15-11-2005, 03:23 PM | #1 | ||
T3/Sprint8
I'm sorry being lazy here, now that I have gone to a Boot Lid look at the rear I think I better get my brake light working inside the rear window before I get tailed by a Patrolman and get booked for something so stoooopid : :
They are obviously not connected having the usual spoiler fitted with the brake light in the wing, has someone done this before ? Is the bulb just missing or fuse or what ????? What bulb do I need to buy,or maybe it's in there,should have a closer look I suppose. How do I get to this tight little situation ? Thanks in advance :
Tickfords T3/TS50 '02 Sprint8 manual Sept 24 '16 Daily Macan GTS "Don't believe everything you read on the internet. Abraham Lincoln" Last edited by FTE217; 15-11-2005 at 03:30 PM. |
15-11-2005, 03:50 PM | #2 | ||
Barra Turbo > V8
On my XR i have the stop light on the spoiler and also the one inside the window dunno why u dont have u ever had the window light working? It could be just a broken globe
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
15-11-2005, 03:56 PM | #3 | ||
I may be wong, but if you have a spoiler the rear window light is not connected ( by means of just leaving the globe out ) as the law states you should only have one rear ( central ) brake light.
without the spoiler all you need to do is intall the correct globe into the existing rear light and from memory look up inside of your boot for access. Cheers Pete |
15-11-2005, 04:06 PM | #4 | ||
they call me Tibbo
its a large wedge bulb iirc
15-11-2005, 04:06 PM | #5 | ||
Miami Pilot
Blue Driver, Not only is the bulb not there, but the red glass/perspex/diffuser is also not there. If you look carefully, you will notice that it is a piece of black plastic taking up that space (at least in series 1 XRs). So, you will need to get a rear brakelight from Ford, or the wreckers. I got mine for $15 from the wreckers when I was driving around spoilerless for a while. You will also need a bulb.
To change the black plastic to the proper brake light, you need to remove the rear parcel shelf cover. It's pretty easy - just get some new Xmas tree lips as the old ones will be buggered.
15-11-2005, 04:18 PM | #6 | ||
not here much anymore
Maurie it should be a simple matter of putting the bulb in.
RAM 1500
15-11-2005, 04:33 PM | #7 | ||
T3/Sprint8
Thanks very much fellas, cheeez something simple as usual seems a pain in the backside especially after JC's reply lol it sounds like they made it easier for the S3......thanks Aust after speaking with Darkhorse it seems as easy as just putting a wedge bulb in the it's place.
You are right DOC, here in NSW I know if you had the spoiler light all never had the window bulb connected. Thanks again for your help bulb shall be purchased on the way home.
15-11-2005, 04:33 PM | #8 | |||
15-11-2005, 04:34 PM | #9 | |||
Beat me to it : |
15-11-2005, 05:30 PM | #10 | |||
_Oo===oO_
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
15-11-2005, 05:59 PM | #11 | |||
T3/Sprint8
Again thanks.
15-11-2005, 06:10 PM | #12 | ||
FTF Car Club NSW
lucky its a simple fix, could see maurie coming down to work again for a little help
15-11-2005, 07:16 PM | #13 | |||
Miami Pilot
15-11-2005, 09:15 PM | #14 | |||
T3/Sprint8
21-11-2005, 08:58 AM | #15 | ||
Just looked at mine and its just like JC's. Just a plastic cover, no lens at all.
Looks like I'm keeping some sort of wing cause I couldnt be stuffed getting it all sorted.
