Old 25-07-2011, 03:57 PM   #1
MattsDisturbed
Bseries
MattsDisturbed's Avatar
Default AU 1 Forte Electrical problems
Hey guys just wondering if anyone could shed some light on an issue the girlfriends AU series 1 Forte has developed.
All at the same time, the following problems started.
1. One headlight has stopped working properly, (only works when highbeam turns on)
2. Cruise Control won't engage
3. Central Locking won't open itself, (needs physical key to open)
4. and the clock (installed by me) doesn't light up unless the headlights are turned on.
Wondering if these components share a common circuit and whether a fuse may have set this off.
The only things done to the car recently were the installation of a clock but that has worked fine up until now, and I replaced the parker bulbs this weekend with LED items.
Any comments welcome.
Matt
His: 2003 BA Fairmont in Arctic White/Mercury Silver
Hers: 1999 AU Forte in Amaretto
Check it out:
http://fordforums.com.au/showthread.php?t=11336211
MattsDisturbed is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 06:28 PM   #2
GK
Walking with God
GK's Avatar
Default Re: AU 1 Forte Electrical problems
Matt
With 2. the cruise control, does the little 'cruise' icon appear on the dash when you turn on the cruise from the indicator stalk? If yes but the actual cruise won't engage when you hit the 'set' button on the steering wheel, then check to see if your brake lights are all operational. They are linked. Happened to myself a number of years ago. Cruise wasn't working, checked the rear brake lights, they were out. Changed globes, voila, the answer!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 26-07-2011, 12:52 AM   #3
MattsDisturbed
Bseries
Yes it does, I might look at all the bulbs now. Cheers
Check it out:
Old 26-07-2011, 11:01 AM   #4
FGII-XR6
FGII-XR6's Avatar
headlight sockets get coroded after a while and need replacing when you replace a smear of silicon grease stops it hapening again
[SIGPIC][/SIGPIC]
Rides:
