Old 01-09-2007, 06:55 PM   #1
daz_
Default Interior Light
I'm guessing its the same in the sedan...
Interior light has what looks like 2 prongs inside of what looks like holes i'm guessing you need to push the prongs back inside is there a trick to getting them out?
daz_ is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 07:26 PM   #2
congo3sr
Hi,are you talking about the light cover,or the map light surround?
cheers george
congo3sr is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 07:49 PM   #3
daz_
I've got the ute, its got an internal light at the back ...
Interior light not map light
Old 01-09-2007, 08:47 PM   #4
b2tf
not here much anymore
b2tf's Avatar
are you trying to remove the bulb? if so, just carefully pull it out of the bits that hold it.
otherwise im not sure what youre trying to ask?
RAM 1500
Old 01-09-2007, 08:57 PM   #5
daz_
Remove the light holder so I can pull down the roof lining...
Sorry I guess I didn't make complete sense...
Light holder has what seems like prongs in each corner with little bits of metal if you look in that look to be holding on somehow... How the ell do I get them out?
Old 01-09-2007, 09:07 PM   #6
b2tf
b2tf's Avatar
ok makes more sense now!
the entire unit itself should come off, the clips shouldnt be connected to the roof itself at all.
RAM 1500
Old 01-09-2007, 09:11 PM   #7
daz_
Wtf?
Just pull it down?
The clips definitely go into the roof just I guess not knowing if they're clipped in or what don't want to break stuff!
This is the interior light assembly at the back in the ute...
What about the front assembly / sunglasses holder? seems held on not quite as well as the other but also has 2 bits in the middle that look kinda stuck in there too
Old 01-09-2007, 09:13 PM   #8
b2tf
b2tf's Avatar
Wtf?
Just pull it down?
just realised im talking about the wrong set of clips:
RAM 1500
Old 01-09-2007, 09:24 PM   #9
daz_
Oh you talking about the clips that hold the roof in? yeah... pull those ones straight out
Its stuck in there pretty well! Why can't people just use screws?
Old 01-09-2007, 10:53 PM   #10
daz_
Alright... for everyone's info they are just clips just gotta lever them a bit harder
Old 02-09-2007, 12:14 AM   #11
lotus
Just a bit of info on the interior light itself. This interior light is used from EA to BF models, the only difference is the metal clips that are used on the later models(AU-BF).Went to ford to get one for my EB and got one with the clips (EB's have four screws hold them in). Was told that the light is used for replacement of all models. This is for the light only, not the one with the map lights from earlier models(fairmont,XR's ect).
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2007, 12:31 PM   #12
daz_
Ok so some info on the interior of the AU (possibly sedan?) and the interior light
Interior light just needs some leverage but pops straight out
Sunglasses holder / map lights is not held onto the roof at all although it is attached to the roof lining! Short of cutting the wires there's no way to get this out other than to unplug the lights from the clips and feed the lights / clip back out through the insulation on the roof lining! ( of a job and you'll need to reattach the insulation somehow later on)
Old 03-05-2011, 06:28 PM   #13
isharpen
Default Re: Interior Light
Well after reading this I decided to give it a go with my headlining, I have the lining out now. I was also stuck with that interior light and could not work out how to remove, a bit of wedging back and forth got it in the end.
Rubbed and lightly washed the lining and the backboard.
What glue are people using to glue it back, local shop suggested spray on contact, which sounds reasonable what's your thoughts?
By the way thanks for those that gave the input
isharpen is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2011, 06:57 PM   #14
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
just pull the light houseing it will come out its cliped up there by 4 Srong steel clips SO Just yank a little on it and it will come off
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
