08-11-2010, 03:39 PM | #1 | ||
Hey Guys my 01 falcon ute is flashing 3 3 thats passanger side short circuit right? theres no loose connections i have looked. what else could have gone maybe the seat belt pretensioner? any help guys would be great
cheers |
11-11-2010, 06:35 PM | #2 | ||
Having exactly the same problems, code 33, all wiring checked, about to call auto electrician???
2000 AU11 XR8 UTE 5 Speed - play/day 1992 80series Landcrusier Turbo - play 2009 Hilux - work |
11-11-2010, 07:22 PM | #3 | ||
Code 33 is not a short circuit.
Code 33 indicates Passenger Side Airbag open circuit. |
15-11-2010, 10:19 PM | #4 | ||
ok thanks guys markvic66 let me know how u go if u go to the auto electrician.
what do u mean by an open circuit? i thought open and short were the same? cheers |
19-11-2010, 12:54 AM | #5 | ||
No open circiut is the complete opposite to a short circuit, mine is flashing 33 to which i understand is open circuit passenger side air bag, its an intermintent fault, seems to start flashing after an hour or so of driving, car will be at mechanics later today on an unrelated problem, next door is the auto electrician, will be chatting to him, will keep you posted
19-11-2010, 07:31 PM | #6 | ||
ok cheers mate. would be good to find out possable causes of the issue
23-11-2010, 09:01 AM | #7 | ||
Ok after checking and rechecking, cleaning and re cleaning with contact cleaner all the plugs in the circuit that i could find, I bit the bullet and pulled out the passenger seat, the pretennsioner is an unserviceable item, so replaced it, touch wood problem is fixed, all up to remove seat and replace pretennisioner took 30 min cost $30 all you need is a number 5 torx bit. hope your problem is as easy fixed and mine stays fixed of course!!!!!!
23-11-2010, 06:55 PM | #8 | ||
ok cheers mate the pretentioner is the buckle bit? if not what is it exactually?
24-11-2010, 10:26 AM | #9 | ||
yes mate the buckle, bit, the pretennioner is one complete unit, take the seat out disconnect the wires unbolt the unit and bolt in another one, if you get one from a wrecker, plug it in before you drive off, and check that the dash dosen't flash
24-11-2010, 06:44 PM | #10 | ||
yeah thanks mate thought that would it and think it will be the problem. wreckers say that by law they cant sell any seat belt part. and ford want bout 220 for one.
cheers for the help mate |
30-11-2010, 03:53 PM | #11 | ||
Feel the boost
Hey guys, my XR8 has the same problem, its only occasional and as silly as it sounds it always happens to be a case of wiggling the wires under the seat and its good as gold.
2005 BA Mk2 XR8 ...... Let the fun begin Drive carefully! Remember, it's not only a car that can be recalled by it's maker. |
30-11-2010, 04:48 PM | #12 | |||
Flairs - Truckers Delight
30-11-2010, 11:13 PM | #13 | ||
that was in S.A he said some wreckers may sell them but by law they arent suppose to. not sure if its everywhere or even if it is the law just what he told me.
