEZEMONT
Registered Menace
BREEZEMONT's Avatar
From an ex Bosch Regulating Diode assembly worker I can tell you first hand I'm not surprised..
Rides = Numerous Chryslers & The making of the AUII Breezemont wagooon
BREEZEMONT is offline   Reply With Quote Multi-Quote with this Post
