Old 14-11-2005, 07:36 PM   #1
blackbart
Posts: n/a
Default Pinging on light throtle
Hi all, my AU Forte pings really badly when cruising at 70+ km/hr whenever I go up a hill. If I accelerate harder it stops but if the throttle is only down a little (or on cruise control) its bad.
I just serviced the car, changed plugs, air filter, tightened inlet man bolts, etc. Fuel filter was done about 20,000ks ago. Injectors never been cleaned but not sure if that'll be the problem cos it goes away if I accerlerate.
Anyone got any idea's?
Thanks.
Old 14-11-2005, 07:57 PM   #2
sfr rob
sfr rob's Avatar
hey.. no one has ever explained to me what pinging is.. can ya tell me what it feels/sounds like?
hope someone can help you mate!
rob
sfr rob is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 08:02 PM   #3
Stav
Smile
Stav's Avatar
You should try a different fuel.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 14-11-2005, 08:33 PM   #4
buickman
buickman
buickman's Avatar
rob
The mtr sounds as if marbles are rattleing in a jar. Mainly happens when a load is put onto the mtr such as going up hills. You need to put a higher octane fuel in it to stop it or on mtrs with dissy retard it a bit.
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 09:27 PM   #5
blackbart
Posts: n/a
I fill up at Shell, BP, Caltex, whatever is closest when I need fuel so its not like its the same servo all the time. I just use regular unleaded like I always have and its only been pinging recently.
Premium is a last resort simply due to the cost, but I spose its cheaper than a new engine.
Old 14-11-2005, 11:02 PM   #6
JC
Miami Pilot
JC's Avatar
I would check your exhaust gasket - sounds like a split gasket to me. It's pretty rare for an I6 to ping if the motor is still stock.
Ford Performance Club ACT
Old 15-11-2005, 05:12 PM   #7
sfr rob
sfr rob's Avatar
hmm so thats what i have.... i noticed it... especially when its cold... it sounds like ball bearings in side a mug rattling around...
i use high octane unleaded everytime i fill up...
but i am on LPG to!
thanks for the explanation!
rob
Old 15-11-2005, 05:15 PM   #8
buickman
buickman
buickman's Avatar
If the mtr is overheating it would cause it to ping as well. Ive never encounted it in a car with injection only on the older carby cars with cams that are fitted with large lifts & duration & running low octane fuel.
buickman
Old 17-11-2005, 01:44 PM   #9
blackbart
Posts: n/a
Thanks for the advice.
Might chuck an exh gasket on to be safe.
Motor is stock and doesn't overheat.
