01-11-2005, 12:31 AM | #1 | ||
hey guys am looking for a motor to build for a turbo setup i have a ef flacon i6 and was wondering what the difference between ef and ea motors are cause i can get a centre point ea motor for nothing should i build this up?? are the blockes the same? i would be putting new pistons in etc could i just work the ea head to ef spec or could i put a ef head on what do you guys think??? cheers guys
http://i11.photobucket.com/albums/a1...50/cartoon.gif |
01-11-2005, 12:36 AM | #2 | ||
the blocks are the same but if i was you i would work the EF head and make it better
95 EF Futura. Ported, slotted, lowered,mags,2.5" Exhurst inc CAT, extractors,Manual,brass button clutch,Limo Tint,Trip Comp, Full Blue Dash, Dual Battery and one kick A$$ Sound system. |
01-11-2005, 01:01 AM | #3 | |||
01-11-2005, 01:12 AM | #4 | ||
so i could use the block? but buy a ef head then it would basically be a ef? cause it will be a slow build up so i couldnt work my original motor and when its done will be transplanted
01-11-2005, 01:21 AM | #5 | ||
Last warning
use the EF head, and use nicely dished pistons in either block
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
01-11-2005, 01:28 AM | #6 | |||
01-11-2005, 01:29 AM | #7 | ||
Last warning
honestly no idea.
Sooner or later i'll be looking into it myself, but i havnt bothered yet.
01-11-2005, 02:30 AM | #8 | ||
no doubt am goin to need to know brands on rods and rings etc so anyinfo would be cool anything else people can think of to tuffen it up?
01-11-2005, 09:59 AM | #9 | ||
Ute Forum Moderator
Use the EF crank
01-11-2005, 10:11 AM | #10 | |||
01-11-2005, 10:46 AM | #11 | ||
not really but the ef crank is a little better but it does not matter if you do all the right things to your engine like nitrating the crank and rods after market rods and pistons blue print and balance the whole engine and do the head
01-11-2005, 01:46 PM | #12 | ||
are they a differrent stroke or anything seeing as the ea motor is 3.9 and ef 4.0 ltr?
02-11-2005, 03:12 PM | #13 | ||
what do people think keeping in mind thhe motor is for free thats the only reason i am considering this
02-11-2005, 07:09 PM | #14 | |||
Ute Forum Moderator
Streeter I agree a properly treated & balanced crank is more important no matter which way you go. On a shoestring build like this one sounds like (practice build?) perhaps use the EA crank until you are ready to build a motor "properly" (as described in quote). |
02-11-2005, 10:28 PM | #15 | ||
might just go the ef motor then i think
03-11-2005, 01:15 PM | #16 | ||
likes falcon's
whys ef more pupular than el?
www.carhubsales.com.au |
03-11-2005, 03:02 PM | #17 | ||
ef look a lot better more meaner looking well thats what i think
03-11-2005, 04:24 PM | #18 | ||
do you mean body wise or motor wise?
03-11-2005, 04:35 PM | #19 | |||
Burnin Rubber
The EF motors had 12 counterweights as opposed to the EL which had 8, so its slightly smoother.
Also, the EF motors had coils rather than distributor like the EL went back too..
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
03-11-2005, 05:08 PM | #20 | ||
likes falcon's
look at the title of the thread guys... "ea and ef motors?"
whats this counterweight thing
03-11-2005, 05:50 PM | #21 | ||
front end wise (body)
