XRSVO
Howdy all
lately my rear suspension has felt a bit rough and noisy ,making me think about the faulty factory mounts. So today I rip the covers off and found that the top steel cap and rubbermount underneath have about a 10-15mm gap between (that cant be right???) so I decided to put my camera recording it while I bounced it up and down well the result has left me stumped ,I know how most things work but this is just weird ,is it the mounts or is it normal?????? cheers Joel the video of suspected problem, bout 2meg http://home.iprimus.com.au/swoopa/vi...tmountprob.wmv |
Miami Pilot
![]() Join Date: Jan 2005
Yep - that's stuffed. If the car's under warranty, take it back to the dealer and get it foxed. If not, then I would buy a set of nolathene bushes and install them under the nut on the mounting side, just to minimise the movement. I think my car has the same issue, as it's making a noise like that from the back somewhere, but only occasionally.
XRSVO
thanks for that
buickman
The IRS does move up & down like that but yours seems to have the shaft or ram sticking out of the rubber bush.
Remove the strut an easy job as every thing is complete & it might only be the rubber bush. I beleive it won't be a big problem. buickman |
XRSVO
yes Its like shocks shaft has punched its way through the mount, and the weight of car only rests on the spring tension
I went down to local dealer this afternoon and ordered a new set of mounts only $86 each, fit em up friday |
is the whole mount a cup type thing ..
with a metal wierd shape thing with a hole in the middle?? and it separates from the spring cup part?? |
XRSVO
YES I pulled out the struts yesterday and the mounts were shagged the little metal piece in the centre had separated moved a fair bit too ,new tops installed and raised my spring base up a notch to stop it punching through again hopefully, handles like new again
